After getting scoring for Grange ready I turned my attention to hall wiring combos. Ahah, noticed a culprit. When I plugged the Halls in, the green wire slipped out of the plastic housing a mm, kinda tricky to notice. When I'd disconnect, the green wire would retract back into the housing and the pins all appeared in place on visual inspection. When trying to put a corresponding pin into the green F JST it was closed, probably a tad of solder got in the wrong place. Yippee
An easy fix and my hopes returning.
The magnifying shot is the fresh pin before crimping and last touch with solder iron.
All right, got 'er fixed up. Nothing, hmmm, try plugging the CA back in, whaaa. . . bike jumps full speed off its' workstand, a lipo burn smell in the air.
Now this is bad karma. Generally the batt box fits securely, only way to get it out is to 1st lift it upward. Yet to plug in the CA, it needed to be unstrapped. The bike landed somewhat upsidedown, batt box dislodged, pulled a harness wire up with a sharp 12ga solder scrapping a snug fitting swelled lipo causing a briefly potent short. Kabamm
All CA settings are default. I can clean up the situation, makeup a precise fitting harness that tucks away and stays put. A 2 lipo loss and lesson learned. Tuned the CA settings down so to progress with single 6S lipo. There's truly nothing now, now even a 1 inch bump when plugging in, resetting CA.
Time to pass on getting my competitive bike rolling and just head off to Grange and have the most enjoyable Spring Break of years
See ya'll there.
My trouble shooting question now is: what causes full throttle upon plug in
Hopefully, another motor phase wire combo will remeady this, I'm running out of Lipo
