has anyone implemented reverse switch on an ebike?
monster   100 kW
Post by monster » Apr 21 2008 4:27pm
the crystalyte controller i got recently has a connection for a reverse switch. might be cool to go backwards on a bike?
kbarrett   10 kW
Re: has anyone implemented reverse switch on an ebike?
Post by kbarrett » Apr 21 2008 4:30pm
Please post mpegs of someone going backwards on a 72V bike.
Sun EZ-1 recumbent, Heinzmann 450W, 36V16A Ping "Duct Tape" LiFePO4
Evil Smoker ( Schwinn beach cruiser with 49cc two stroke, and a one gallon gas tank )
monster   100 kW
Post by monster » Apr 21 2008 4:32pm
the reverse switch i saw seemed to be somewhat slower than in the forward direction.
Link   100 MW
Post by Link » Apr 21 2008 4:44pm
kbarrett wrote:Please post mpegs of someone going backwards on a 72V bike.
I could plug in my BD36 backwards. It's only 48V, though :P.
monster wrote:the reverse switch i saw seemed to be somewhat slower than in the forward direction.
The C'lyte ones are limited in the reverse direction for obvious legal reasons.
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
RLT   10 kW
Post by RLT » Apr 21 2008 8:25pm
I've been trying to think of any likely situation on an ebike where a power reverse would be of any value that would outweigh it's liabilities.
I can't even see the value of a reverse even on a small to medium sized motorcycle, .... although on a big heavy Harley, BMW, Goldwing etc, Yeah
(Just a little bit of useless trivia... The Honda Goldwing Aspencade model was named after a local festival in my town that was kind of 'swiped' for a big bikers rally.)
And on an E-Trike or quadracycle, I can see it. But on a two wheeler??? Even my 100+ pound 2WD, I can pick it up and turn it around if I need to.
I could only see getting myself in trouble with a reverse.
deardancer3   10 kW
Post by deardancer3 » Apr 21 2008 8:34pm
monster wrote:has anyone implemented reverse switch on an ebike?
I initially put reverse on my e-trike. But when engaged, the pedals rotated backwards too, and was more inconvenient than just "Fred Flintstoning' it. I took reverse off.
dick
Chain Drive Advocate
lazarus2405   10 kW
Post by lazarus2405 » Apr 22 2008 4:18pm
I can't see any reason on a bike I'd ever want reverse periodically. If I needed the motor to run in reverse in the first place, I'd just switch the phases. With the reverse key switch on the clyte v1 controllers having no indicator whether it is in forward or reverse, many folks just disconnect it.
A better use is to simply put that key switch in series with the power button for a useful way to lock the "e" of the ebike. I always felt that inline key switches are too easy to bypass.
Ypedal   100 GW
Post by Ypedal » Apr 22 2008 7:02pm
Most of my controllers have a reverse key feature built in .. handy if you use the controller on a front motor converted to rear or X controller with Y motor combinations..
Heavy trikes could make use of it as well..
And.. at oen point i accidentally mounted the motor the wront way.. much easier to just flip the switch than cut the zip ties and re-mount the wheel !! :lol:
Forward or reverse...same speed.. same no-load current. ( On older style V1 controllers.. don't know bout the V2. )
ES site status page:
lazarus2405   10 kW
Post by lazarus2405 » Apr 22 2008 8:14pm
I was surprised to find... there is no reverse on the v2 controllers. :shock:
...Not that I'll miss it.
Dee Jay   100 kW
Post by Dee Jay » Apr 22 2008 8:47pm
The only reason the reverse feature was made, as far as I can see, was to give you the option of flipping the whole wheel (of the front motor only) so that the wired side of the axle can be on right hand side. Obviously this cannot be done with a rear motor. I doubt the reverse was made to allow riding your ebike backards . . . :lol:
lazarus2405   10 kW
Post by lazarus2405 » Apr 22 2008 8:56pm
You make the mistake of assuming that pedals are a requirement.
Dee Jay   100 kW
Post by Dee Jay » Apr 22 2008 9:59pm
lazarus2405 wrote:You make the mistake of assuming that pedals are a requirement.
That's very true. In third world countries. :wink:
kbarrett   10 kW
Post by kbarrett » Apr 22 2008 11:41pm
It says it has to have pedals to be an electric assist bike.
No where in the US regs does it say they have to actually work ...
Rassy   1 MW
Post by Rassy » Apr 23 2008 12:58am
No big deal Kb, but Oregon regs (ORS 801.258) actually states:
Has both fully operative pedals for human propulsion and ...
So if you get one of Safe's old bikes and ride it accross the bridge... :D
Edit: Oh yeah, on topic, I think the main purpose for the reverse option is for use on trikes and quads.
-Rassy-
One Tadpole Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 28&t=69419
One Delta Trike equipped with a Bafang BBS02
https://endless-sphere.com/forums/viewt ... 0#p1291260
lazarus2405   10 kW
Post by lazarus2405 » Apr 23 2008 8:25am
With your trailer drive system, that reverse would really be useful.
rkosiorek   1 MW
Post by rkosiorek » Apr 23 2008 9:41am
lazarus2405 wrote:I was surprised to find... there is no reverse on the v2 controllers. :shock:
i use the "reverse" occasionally on a heavy delta style trike. helps when i am backing up somewhere with a heavy load. the trike has a C'lyte 408/4012 on the front.
to get reverse on the V2 controller you just need to locate a pad on the board labeled DSP and short it to ground.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
Rassy   1 MW
Post by Rassy » Apr 23 2008 11:17am
Actually I toyed with the idea on my trike/trailer, but with the short wheelbase it is difficult to back in a straight line by hand.
-Rassy-
Ypedal   100 GW
Post by Ypedal » Apr 23 2008 11:21am
Heh.. next time the boys are over having a few drinks.. i'm getting the X5 powered BMX out .. flipping the reverse switch and handing it over to the closest friend... with instructions to
" Lean forward.. and just FLOOR IT !! "
:D yeah.. i'm like that ! :wink:
lazarus2405   10 kW
Post by lazarus2405 » Apr 23 2008 11:57am
Ypedal wrote:Heh.. next time the boys are over having a few drinks.. i'm getting the X5 powered BMX out .. flipping the reverse switch and handing it over to the closest friend... with instructions to
monster   100 kW
Post by monster » Apr 23 2008 1:44pm
make sure he has a helmet!
reverse is useful when your waiting at lights and a driver cuts the corner at speed. hit reverse to get out the way. also it might be cool for showing off -do something that other cyclists can't. might be good for three point turns in confined space with heavy cargo.
kbarrett   10 kW
Post by kbarrett » Apr 23 2008 3:29pm
Be sure to say "Hold my beer", and "Y'all watch this!" just before you start.
