youreaspeedemon
Let me just say that this is an impressive board with a lot of smart creative members, I stumbled across it looking for info about Crystalyte stuff and needless to say I have been spending many late nights reading through a lot of posts (my wife hates it). I think I have a pretty good game plan so I'll lay it out and ask for some feedback from you guys. It's a bit of a long read but I'm trying to be as descriptive as possible.
Thanks in advance,
Glen
First is what I need/want in a bike without spending a fortune and having the ability to upgrade later to better batteries when the prices come down or I have more money;
- 15 mile range minimum at sustained not average speed of 20-25mph and being able to get up light hills for commuting, one way is about 12mi, 10mi are smooth bike paths, I will pedal some to save juice from stops and such, and I can charge at work (approx weight with me on it would be 305lbs)
- 2-5 mile range balls out with a top speed of 30-35mph for having fun on the weekends
- 2-5 mile range towing a 20 lbs trailer with 60 lbs worth of kids at 10mph maybe 15mph but that's pushing the safety limit with kids in tow (total bike with everything/everyone would probably be approx. 385lbs
Second is what I have to start with;
a. 35 lbs. Bianchi Rigid that has 26" rims with street slicks, fenders, a rear rack and panniers
b. 52 lbs. of SLA out of an APC UPS model RBC11 they're 4 batteries at 12.5lbs each- 12v and 18ah, they are built in 2 battery series already so I would connect the 2 24v 18ah packs together in series to make it a 48v 18ah pack (free and I have 8 total to make 2 - 48 volt packs) I can't find the C Rating anywhere but since they're designed for a UPS I would imagine that it would be pretty high.
c. 195lbs of Me with clothes and loaded pockets
Third is this is what I was thinking of doing using the info I've gathered from many of the posts here;
1. Rear Crystalyte Phoenix 5304 Cruiser Black from Electric Rider (more torque than racer for towing kids plus the extra weight of the SLA's)
2. 36-72V 48A Start Immediate Digital Controller (IRFB4110 Mosfets) from ebikes.ca (for future battery upgrades)
3. put the 4 SLA's in Series for 48v 18ah pack (thats about all the weight I can handle in the panniers)
4. one of the Cycle Analyst's from ebikes.ca not sure which one (Recommendations Please)
5. Crystalyte Twist Throttle
6. Necessary wiring kit, 2 30amp fuse holders, additional Andersons to wire everything up and 2 spools of 10g wire black and red
7. I've already ordered black styrene to make some cheap disc wheel covers to make it more stealth
8. Put batteries and controller in panniers with minimal wiring exposed to make it more stealth
Not sure if this can be done with the batteries I have but from what I've read it seems like it should work, the weights I'll be dealing with are approximately;
bike - 35lbs
hub motor - 25lbs
SLA's - 50lbs
me - 195lbs
trailer - 20lbs
kids - 60lbs
Built bike - 110lbs
Built bike with me on it for commuting - 305lbs
Built bike with me on it for fun with the kids and trailer - 385lbs
With the above weights would I need to get the Crystalyte Phoenix 5305 Brute or would that be overkill.
or could I get buy with getting the Crystalyte Phoenix 5303 Racer (probably not enough torque)
I'm still going through posts on Freewheels, Kickstands, and Chargers
Should I get the 5 or 7 speed freewheel? I have older XTR components, if I can't adjust the derailer for the lack of 1 or 3 gears I'll have to replace with something else.
And
Is there a good heavy duty kickstand that I can use for all this weight? Possibly a center stand to help with supporting the bike if I ever have to remove the rear wheel.
Also
SLA Charger that is not to expensive so I can buy 2 - one for home and one for work that can charge a 48 volt pack with at least 5 amps so charge time will be at or less than 4 hours also can I charge the pack in 48 volt series
With the SLA's do I need to worry about balancing the cells and breaking the pack apart to charge each battery separately? I've gathered that they balance themselves out pretty well and don't need the extra attention.
Can I use a car charger and charge the 4 12v batteries in parallel I think this would take longer because it only puts out 6 amps and it would be like charging a 12v 72ah battery.
SLA's from what I understand can't be quick charged, the question is will they take enough of a charge in 4-6 hours to be near 100%, if not I guess I would need to charge for 8 hours at least which shouldn't be a problem considering I'm usually in the office for at least 9 hours. Can I get a full charge on them in that amount of time and if so what configuration of charger/chargers and voltages. All this being said I'd rather not have to rewire the pack every time I want to charge it.
Would it be more cost effective and better on the Batteries if I split the packs and charged with 2 chargers at 24v.
Thanks again for spending the time to read this and offer any advice or comments.
Glen
Thanks in advance,
Glen
bike - 35lbs
hub motor - 25lbs
SLA's - 50lbs
me - 195lbs
trailer - 20lbs
kids - 60lbs
Built bike - 110lbs
And
Also
Glen
