My solar-assisted custom tricycle FOLLIES
ddk   1 MW
Re: My solar-assisted custom tricycle FOLLIES
Post by ddk » Nov 10 2018 12:55am
pic one
choices choices.jpg (132.62 KiB) Viewed 568 times
needs expression maybe :banana:
docnjoj wrote:
Nov 09 2018 8:03am
"All the better to see you with"! Great stuff!
otherDoc
"How can we play Hot Wheels without lighter fluid? " -Serge
amberwolf   100 GW
Post by amberwolf » Nov 10 2018 10:46am
ddk wrote:
Nov 10 2018 12:55am
You could pin one pupil up at the top and leave the other loose, for that "derpy" look. ;)
Or stick a clock movement with a magnet on the second hand, behind the plexiglass behind the eye, and another magnet on the pupil, so the pupil moves around like rolling eyes. Just one eye or both if you have two old clocks you don't use. :roll:
ddk   1 MW
Post by ddk » Nov 14 2018 6:59pm
amberwolf wrote:
Nov 10 2018 10:46am
You could pin one pupil up at the top and leave the other loose, for that "derpy" look. ;)...
This trike sports no front suspension. As such, as it travels down the road it's googly eyes googly very much.
The trike formerly drew a lot of attention but now it draws twice as much :pancake:
new camera
focus fun.jpg (51.5 KiB) Viewed 533 times
not even close to it's maximum zoom
100 meters distant.jpg (80.08 KiB) Viewed 533 times
manual focus does another trick
branches aplenty.jpg (94 KiB) Viewed 533 times
:confused:
wturber   100 kW
Post by wturber » Nov 15 2018 12:47pm
Neodymium magnets and chain could be used to make adjustable eyebrow and mouth expressions.
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
ddk   1 MW
Post by ddk » Nov 19 2018 7:48pm
I was just thinking that it's been awhile since I installed the front motor so I probably should recheck connections between the controller, motor and battery but this weekend I was either too lazy, too cold, or doing my favorite thing, procrastinating.
Come today and it's sunny and mild and whales might be aboot (or aglove) so I grabbed the new camera, the tripod, my coat (because fog is always possible) and set off to a high point by the ocean. Curiously enough, this 'high point' is named 'the point'.
As usual, fog rolled in as I neared my destination.
Doing a 180, I then donned the coat and started smelling smoke coming from wherever.
In an area prone to being covered by smoke from wildfires [cue music] music intensifies [/cue music]
Coasting down a long incline to the bridge over kwai I continue to smell smoke. Climbing out of the river valley the smoke stench is stronger but this seems common occurrence these days.
I pays it no mind.
But then... randoms jerks from the front motor and of course, this is also the time the rear motor decides to do it's thing of randomly failing.
Lucky for me the jerks stop and I make the trip home without another incident.
And as I pull up to the workshop I see smoke emanating from my steering tube, where I have the controller and it's connector mounted. :flame:
shoulda tightened screws.jpg (54.69 KiB) Viewed 488 times
Apparently the yellow phase wire loosened it's connection, causing said wire to overheat destroying the connection along with it's neighbors.
wturber wrote:
Nov 15 2018 12:47pm
Hey hey, you be talking to a superbly lazy person here.
Ain't gonna happen. :pancake:
+ the trike already gets more attention then it deserves
ddk   1 MW
Post by ddk » Nov 23 2018 2:13pm
...of course I had to repair the damage the very next day, as I had to attend an appointment the day after. This included the first day of the rainy season where I got to experience the joys of riding through heavy rain and gusting winds (not that it's enjoyable, but doing so is always exciting, if one finds risk exciting) (I don't especially find risk exciting, but it does keep my interest somewhere in the 'high anxiety' ranges).
Had I left for the appointment 30 minutes later, I might have missed the strongest part of the storm. But I gets so antsy about things like 'flats' and other stuff [see: previous post about 'other stuff'] so I tend to start my trips that require my timely arrival about an hour before I expect to arrive had I not experienced any 'issues', so to speak.
I had no issues, so to speak and arrived at my destination with that hour to spare.
Fixing the burned connections and wiring involved snapping off the undamaged (and unused; see previous photo) connectors, cutting and trimming back the wires to undamaged areas and reconnecting using the previously unused 16 ga euro blocks.
It's always good to have extras of everything, especially if you're out and aboot (or aglove) on your homemade contraption and 'issues' arrive before you do.
BTW, one of the many reasons I will not use a 40A controller with this motor is that its' phase wires are only 16 gauge. I'm already pushing the wiring to its' limits using a 26A controller.
no photos again
ddk   1 MW
Post by ddk » Dec 11 2018 5:27am
break out the party favors, balloons and ice cream.
My solar panels have finally paid for themselves! :bigthumb:
They've just provided me with about 300kW of power for chargers and whatnot, whilst idle generation of an additional 2MW kept the solar systems' AGM batteries warm (I guess)
I still haven't replaced the batteries in my 7S packs, marking the eldest at 6 years of age.
Although they were showing some signs of needing replacement, in reality the way I utilize the rear motor of the googly-eyed trike makes voltage sag an indifferent consequence to the overall operations.
IOW meh...
Speaking of trikes there's not much to speak of.
I'll be exchanging the rear disk brakes for BB7 types in the near future (waiting for parts)
but other than that I only had that one issue with the loose connector this year :flame:
*knocks on wood* I didn't even have a flat tire this year (breaks open the fake Champagne to celebrate) (diet soda)
The googly-eyed modification has increased the trikes speed and beauty (reality check=nope) (however, googly eyes makes everything better)
a flock of ships.jpg (59.27 KiB) Viewed 366 times
400 meters birdy.jpg (50.82 KiB) Viewed 366 times
is this my best side.jpg (23.54 KiB) Viewed 366 times
or is this.jpg (22.53 KiB) Viewed 366 times
down in front.jpg (24.32 KiB) Viewed 366 times
processed photo
moon stroke.jpg (48.22 KiB) Viewed 366 times
docnjoj   100 GW
Post by docnjoj » Dec 11 2018 9:33am
Love those images!
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
ddk   1 MW
Post by ddk » Dec 23 2018 7:11pm
docnjoj wrote:
Dec 11 2018 9:33am
Love those images!
otherDoc
thanks! ...and I like to take'm
speaking of which; on a wet and stormy today I took more...
waves washing road.jpg (28.28 KiB) Viewed 319 times
logs tossed aboot.jpg (36.2 KiB) Viewed 319 times
wash out.jpg (27.99 KiB) Viewed 319 times
hawking around.jpg (64.55 KiB) Viewed 319 times
ello dere.jpg (42.25 KiB) Viewed 319 times
waves hi again.jpg (27.4 KiB) Viewed 319 times
ddk   1 MW
Post by ddk » Jan 10 2019 6:43pm
bb7 brakes to replace rear disk brakes almost completed. Real tests done Monday as trucks attempted to smash into googly-eyed lite-up trike.
They missed.
group grope.jpg (64.64 KiB) Viewed 246 times
lounge act.jpg (34.74 KiB) Viewed 246 times
gov debate.jpg (36.79 KiB) Viewed 246 times
blowing raseberry.jpg (27.21 KiB) Viewed 246 times
mybike   100 W
Post by mybike » Jan 19 2019 1:55am
Hi ddk, I posted on another thread and was told to ask you as you have been using Neutrik chassis connector and spekon connectors.
I have Neutrik NL2MP 2 pole chassis connector (brought from ebay UK). I am tying to find out can Neutrik NL2MP 2 pole chassis connector handle 10A without any issues, have you tried the 2 pole ones?
I want to use it for charging my battery pack and worried about smoking it. The max I will ever charge is 10A cont… but at the moment I have a 5amp charger. The info I have so far they can handle up to 30A but I don’ think that’s all true… or is it?
ddk   1 MW
Post by ddk » Jan 19 2019 5:10pm
mybike wrote:
Jan 19 2019 1:55am
Neutrik's specs are usually spot on, but there are many fakes available.
I tested the 2-pole @ 10 amps without issue.*
Why I use the 4 pole connectors is even the fakes handle 30A with no issue if you double up the connections (i.e, 2 connections for the +, two connections for the -)
Since I posted, pics:
mars attacks part two.jpg (61.46 KiB) Viewed 188 times
a pleasent summer day in winter.jpg (50.83 KiB) Viewed 188 times
spring springs.jpg (39.28 KiB) Viewed 188 times
interesting, I spotted these ducks and misidentified them as puffins, mainly because the first duck would bend its head giving the impression of a puffin (same size, same coloration, as seen though a dirty window) When two more ducks suddenly appeared I started to question my initial identification.
duck ducks.jpg (34.33 KiB) Viewed 188 times
Of course, puffins don't usually feed in an enclosed area like a bay or harbor. but I've witnessed too many 'unusual' birds over the years.
a Buffohead duck
* I utilize 2 poles of the NL4 connector for charging, and my chargers supply up to 10A of current, so even the fakes and off-brands should serve your purpose.
ddk   1 MW
Post by ddk » Feb 06 2019 9:04am
It's been somewhat exciting around these parts.
Experienced Robins returned a couple of days ago, same day it snowed.
let it snow.jpg (53.39 KiB) Viewed 117 times
snowed trees.jpg (55.85 KiB) Viewed 117 times
I saw snowflakes falling
suddenly melting
but a different tale was told 100 ft higher.
100 ft higher.jpg (51.69 KiB) Viewed 117 times
Earlier this year a King Tide (as opposed to a Queen Tide, I suppose)
and rough seas caused some damage and washing across the whole of the
RV grounds I formerly kept house in (on)
rough seas get it on.jpg (69.19 KiB) Viewed 117 times
handrails washed away.jpg (121.31 KiB) Viewed 117 times
The temps have been in the low 30s F (1C).
Speaking of Polar Vortex (no we weren't) I'm so old I remember weeks of
'Polar Vortex' like weather back in NE during the 60's 70's and 80's
I distinctly remember getting stuck in North Dakota for several days where
the daytime temps never got higher than -44D
(pick your favorite F or C cause at -44 they be the same thing... too cold)
Engine heaters, new batteries and starters failed the mission of starting a
super cold truck engine.
I ended up draining the crankcase oil (took a whole day) warming it up
on a stove tricking the truck into starting.
I'm guessing a lot of power would be used keeping an electric car's
batteries warm enough to function in weather like that
...speaking of which (we was) no problems getting around in MPdPM.
I blame the googly eyes.
ddk   1 MW
Post by ddk » Feb 16 2019 4:25pm
generally speaking, the weather locally remains what's known as 'normal'. Normal being strong storms, lotsa rain and more rain.
Yesterday a lightning strike was so close to my abode the sound of the electrical discharge was heard milliseconds before the thunderous boom. (zaaaap BOOM)
Scary.
It actually is rare that we has a lightning and thunder event here, in fact I only discerned two of those events yesterday. But I'd rather they ( lightning, thunder) be accompanied by a large dose of water (rain) to extinguish any sparks. Otherwise wildfires. :flame: And for the last few years we've had some doozies. (opps... wildfires)
barking up the wrong tree.jpg (95.68 KiB) Viewed 54 times
by morning it was gone
dark and snowy.jpg (16.07 KiB) Viewed 54 times
wuts up.jpg (72.02 KiB) Viewed 54 times
anchors away.jpg (52.34 KiB) Viewed 54 times
The googly eyes remain the same (except mold is growing behind the right googly)
markz   100 GW
Post by markz » Feb 16 2019 10:57pm
Was watching on yt some aussy guy with a sweet truck doing some flicks, he is an "out backer" and active sports type. Claims the generic flexible solars are not bad. Young bloke, got that california look to him. I will see what I can find, he's got a topper, dark truck.
He is too smily
https://www.youtube.com/watch?v=3-sc4rlV93g
He is always smiling, where is my gallon of vodka!
