dogman said:Well, have we got a use of english problem? Without discharging the battery, you can pedal around the world if you never turn the battery on. :wink:
But I have a rule of thumb for 36v batteries. At typical full throttle speeds of about 23-25 mph, 1 ah will take you one mile reliably. You can go further with no wind and no hills, or less far with wind in your face or uphill. On the flat, you'd still be likely to have a few miles left in reserve, but less than 20% capacity.
Slowing to 20 mph, you will get noticeably further range. perhaps 1.2 miles per ah.
el_walto said:The battery BMS "Should" protect the battery from over discharge. The battery will actively cut out when it is at its minimum safe voltage. Fully charge your battery overnight. Reset your cycle analyst, ride until it cuts out. Your Cycle Analyst will give you your actual battery capacity in Ah . Might not be exactly 14Ah.
Most people will tell you to keep most of your cycles above 80% discharge in case the battery is out of balance etc. Every time you finish charging, reset your cycle analyst by holding down the right button for a few seconds. When your cycle analyst says you have used 11.2Ah, your battery only has 20% capacity left. Try to not use more than 11Ah on a regular bases
You should keep your battery topped up whenever you can. You do not need to discharge it like people used to do with NiCad batteries.'
The capacity of the battery is measured in AH, so if you have a cycle analyst you can easily see how many you have used. It will just count up, so you need to reset the CA every time you charge the battery.
Nelson37 said:Sorry for the noob question, but if charging a slightly-drained battery does not "waste a cycle", then what exactly is a "cycle"?
Say I drain down to 75%, then fully charge, three times, is that the same as draining to 25% and then charging once? In terms of total charge cycles available?
I was thinking that every time you put the charger on, that is one "cycle".
Nelson37 said:So far all I know about batteries is that I don't want SLA and I really, really don't want the ones that catch on fire. Still working on the differences between Ping and Cellman's batteries, but I'll get there.
The way I understand it, Cellmans packs have a higher C rate, a higher discharge rate. Running his a123's will make your bike quicker but not faster, given the same voltage.
The part about not being able to tell what I have left, and instead only what I've used, is a curve ball for now but knowing How it works is OK for now. Don't tell me, I'll research the Why later. That's half the fun.
Dang, I know this one. Ooooh Ohhh Mr. cotter, Mr. Cotter call on me! :lol:
Are high amp chargers more damaging to battery life than low-amp chargers, which take longer?
But if they still get out of balance with "short cycles", then don't I HAVE to do a "deep cycle" to balance?
