15s 15aH?
sacko
Kent, United Kingdom
Is this correct?
In either 'stack' there is;
2 x 6s 5000
1 x 3s 5000
Each stack is then made in parallel, then both parallel leads are put in series (at the controller)
I think you may have that wrong. I don't think you can parallel a 6s with a 3s. You'll create a short and current will flow from the 6s to the 3s to try and equalize. When you parallel packs they should be the same voltage.
You could connect them in series first then parallel. 6s + 6s +3s in series to make 15s 5 amp hours for each stack would give you 15s 10 amp hours.
You could also parallel 6s + 6s, 6s + 6s, 3s + 3s then connect those 3 pairs in series if you prefer to parallel first then series. The series first method is the simplest and has the least wiring.
Exactly, OP has 4qty 6S and 2qty 3S bricks. Most capacity for 15S is 10Ah and remember that is pushing it.
I do series groups 1st and then just parallel whatever desire for capacity. 2P, 3P, 4P, 10-20Ah.
Parallel 1st is ideal if dealing with all same bricks but that's obviously not the case here. No problem series wiring 6+6+3=15...
Each stack is 15s 5ah, so it's 15s2p for 10ah. But you've really complicated it with lots of unnecessary main wiring and no parallel wiring of balance cables (optional, but good idea imo).
The wiring is necessary as the packs have other uses (rc Heli).
I'll be using the Cellpro MPA board to parallel charge on my PL6. The board has re-settable polyfuses etc for safer charging, hence there being no need for parallel balance leads, just 6" extensions.
I know the OP doesn't have a 15s charger... so for discharging doesn't make much of a difference whether you parallel 1st or series 1st. But for charging (especially if you're bulk charging) parallel 1st is better since you'll only need to break half the connections to charge. And you can charge each group at a full 10Ah rather than separate bricks at onlh 5Ah.
Works if you ride only every once in a while but daily use and they'll start looking for a 62V supply to serial bulk charge. Why break any connections on a regular basis? Parallel business is just goofy and introduces way too many connections and possibilities for potential connector failure IMO. Using tested bricks series wired, one connection 62V supply. RC Charger for troubleshooting, balancing work only.
I have the exact same packs as the op and that's how I do it. The pairs of paralleled packs are also paralleled at the balance taps as well.
