Houston, we got a problem! :x
I had pain to finish the third and 4th stage spokes on that rim!
12 gauge spokes are difficult to assemble when your rim eyeslets doesn't fit!!!
--TAKE 1--
First, I drilled all eyeslet.. then i began to assemble the first round of spokes...I just turned 3 or 4 turn on the nipple to allow space to work..
then i assembled the second round of spokes... from now.. no problem
I turned the rim to twist the 2 round of spokes clockwise.. to prepare the next third round of spokes in the other directions
And.. the main problem i had is that the driled hole in the eyeslet only allowed the nipple to fit straigt.. and no angle possible on the nipple.. so to assemble the third round i NEED to put these nipples at the angle to be able to screw it on the spoke that came in the other direction...
--TAKE 2--
So i dissassembled all the spokes and verified with my other 5303 hub to see if something is wrong... and it was correct.
Then i noted all spokes angle that goes on the rim eyeslet with a blue pencil on the rim.. then i drilled again all eyeslet in each of these angles.
I began again the third round of spokes install( the spoke in the inverse angle single crossed)
I succeded to screw all, but some nipples had difficulty to screw and the first threads brokes in the eyeslet...
all the spokes have been already very thight... but i diden't torqued them.. i just needed to make few turn of each nipples, but to be able to fix all them i needed to tight alot all of them to reach the only firsts threads... like if the spokes could be too short..
And came the final 4th round installation...
I have to say that it was a pain to install!! :x
I had to tighten again all the 3 first round of spokes to be able to reach the first thread of the spokes!!
Well.. something is certainly wrong !!
I dont understand why they was so difficult to install .. I oiled all thread before to ensure no friction could make it difficult to screw..
but the shape and the crossing desing i used are standars.. the offset of the rear hub motor from the rim is ok too..
But the spokes are tightened at the very limit.. and i still see the threads on the spokes... :|
They make the same sound than the last cord of an electric guitar!!
I checked to see if it could be normal to see the thread on the spokes on some other wheel i have.. and no one have that problem..... maybe if i see this exemple, where we may observe the thread on the spokes, indicating that i'm ok too?
http://www.scootonthis.com/images/jpg/productimages/crystalyte/rimblack_600.jpg
i'm confused.. cause i know that all the spokes only have half thread into the nipples.. so they are not as solid as they should !
I really dont understand why Justin sent me this kit of rim ad spokes that are not compatibles...!
i'll go to sleep now.. it's 2:30am maybe that will help for tomorrow
Doc
