BMC brushless 1500 watt motor from superkids
johndjmix   10 W
Post by johndjmix » Oct 01 2012 3:05pm
Has anyone tried the BMC 1500 watt motor from superkids? This is one of the motors I would like to try for my bike prototype. Would appreciate some input on how it performed.
--john
torqueon   1 kW
Re: BMC brushless 1500 watt motor from superkids
Post by torqueon » Oct 04 2012 10:29pm
There's a lot written about the 2000 watt bmc motor, similar to the 1500 watt model. I my self have chased this motor among others.
To me the motors are over priced and when I ask, there out of stock!!
Funny this topic seems to surface every 6 to 8 months
Prove me wrong !!
Pete
knoxie   10 MW
Post by knoxie » Oct 05 2012 2:43am
http://www.thesuperkids.com/15wabmcbrmos.html
The website says they are in stock but as with most things that doesnt always mean that they are :roll: good little motor if you can get one though.
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
neptronix   100 GW
Post by neptronix » Oct 05 2012 3:24am
There is not a lot of documentation on these motors.
But yeah, the question does come up.
Magudaman has played with it, but not documented it too much on his own threads.
I do not know who else has played with these extensively.
I do know that you are going to need a dual reduction to get these motors up to proper speed though, IE a 7:1-10:1 ratio.
I do have a bit of info on it's MAC variant though;
http://endless-sphere.com/forums/viewto ... 30&t=40166
The "2000W" MAC lawnmower mower is identical in most ways, main difference being the cover. But it doesn't have the best heat path.
http://endless-sphere.com/forums/viewto ... c&start=75
Wish i had more info for ya :/
johndjmix   10 W
Post by johndjmix » Oct 05 2012 10:56pm
Thanks guys, gear reduction is no problem, using a neugart 90 deg reducer....
Yea, hearing good things, but all 4 of the motors im going to test I hear good things. Anyone got a good source for the MAC version?
--John
johndjmix   10 W
Post by johndjmix » Oct 16 2012 2:14am
Actually got a 114 tooth rear sprocket and a 12 tooth front, that should get me right where i want to be in reduction.
But the wiring of this motor has me stumped:
3 Thick phase wires.....I understand these.
Then a 5 conductor wire:
Red:
Brown:
Green:
Black:
White:
I assume this is the hall sensors....but whats what?  Which is +5v and which is ground and which is A B C?
Then there are 2 thin single wires coming out of the motor: blue and black.  What are these for?
--John
sn0wchyld   1 MW
Post by sn0wchyld » Oct 16 2012 2:57am
johndjmix wrote:Actually got a 114 tooth rear sprocket and a 12 tooth front, that should get me right where i want to be in reduction.
Red:
Brown:
Green:
Black:
White:
--John
red shoul be +ve, black ground... the other 3 - its up to you to match them with whatever controller you use. A bit of experimentation (with no load on the motor) will usually reveal the result.
\http://www.endless-sphere.com/w/index.p ... less_Motor
that should give you some idea... just write down the combo's you've tried as you go along, should only take half an hour or so at worst.
johndjmix   10 W
Post by johndjmix » Oct 19 2012 11:39am
Be sure to try all 36 combos of halls and phases. If you are new to brushless (As i am), you need to realise just moving one or the other (Hall wires of phases) is not enough! You must try moving all of them to every possible combo (36 combos). 6 will run good.
--John
johndjmix   10 W
Post by johndjmix » Oct 21 2012 9:00pm
Anyone know what this motor should draw with no load? Im bench testing it and seeing in excess of 10 amps on full throttle.....is this normal with no load?
It runs totally smooth, so i think the above wiring is correct.
--John
neptronix   100 GW
Post by neptronix » Oct 21 2012 9:17pm
10 amps, at what voltage?
dumbass   100 kW
Post by dumbass » Oct 21 2012 9:56pm
Hell I would think 10a at even 24v would be high at no load.
Bob
BTW, now that you've had a chance to test run the motor how much noise, wine, whirl or sound does it make?
neptronix   100 GW
Post by neptronix » Oct 21 2012 10:14pm
Here's my MAC "2000W" spinning up to 2700rpm ( 70kV ) at 38.6v using all of ~2.75 amps.
p.s. does yours have the same funky plastic case, or did you get a fancy metal case with your BMC?
The Stig   100 kW
Post by The Stig » Oct 22 2012 2:24am
Dam that sounds evil! :twisted:
johndjmix   10 W
Post by johndjmix » Oct 22 2012 11:46am
The test was at 48V.....humm, maybe the kelly hall sensor setting is wrong, it can go 60 or 120 degrees...
neptronix: Where did you get the 2000 watt motor? Superkids hasent had it in ages!?????
And yes, mine came with that plastic case....
--John
neptronix   100 GW
Post by neptronix » Oct 23 2012 12:16am
That's cheezy that you got yours with a plastic case too. I guess BMC and MAC are now doing that :(
Yeah, it does sound good. It has that grunty tone from having a lower pole count than the MAC hub motor. But what is really disappointing with this motor is that it has the same stator dimensions as the MAC hub motor, and just a tiny bit more neo magnet thickness.
The 2000W model i have is very similar to your 1500W model. I got it by saying the right magic words to a particular MAC sales rep. If my tests of the motor turn out good ( i swear i'll get to the tests one day :P ), i may get a group buy going, but so far i am not too psyched about this motor.
Video of the motor in action ( from magudaman ).
Here is a relevant thread on the "2000W" MAC motor.
johndjmix   10 W
Post by johndjmix » Oct 23 2012 1:05am
neptronix: What controller are you using?
Im using a kelly and didnt get the high speed option on it, myself and kelly girl are both pretty sure thats the problem. Its a bit confusing, when i ordered the controller the kelly says "supports up to 40000eRPM. I didnt see the E, and thought it meant RPM. Im not sure of the formula to convert, but Fany at Kelly says thats the problem. So ill ship that one back for them to modify. Then this motor will go on one of our other ev's we build.
As for the bike, ah, after reading several threads (yours included) i realized im not going to have the performance i expect without going big. So I ordered the Golden motor 5000 watt brushless. I was torn between that and the brushed/brushless etek's, but what it came down to is size, as the golden is just a tiny bit smaller and will fit in my frame design better. From the videos ive seen looks like the golden makes a TON of power, should work well. Went with the air cooled unit as I cant see overheating this monster on my 100lb bike. Makes me wonder though, does the water cooled unit have a impeller built into the motor to pump the water or do you need an external pump?
--John
marksch   100 µW
100 µW
Post by marksch » Nov 18 2012 1:11am
did you get the combo 1500w bmc and the 72v 55a Crystalyte controller?
I have the combo 1500w superkids kit am going to test it this week when the throttle get here.
neptronix   100 GW
Post by neptronix » Nov 18 2012 1:24am
I'm just using one of cell_man's infineons. ( aka a lyen mark II controller )
..which i estimate is good for about 4000-5000rpm on these motors.
Yes, eRPM and RPM are two different things. It has to do with the number of poles. I'm not 100% sure of the formula, maybe it's poles X RPM, but i'm not certain.
I believe these are 8 pole motors.
johndjmix   10 W
Post by johndjmix » Nov 18 2012 4:16am
I ordered just the motor. Actually have 2 of them now....just installed one in a friends machine.
Power is nice and smooth, but you need to remember its a high-rpm motor....at low rpm it has no power compared to a Unite 1000 watt for example.
That said, for the money your much better with the Unite 1000 watt PM motors. Get a 48V and run it at 60. For $230 you can get a motor, and a controller. Been running them for years, and they are SOLID as a rock. But the unite PM weighs MUCH more than a brushless.
--John
