KMX trike build (updated pics)(new HD video)
migueralliart   10 kW
Post by migueralliart » Oct 02 2012 1:43pm
Yup it got to me ... as much as I tried holding back on this I HAD to order me a trike kit from utah trikes.
Took the hint from andrew.box and ordered a frame kit with double wall rims (20") on the front. I think it is better this way but I'll end up buying the brakes I want and components I want.
Bought a crystalite HS3540 from method's like 3 weeks ago on a 20" rim.
My plan is to run this thing @ 20S lipo or maybe 18S lipo still trying to figure out which one.
I bought the controller a while ago and it is being modified by amberwolf to handle more current and bigger phase and battery wires. Fets are going to be replaced too.
I'm working on a 24S a123 monster battery for this thing but in the meantime I would like to start with 3 6S bricks from hobbyking for easy hookup and testing.
My question is this;
do you think 3 of these in series might work well pulling 60-70 amps max from the battery
http://www.hobbyking.com/hobbyking/stor ... duct=21431
I'm not looking to break 50mph with this motor or anything but to have a constant 30mph with bursts of a bit more when needed. If I crave more speed I'll probably add another 6S brick for 88.8V but for now I think 3 will do.
Another thing I want is to be able to fast charge this thing.
Are these nanotech's really good for charging at 2-3C?
Any suggestions in terms of brake and other components I might need. I was thinking AVID BB7's on the front (200mm) with a dual pull lever. Hookworms in the back but have not settled on what tire to use for the fronts.
UPDATE Oct 6,2012
Well some updates and pictures as promised...
Prepping the HS3540 and front 20" rims
Front disc brakes and spindles attached plus tubes and tires
Frame is out of the box to be prepped for the torque arm installation using the DP420
Front left wheel installed
Both front wheels installed
Seat installed too
Added the freewheel to the HS3540, had to make a spacer out of a washer I had
Some bonus pics
The torque arm I left curing with a heat gun and a carton box @150F for about an hour. Thing is solid now :D
Still to do;
Install the front brake cables and adjust accordingly
Install crank and pedals
Install chain and rear derailleur with shifter
Lots and lots more....
UPDATE Oct 13,2012
It is running now .... not electric at the moment but everything else runs fine. I'm gonna tweak the brakes and add the shifter cable.
UPDATE Oct 17,2012
Installed the shifter for the rear derailleur. Bought an SRAM grip shifter and cut a wuxing handlebar grip. 7 speeds it is. Now I need to tension the rear chain a bit since it is a bit loose. It still shifts good but i'D like to tension it a bit.
Shifter and Brake
Installed a CA up front and used all the cable routing stops for the front derailleur that I won't have.
CA with a bit of clearance on the right
Left clearance
Now onto the throttle ... I bought a throttle from an user here on ES a while ago. Now I got it installed YPEDAL's style. Definitely the best way to install a throttle on these KMX trikes.
UPDATE Nov 17,2012
Well as promised here is all the updated pics of what I think is my new commuter in combination with my idrive. Enjoy!
And RIDE STATS
NO REGEN
LOTS OF START AND GO PULLS
NO PEDALLING
UPDATE Dec 5,2012
Update now with videos
No editing at all , no music. 808 v2 #16 camera mounted on giro remedy cam
The next one will have a cool intro and music.
Ypedal   100 GW
Re: KMX trike build
Post by Ypedal » Oct 02 2012 1:56pm
I put hookworms on the front and Vee-Rubber on the back.. nice and rubbery ride..
i " had " a hookworm on the back :D
http://www.youtube.com/watch?v=AJnPxF9h ... ature=plcp
ES site status page:
kriskros   10 kW
Re: KMX trike build
Post by kriskros » Oct 02 2012 3:36pm
ask dr bass...he has an excellent kmx build :mrgreen:
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 02 2012 3:54pm
I'm more doubtful about the nano techs for this configuration..
Ypedal;
I'll search around for those tires :D thanks for the recommendation. I liked your documented build on your webpage... very detailed. Do you think there is space for a 8 speed freewheel in the back?
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 05 2012 9:29pm
Well big shipment arrived today...
I just can't figure this UPS guy. He never leaves small packages at my door and leaves a note for me to pick em up at the club house. Today thou he left more than 1500$ worth of things just sitting there. To make things worse I live on a 3rd story.
Anyway my frame kit arrived and this is gonna be a really busy weekend.
Ordered 3 Maxxis hookworms and avid 2012 200mm mec disc brakes. Also some avenir thorn resistant tubes, rim tape and a dual pull lever.
Now some pictures.
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 05 2012 9:34pm
and the hookworms
Planky   10 W
Re: KMX trike build
Post by Planky » Oct 06 2012 11:06am
subscribed! :mrgreen:
ohzee   1 MW
Re: KMX trike build
Post by ohzee » Oct 06 2012 3:49pm
yea looking good.. I plan on doing this same thing next year.. I really want a velo tho or at the minimum something to break the wind.
mind sharing how much you saved just getting the frame like that ? never thought about that option.
cant wait to see more even open box's
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 06 2012 4:45pm
ohzee wrote:yea looking good.. I plan on doing this same thing next year.. I really want a velo tho or at the minimum something to break the wind.
Frame kit is 850$ plus 49$ shipping with double wall front rims
Bought an hs3540 from methods when it was on sale for 200$
Avid bb7's ~150$
Im getting close to 1.3k and im still shopping for lipo and a CA.
My suggestion is go for the frame kit if you want GOOD components. I just hate to buy bundled things it seems you waste a lot of money that way.
Took some pics im waiting on the dp420 to cure in the diy box oven lol
Man those hookworms are hard to put on!!!
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 06 2012 8:16pm
Seat installed too
Some bonus pics
Still to do;
Ypedal   100 GW
Re: KMX trike build
Post by Ypedal » Oct 07 2012 8:44am
have fun with the chain tubes :lol: .. an extra pair of hands come in handy.. refer to my review thread if you need help figuring them out, top bottom , forward back ..
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 07 2012 11:16am
Ypedal wrote:have fun with the chain tubes :lol: .. an extra pair of hands come in handy.. refer to my review thread if you need help figuring them out, top bottom , forward back ..
Btw I still need to buy a bottom bracket and crank.
Ypedal
Do you know what type of BB it is and the width?
What chainring did u end up going and arms length?
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 13 2012 9:17pm
andrew.box   100 W
Re: KMX trike build
Post by andrew.box » Oct 13 2012 10:58pm
The white frame looks awesome, didn't notice that was an option when I ordered mine. I can't wait to hear how it performs once it's finished. Looking good so far!
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 13 2012 11:09pm
andrew.box wrote:The white frame looks awesome, didn't notice that was an option when I ordered mine. I can't wait to hear how it performs once it's finished. Looking good so far!
Hey thanks man!!!
Btw your suggestions were BIG help everything was perfect. Now i'm trying to figure how to setup the shifter and what to put in the levers. There might be a problem with the derailleur being to long i think i might have to change it for a short cage but we will see.
amberwolf   100 GW
Re: KMX trike build
Post by amberwolf » Oct 14 2012 1:50am
Will be playing with the various pads on the controller to see what they all do (regen/etc), and install a CA connector and verify the one I have will work with this controller, which means yours should work the same.
After I get all the small-scale connections figured out I'll pull the FETs, beef up the power traces, and install the new FETs, install the new phase/power wires, then retest everything.
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 14 2012 12:20pm
amberwolf wrote:Will be playing with the various pads on the controller to see what they all do (regen/etc), and install a CA connector and verify the one I have will work with this controller, which means yours should work the same.
Good to knoW! centainly no rush .. I need to purchase a 6/9 fet infineon controller to test it but it will be later used in the other bike I have. That other bike is currently running on a sensorless aotema controller and it is not working well with the geared hub I have on that bike.
Kirk   100 W
Re: KMX trike build
Post by Kirk » Oct 14 2012 1:02pm
I like the entry level price on the KMX Karts but the lack of decent steering on them can be a problem in high speed cornering. They tend to scrub too much in the corners.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
andrew.box   100 W
Re: KMX trike build
Post by andrew.box » Oct 15 2012 10:26am
How does the cattrike steering differ? I've never had the chance to ride one. They're supposed to be really nice.
ohzee   1 MW
Re: KMX trike build
Post by ohzee » Oct 15 2012 10:28am
Also what does scrub in the corners mean ? sorry not familiar with it and curious. I plan on getting one of these at some point , but not set on a make/model.
amberwolf   100 GW
Re: KMX trike build
Post by amberwolf » Oct 15 2012 3:35pm
On a bike, the front wheel guides the turn and the rear wheel follwos. On a trike or quad, one wheel of a steering pair will guide the turn and the other will be dragged along a different curve than it would naturally go in, and the non-steering pair will follow, again with the wheel out of line being dragged into line. That's an oversimplification, but should be easy enough to picture.
With different mechanicals to the steering, suspension, etc, then this behaves differently, with more or less scrub (drag of tires on road) in some than others.
ohzee   1 MW
Re: KMX trike build
Post by ohzee » Oct 15 2012 3:40pm
Thanks Amber never actually thought about that.. thanks for the explanation.
Yea makes sense.. do people who make products give specs on that value or is it something they try to omit ?
amberwolf   100 GW
Re: KMX trike build
Post by amberwolf » Oct 15 2012 3:55pm
I don't know that most poeple care--the main issue is wear on tires and loss of speed in the turn, and possibly stickiness to the pavement causing you to flip in an extreme turn (but that could happen anyway).
I haven't seen specs on it at all. i don't knwo that there is a system of measurement in place for it, even.
migueralliart   10 kW
Re: KMX trike build
Post by migueralliart » Oct 15 2012 6:09pm
From driving this thing around all I can say is the steering takes some time to get used to. It is totally true that when hard cornering even at low speeds you can turn over. I will definitely take my time to learn how to control this thing.
andrew.box   100 W
Re: KMX trike build
Post by andrew.box » Oct 15 2012 6:27pm
It gets better, I felt the same way at first but now I feel very comfortable with the steering. Don't forget to check the amount of toe-in. When I had mine set with too much, it handled weird, was less efficient and wore out my tires.
