cbr shadow
I've been having problems w/ my controller, reasons which I wont bore you with but I recently received it back from Lyen. I hooked it up today with 60v nominal and was able to ride around, but it felt very very underpowered. On very flat ground I could start to pick up a little bit of speed VERY slowly, but as soon as I would hit any type of hill I would have to pedal to keep going forward, and it had a hard time even getting up my driveway without having momentum going into it. What could the problem be? One thing I noticed is that it's letting out a bit of a grunt when going really slow as it gets started. If I lift the rear tire (no load) and give a tiny bit of throttle, it will grunt/shutter as it starts spinning then pick up speed.
I would think that with 60v and a 20" wheel I would have plenty of torque, but it's seriously lacking. Any ideas? Lyen sent me a video of himself using my controller on a 48v setup and seemed to be cruising around just fine. Below is a list of what I have:
KMX Trike
HS3540 in 20" rear wheel
Lyen 18FET controller
60v nominal Lipo
CA
I should note that I had this exact setup going about 5 weeks ago with 100v and it had really nice torque. I was able to take on ANY hill.. then I believe I overheated the controller by pushing it too hard. Now I'm not even sure what to check!
Thanks,
Ryan
KMX Trike
60v nominal Lipo
CA
Thanks,
Ryan
