2000w rated hub motor
PeeHell   100 W
Post by PeeHell » Jan 03 2013 5:33pm
I've been recently seeking for an ebike hub motor that has a great quality/price ratio. The best I've found is this one :
http://www.poltm.com/en/product_detail. ... d=122&fid=
I decided to order it since the specs and price were looking great. I received the motor and let me tell you it looks very similar to the "large diameter cromotor" : http://endless-sphere.com/forums/viewto ... ge#p530502
Here are the specs from the manufacturer :
Stator diameter: 266mm
Stator width (magnets): 24mm
Kv: 9.3rpm/v
Net weight: 8.95kg
Rated power: 2000w
Phase wire gauge: 4mm² (~11awg)
Dropout: 145mm
Max claimed efficiency:84.8%
Taken from the document with test graph and data:
Disk brake screw holes:
Nice overall paint quality :
The only issue I've spotted so far : a "cone" instead of the freewheel adaptor...
A closer look :
Nice stock phase wire size ; less mod to do :
This motor looks promising thus far. I'd like to hear opinions about it from you guys as well as a possible solution for the freewheel issue. Any comment are welcomed.
Pierre-Luc
neptronix   100 GW
Re: 2000w rated hub motor
Post by neptronix » Jan 03 2013 7:02pm
That does look just like the motor i like to call the "deep dish" cromotor. :mrgreen: dimensions being +/- 1mm.
Might even be that a magic pie side cover bolts right on to that weird tapered side.
Can you get us a pic of the interior?
This is what the magic pie stator looks like.
PeeHell   100 W
Post by PeeHell » Jan 03 2013 10:18pm
That is my next move when I'll have time. Great idea to try the magic pie cover swap. I have a magic pie in the garage ; it's worth having a look at that procedure.
flathill   100 kW
Post by flathill » Jan 04 2013 3:11am
$235 shipped from china is a hot deal
Was that by air by chance?
Great find man!
POLTM is working witch fcuking Bosch on magnesium hub motors
Yes the germans
The future is looking bright for wheel motors
Maybe the cone shaped side cover allows for a stronger side cover (1 piece maybe
Maybe some sort of taper lock
And the design may allow the freewheel to slip before you break it
I've broke two side covers in a week a few years ago stomping on the pedals in high gear
PeeHell   100 W
Post by PeeHell » Jan 04 2013 5:10pm
The shipping was from DHL and I received within 5 days ! I'm still looking for a freewheel solution. Maybe I could glue a freewheel with 3M DP420 epoxy. Will see...
docnjoj   100 GW
Post by docnjoj » Jan 04 2013 5:18pm
Any chance that cone thing unscrews leaving standard freewheel threads?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
neptronix   100 GW
Post by neptronix » Jan 04 2013 5:21pm
When you gonna open that badboy up? :mrgreen:
Is the dropout spacing 150mm, btw?
flathill   100 kW
Post by flathill » Jan 04 2013 7:23pm
What motor did you order? On the polaris website when I click through to and see the motor it shows 266 series, but when I search 266 series polaris on google I get a different motor:
http://www.poltm.com/en/product_detail. ... id=22&fid=
Did they have no problem with you buying just one?
It would be a shame if this was made for a moped and you can't easily mount a freewheel. Have you tried contacting polaris?
Thanks!
Does anyone have a link to the chinese language version of the polaris webpage?
Anyone speak Russian? The Russian ebike forums seems to have many users of polaris hub motors...
I love how they list all the specs for the most part
going so far as to list the steel hardness
1、Casing : 20 # steel
2、Magnet material: NdFeB
3、Enameled wire: QZ-2/130
4、Iron core: DW600
5、Shaft:40Cr/Q.T.: HRC22-28 Side outlet
6、Cable:3*1.5mm²+5*0.2mm²/Max.Tmp.:180˚C
It looks like the windings are only rated to 130C :(
while the phase wires are rated to 180C
How thick are DW600 laminations?
PeeHell   100 W
Post by PeeHell » Jan 05 2013 3:44am
I copied the link in my first post.
I'll probably open it next weekend.
I've seen the other 266 motor before and I went with the all-black cover one because of the superior weight (probably because of a thicker stator).
I cannot unscrew the "cone" thing ; it's embedded in the side cover.
Chalo   100 GW
Post by Chalo » Jan 05 2013 4:09am
How do you expect to tighten the disc side axle nut without destroying the dropout, the axle face, or both?
Staton Inc. made a similar design mistake with their in-house RH/LH threaded hub.
dogman dan   100 GW
Post by dogman dan » Jan 05 2013 7:59am
Good eyes Chalo. I didn't notice that. Not much axle shoulder there. I can't tell from the pic if there is a shoulder further in, allowing the use of a spacer.
No big deal though, if you would, and you should be, using a pinch dropout torque plate on that side. Assuming of course that you'd be running this thing at at least 2x the rated 2000w. 8)
neptronix   100 GW
Post by neptronix » Jan 05 2013 9:24am
Chalo wrote:How do you expect to tighten the disc side axle nut without destroying the dropout, the axle face, or both?
Solution: 100% tight fit custom washer :cry:
I didn't notice that..
knighty   10 kW
Post by knighty » Jan 05 2013 5:44pm
your spec above says 2kw... but the page you link to says 1kw ?
PeeHell   100 W
Post by PeeHell » Jan 05 2013 10:26pm
The test data sheet I received indicates 2000w rated power. Chinese vendors often don't write the same information correctly...
neptronix   100 GW
Post by neptronix » Jan 05 2013 10:34pm
Continuous wattage will vary with the voltage they are thinking of at any given time in the spec sheet :lol:
I can see how this motor would do 2000w continuous all day long in a smaller wheel like a 24" or 20". My magic pie could do about 1250W-1500W continuous all day in a 20" wheel, and that was with a narrower stator that had far more end turn loss and less efficiency than this as a result.
The stator on this baby is about 20-25% wider than on the magic pie, and the spec sheet indicates peak efficiency is maybe 3-4% higher, so 2000W continuous doesn't seem like a stretch. Lace this thing up to a 24" ( 20" might be difficult/impossible :lol: ) and let it rip!
PeeHell   100 W
Post by PeeHell » Jan 05 2013 11:04pm
24" wheel running at 24s lipo is the plan, maybe 20s will see. I'll go slowly with this project
neptronix   100 GW
Post by neptronix » Jan 29 2013 4:43pm
Shameless thread bump..
Have you gotten anywhere with this?
PeeHell   100 W
Post by PeeHell » Jan 29 2013 5:04pm
Haven't had time yet. Just starting to figure out how to install at least a one gear freewheel on this motor. Not that easy...
briangv99   100 W
Post by briangv99 » Feb 04 2013 6:24am
Does the cone appear to be solid, or is it just a thin wall casting? Might be some option to machine down the cone and cut a thread, or press on a threaded insert
PeeHell   100 W
Post by PeeHell » Feb 04 2013 11:03am
I think this is exactly what the greyborg team has done. I will probably go this way. Really looking forward to see this thing in action ; I think it will match the performance of the new expensive Crystalyte "The Crown".
MadRhino   100 GW
Post by MadRhino » Feb 05 2013 11:00am
Interesting motor.
I hope to see you riding it in the Mount Royal next summer :D
What frame are you building on ?
I doubt that it will be close to the new Clyte in performance, for it looks like it has less than half the copper.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
gensem   100 kW
Post by gensem » Feb 05 2013 11:53am
Ultimate solution would be a motor that wide but with 50mm magnets and deep slots filled with copper. :)
Justin we really appreciate what you did!
MadRhino   100 GW
Post by MadRhino » Feb 05 2013 11:56am
gensem wrote:Ultimate solution would be a motor that wide but with 50mm magnets and deep slots filled with copper. :)
:twisted:
Current bikes
Street:
Dirt:
neptronix   100 GW
Post by neptronix » Feb 05 2013 1:06pm
Ah yes but you have no idea how powerful a tallboy can be. My magic pie was insane. And it could shed an incredible amount of heat thanks to it's tallness. This is more efficient and has ~20-25% more magnet than my magic pie.
I can't wait until you show us the guts and/or actually get it running.
PeeHell   100 W
Post by PeeHell » Feb 05 2013 1:10pm
I was going to reply the same as neptronix. I currently own a magic pie too and I think that a large diameter is the way to go. It's like "bonus torque" because simple physics principles gives you the extra torque.
I don't think this will outperform "The Crown", but for 1/3 of the price, it'll be the best price/performance motor for sure.
I'm currently planning to mount this motor on my Tidal Force S750, but I'm having a hard time fitting 24x 4s 5000mah hardcase on the frame....
