If you figure it out, let us know how it works. I'd love to put a springer on my trike, but I have no Idea if it could handle the torque of a hub motor. I need to see one in the flesh, instead of a picture. As for fitting the bike frame, one of the major issues is the diameter of the steer tube. A lot of bikes use 1 1/8 " but some are only 1" . The big tube will not fit in the hole on the frame if it takes the small one. So the starting point is to find out what size steer tube your bike has. After that from what I can see in pictures, the springer fork steer tube is either adjustable, or cut down to fit the lenght you need on the steer tube. Just my luck, my trike is the one inch tube and most of em I see are for the big tube.
