sacko said:There's a sheet of info in the email Lyen sent?
Expecting people to reply to an email/phonecall on a Sunday is wishful thinking from anybody, its a day of rest! If you don't get a reply, just wait until the following day.
On the email, it shows and gives a definition of each configuration setting. Stating what it does and what you can change it to.
This any good to you?
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=14807
ambroseliao said:Just Google, "lyen controller parameters site:endless-sphere.com" and click on Images. You'll find lots of samples. You'll need to know what board/chipset you have.
https://www.google.com/search?q=lyen+controller+parameters+site:endless-sphere.com&safe=off&source=lnms&tbm=isch&sa=X&ei=kud-UYmbOYvY9ATnuICIDQ&ved=0CAoQ_AUoAQ&biw=1400&bih=888
Click on any image that looks like your screen and then click the "Visit Page" link. There's no substitute for reading to learn more instead of calling for help from a one man shop who works late and who does this in his spare time.
I have never had any problems with Lyens controllers being mis-set and they have performed flawlessly for me. He's also a great repairman. He once fixed a Crystalyte controller for me that he didn't sell!
I wouldn't blame your bike's sitting unused on Lyen. There are many other vendors of controllers out there with full time staffs and who do respond to emails and phone calls quickly. Ah-hem, http://ebikes.ca to name one!
Ykick said:Mistakes happen and the fact it took 2 years to figure out the problem doesn't help. Why not you send the controller back and have him to reprogram it as originally desired? That wouldn't cost what the cable and the subsequent frustration has cost.
Throwing a tantrum and "blaming" somebody for a bike sitting in YOUR living room is quite a stretch. Good iggy list material though, thanks...
sacko said:What about the link to the download in the email?
I have never done it before, and following the instructions I have installed the drivers and the software in under 5 minutes. I'm just awaiting my 12fet from Lyen so I can test it, should be here soon though.
The codes etc were in the link I posted earlier.
I wouldn't expect Lyen to post a 'default' setting for a 48v setup as there are so many variable parameters; direct drive motor, geared motor, lipo, LiFe, LiCo, NiMh and so on.
There is also a vast amount of screenshots on Google Images.
sunnyday said:here is the serial # on my Lyen controller
EC- 124110LD
does this help ?
EC- 124110LD
does this help ?
ambroseliao said:sunnyday said:here is the serial # on my Lyen controller
EC- 124110LD
does this help ?
You need to open your controller up and look at the PCB. I believe it's printed on the board.
sacko said:sunnyday said:here is the serial # on my Lyen controller
EC- 124110LD
does this help ?
From the instructions
"Board Type
This is to select the controller board you have:
a) EB206 = 6 FET controller board
b) EB209 = 9 FET controller board
c) EB212 = 12 FET controller board
d) EB218 = 18 FET controller board
e) EB224 = 24 FET controller board"
sunnyday said:sacko said:What about the link to the download in the email?
heres my serial number
EC- 124110LD
i have a 48 volt lifepo4 - 20A/h battery
1000 watt brushless rear hub motor / direct drive.
I want to keep all the numbers currently programmed in my controller, the same, except for the LVC ....
sunnyday said:is this the correct photo ?
https://www.google.com/search?q=lyen+controller+parameters+site:endless-sphere.com&safe=off&source=lnms&tbm=isch&sa=X&ei=kud-UYmbOYvY9ATnuICIDQ&ved=0CAoQ_AUoAQ&biw=1400&bih=888#imgrc=jGme1DHAbzJNTM%3A%3BHU2_ZGb9bKWpcM%3Bhttp%253A%252F%252Fi256.photobucket.com%252Falbums%252Fhh184%252Fmrefex%252FMrKang%252520E-Scooter%252FParametersLYEN12FET.jpg%3Bhttp%253A%252F%252Fendless-sphere.com%252Fforums%252Fviewtopic.php%253Ff%253D10%2526t%253D13442%2526start%253D75%3B783%3B478
and if so, what window is for the LVC that I need to change to 40 volts ?
chroot said:@sunnyday - Howdy, I know Edward Lyen personally, and He is extremely busy lately. Recently, He mentioned he was in jury duty and let me get hold of him to have him get in touch with you shortly. 8)
sunnyday said:chroot said:@sunnyday - Howdy, I know Edward Lyen personally, and He is extremely busy lately. Recently, He mentioned he was in jury duty and let me get hold of him to have him get in touch with you shortly. 8)
I appreciate it...but at this point in time...Id be happy if anyone on this forum could help me instead.
