zombiess
I don't know why I haven't ever experimented with this feature before after all this time, but finally decided to a few days ago. I love the way the bike rides with it engaged. I usually have my regen set at level 1 and with slip charge engaged it provided a nice smooth drag slowing me down that increases as I let off the throttle. All the way off the throttle = almost full regen. Pressing my regen button gives an even stronger regen brake than the slip charge mode. I think I've really been missing out by not using this. It's also appears to be proportional to speed, higher speed = more force, lower speed = less.
Try it out if you haven't yet, as long as you aren't close to maxing out your controller amp wise as it will produce some extra heat due to regen. I used it during hard core stress testing my controllers and all was fine at the 100A level on an 18 FET IRFB4115 and not noticeable on a 24 FET IRFB4115 controller.
