It's only been over 2 years since I first started trying to restore this bike
, but I never fully gave up, and my persistence is looking like it might finally pay off!
I finally found a bottom bracket that was able to fit.
http://www.sickbikeparts.com/catalo...ucts_id=214&osCsid=353qqo9frlc06sr8jl1ohbgvh3
The adjustable nature of the bearing/cup in this bottom bracket is what made it possible to get this to work. Since it does not have a fixed cup width on one side and the bearing is held inside the cup, this bottom bracket axle can fit any size shell from 83-110mm wide...just what I needed.
The only problem I found with it, was the threading on the cups did not seem to match up properly to my shell. I tried for hours to get it both sides to thread on, but could not. One side was able to thread so in the end I used it. I managed to destroy the other cup trying to replace it's bearing after I tried removing it to put in a different cup unsuccessfully. So on that side I ended up using a standard cup that would thread on properly, but with a slightly smaller bearing which I jammed into place with some cloth. It's not a perfect fit around the axle (2mm too big) and not held into place inside the cup like the original. I realize it might not hold, but for now with all the standing on the pedals I have managed it hasn't moved at all...so fingers crossed. If it does fail, I will get a replacement cup from SickBikeParts and probably hammer it into place in the shell with some epoxy to hold it. It doesn't matter how it's held in...once it's in there, as long as it stay's in place...I never plan to remove it.
Anyway, I'll let the images show how it looks.
I also had a go at fitting the HS4080 from my Stealth Fighter which has caused me never ending problems with stripped axle threads. I recently used an M12 die to cut it's threads from 1/2" UNF down to a very close thread pitch in M12. This worked great, and it just so happens to match the M12 of the previous geared motor that was on this bike perfectly, although the horizontal dropout's are 10mm flats like any, so it wouldn't matter if the motor axle was M14 either.
The axle shoulders also happen to fit perfectly. I couldn't have asked for a more perfect fit...and I wasn't even trying to make it fit.
It might look a bit wacky with the 24" wheel in the rear, but I quite like how it looks TBH. The 3" tire more than makes up for the smaller wheel size, and just manages to fit the frame.
The weight feels a bit ridiculous compared to the crappy geared hub motor it replaced, but once powered I'm sure I won't care any more.
I need to figure something out with the brakes though. The previous motor had a screw on drum brake...which is obviously not going to work with this motor. There is a single mount on the disc side that might work, but I'm not sure. I might just end up relying on Regen only for the rear...we'll see.
I also pulled apart it's old battery, confirming in the process it's date of origin...2010, which is about what I suspected.
These are 22650 cells which I didn't even realize was a size till I saw these. It's a 10S5P setup, so with these 2050mah (original capacity) cells that's a theoretical ~380Wh...back when it was new.
I individually tested all cells, and found most were around 4V. I recently charged it after it had been sitting for over a year uncharged.
One parallel group of 5 is down at just over 3V and another group has reversed polarity and is at -1.6V. I am a bit confused about the reversed polarity cells as I didn't think that could happen to LiPo cells, but don't actually know the exact chemistry of these cells, just that they are 3.7V nominal.
I think I will dismantle this pack and hang onto the good cells. No idea what they could be useful for, but I'm not one to throw out perfectly good cells.
So from here I plan to see what I can fit inside the existing battery container. I'm hoping I can cram in a bunch of 6S Zippy Compacts I've been using on my other bikes. They are at over 200 cycles now, so ready to be downcycled and have a less dramatic life at lower amps...although I'm not so sure this bike will really be that much lower amps.
I plan to re-use my old 18Fet Infineon controller I used to have mounted to my Fighter. It's got an annoying intermittent issue with detecting hall sensors that I've never been able to fix, but I lived with it for a long time on the Fighter, so I plan to do the same on this bike if I can.
I also plan to crack open the old motor to see if it's at all salvageable. I'm pretty sure it's just got stripped planetary gear teeth, as it was still pulling last time I used it, but as soon as I loaded it, it would make a sound like slipping teeth and stop pulling. I'm not sure if it will be worth it to buy replacement gears or not...depends on the cost and certainty of a good fit I think.
Sorry for the epic post...I'm just exited to finally be getting this old thing back up and running again.
Cheers
