Near fail experience, Dropouts
samoloh   10 W
Post by samoloh » Sep 11 2013 7:51pm
I would usually lift my rear wheel the ground and do full throttle just for fun, I was doing the same thing today when as soon as i started i heard grinding sounds, i thot i had damaged my motor, but on closer examination I found my axle was on the verge of spinning out :shock:
I recalled that the previous day i did some light trail riding (nothing rough), might have hit a few bumps here and there, but then i realized i hadn't for once re-tightened my nuts since i started riding, buts its been only a week anyway. The max power i've ever draw is about 800+ watts. Do I just need to check my nuts more often or get a torque arm?
30mph Rebook 26" Hardtail, 9C hub motor, 48v 10Ah Lifepo4 12Fet Lyen controller
chrashing   100 mW
Re: Near fail experience, Dropouts
Post by chrashing » Sep 11 2013 7:54pm
Glad you caught that, thanks for the heads up. Will check mine.
amberwolf   100 GW
Post by amberwolf » Sep 11 2013 8:10pm
i'd use torque arms regardless, just to help protect the wheel from falling out if hte dropouts did fail...and also to keep the dropouts from having to do a job they're not usually designed for in the first place. ;)
but to keep the nuts tight, you can get Nord Lock washers--there's some in the for sale section now, I think.
captain387   100 W
Post by captain387 » Sep 11 2013 8:13pm
Torque arms, with Nord lock washers are a must.
04 Norco Atomik - Cycle Analyst - Hs3540 - 40amp Infineon Controller- 12s2p 10 Ah Turnigy/Multistar Lipo
pdf   10 kW
Post by pdf » Sep 11 2013 8:18pm
Torque arms, for sure. You can't get the axle nuts tight enough. I have found that axles that fit tightly in the dropouts (that is, larger axles) tend to spin out less easily than smaller diameter axles, but when the dropouts are spread a little, you are sure to spin the axle if you don't add a torque arm.
Jamis Commuter 1.0/Xtracycle Stokemonkey 36V LiFePO4, 15 ahr
Giant Boulder 9C 8x8, 48v, 10 Ahr LiMn from ebikes.ca
Drunkskunk   100 GW
Post by Drunkskunk » Sep 11 2013 9:49pm
This is a great example of why you need protection all the time. You were riding her nice and easy, not putting your weight on her at all, but you unexpectedly lost tension on your nuts. Lucky for you, it just fell out of her slot before any damage was done, but that could have been the kind of accident that ruins things forever.
Oh, wait. We're talking about bikes. Eh, same thing. Use protection, and double up if you can.
This reply was brought to you by Trojan brand Torque arms. Riged for her pleasure.
d8veh   100 GW
Post by d8veh » Sep 12 2013 3:30am
It looks to me like your installation could be improved. Normally the anti-rotation washers go on the inside of the drop-out and the plain washer on the outside. For most people that's not important, but in your photo it looks like you have a dimple around the drop-out. The large anti-rotation washer will be off-centre to the dimple o t'll sit crooked and work loose in operation. If you have a dimple, the first washer must sit completely within it, which means either you have to file the drop-outs deeper to re-centralise the axle, or file the washer eccentric. I normally file the drop-outs so that the anti-rotation washer can do its job instead of sitting out in the air.
dogman dan   100 GW
Post by dogman dan » Sep 12 2013 7:07am
No, it's the lack of torque plates. You might have to make some custom ones for that bike.
GCinDC   10 GW
Post by GCinDC » Sep 12 2013 7:15am
go to ebikes.ca and scroll all the way down to the section: Rear Torque Arms...
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
