josaphine30
Hi.
I thought I had decided on a 500w direct drive kit from Em3ev along with the 50V Samsung battery from them. But I started looking at the Mac motor and Ping batteries, which means I have a lot more questions.
Firstly. How does the Mac motor compare to the Direct Drive one in terms of reliability. I have heard that gearless motors are more reliable. I wouldn't want to choose the more powerful motor but have it break.
Secondly. Is there a noticeable difference between the two motors in terms of top speed and torque. Top speed is more important than torque but I would be interested to know which one has more.
My final question is about the battery I would like to use. It's the 48V 10Ah LiFePO4 from PingBatteries. I need to know, would this battery work okay with the Mac motor?
Em3ev recommend the 9Fet 30A (36-75v) controller for use with the 320rpm 8T motor (the one I would get as it would reach the speed I want, 30mph). I don't want to get a controller that would damage or shorten the life of the battery.
Here are the specifications of the Battery
Specifications:
Suitable Wattage of Motor: up to 550 Watt, 450 Watt suggested
Applications: E-Bike, Electric Bike, E-Scooter, Electric Scooter
Voltage: 48 Volts
Capacity: 10 Amp Hours
Dimension: 200x105x150 mm / 7.9x4.1x5.9 inches
Weight: 4.90 kg / 10.8 lbs
Charging Voltage: 60-61 Volts
Charging Current: <5 Amps
Rated Discharging Amperage: 10 Amps
Max Continuous Discharging Amperage: 20 Amps
Maximum Discharging Current: 40 Amps
Discharging Cut-off Protection: 30 Amps
Lifecycle of the whole pack: >85% capacity after 1000 cycles. Lifecycle of single cell: >85% capacity after 1500 cycles, >70% capacity after 3000 cycles. (<1C discharge rate and <1C charge rate)
Thanks
Specifications:
Voltage: 48 Volts
Thanks
