Hi, I'm new posting, but before posting I've already did a lot of research in this forum, thanks all.
After all the research I think I've founded the perfect kit for me, below you have all the components just in case someone want's to copy them.
But is not perfect and I'm a bit struggled with an ordered shipment to bmsbattery, so far the customer experience is more or less ok, but now after choosing everything, they tell me that is not possible to have a 328rpm motor for a 26" wheel so I'm trying to find the best alternative.
Purpose of the e-mtb:
Go quickly to work with not so many hills with a max speed of 25mph (40km/h) and go to the country with some hills. In the country I won't go all the time with motor so I need something not very heavy and also the motor without resistence. I prioritice go working (every day) than going to the country (w-ends)
The options I've check are:
a) Changing to a direct drive motor (Pros: Quicker going to work, cons:Heavy and resistance if it's off)
b) Changing the order to a 36v 500W 201rpm (That means overvolt and not sure if this is quicker than 48v 500 201rpm, Bmsbattery told me that the speed is the same, wierd :? )
c) Stay with the 48V 500W 201rpm (Cons: Bmsbattery told me to have just 19mph or 30km/h)
d) Buying a 328rpm motor without wheel and order it in a local shop (maybe expensive, or motor uneficient)
e) Changing the whole order to another supplier (more expensive)
What would you guys recommend? and why?
My perfect world is around 25mph (40km/h) cheap geared motor I think, to much?
Here there is a interesting post talking about rpms
The components are:
Any other advice regarding the components?
Update:
I missed the speed sensor in the front wheel, a magnetic reed to use my hydraulic disk brakes and finally I neither used the spare disk brake nor the levers.
I changed the BMP freewheel motor with a CST cassette one so I could have to gears and more traction/speed.
And the Half Twist Throttle - Without a Button
The fan charger is very noisy, I should have been bought a better one without fan at least.
After 1,200 km the gears from the motor broke, I should have been bought spare gears for 19$ the 3 of them.
Thanks in advance and hope this post is interesting for the community.
The components are:
- Bafang BPM 48V500W Rear Driving RPM : 328 *Not available for 26" wheels (And maybe unecificient)
- 48v 10ah hight C rate * I know pings batteries are the best, but ordering from 2 diferent places is expensive for me.
- S12S controller * It's some kind of simulator, will see.
- S-LCD1 display * Not 100% sure if this will give me the battery discharge status.
- Disk brake * I think is compatible with the motor and the shimano gears below.
- 14-28 Teeth Freewheel 7 speed
- Half Twist Throttle - With a Button * Thinking about conecting that button to turn on/off the electric bike (to avoid problems with cops in special situations)
- Brake Grip * Not sure if I'll need it, but is inexpensive.
- A Pair of EBike Torque Arm - Size : M12
- Eight poles PAS * Not sure if I'll need it, but is inexpensive.
Total: 579 USD + 224 USD shippement = 803 USD
Update:
