Just got my ebike kit from yescomusa what battery?
Re: Just got my ebike kit from yescomusa what battery?
Get the 5S packs and run 15S. The stock controller handles it well.
Would this one work? Get 3-6 of these for 5-10AH
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Those will work. Get 6 for 10ah.
What charger would I use
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
No, buy from the USA warehouse if you are in the US.
http://www.hobbyking.com/hobbyking/stor ... duct=15008
Use any 6s charger.with a 6x charge cable and a 6x 5s parallel balance cable
Do I use one of these to connect to the charger and the six batteries?
http://www.hobbyking.com/hobbyking/stor ... T_XH_.html
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Evolutiongts, what battery are you using right now?
Li-ion 48v 15AH
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
what site you bought from? bmsbattery.com?evolutiongts wrote:Li-ion 48v 15AH
Yes, but you also need a 6x charge cable like this.evolutiongts wrote:Do I use one of these to connect to the charger and the six batteries?
http://www.progressiverc.com/parallel-6 ... cable.html
You may find it cheaper someplace else.
http://www.buddyrc.com/parallel-charge- ... or-x6.html
Thanks also my controller says the max current is 26A+1
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Can I just add some solder to the shunt and raise up amp draw that way? I know my li-ion batt is rated for 30A continuous and 40A peak.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Like this but only do 1/3rd of the way to be safe.
http://endless-sphere.com/forums/viewto ... =2&t=31643
I added a tiny bit of electronic solder, it may have sped it up a little bit, but not too much difference. Should I use thick solder, or is the computer/electronic solder enough?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
I put some more solder acceleration is pretty fierce now especially with some pedaling, even without pedaling its not bad.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Will moving up to a 15s lipo battery improve performance or will I need a upgraded controller as well?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
You will not need a new controller to go to 15s. Both acceleration and top speed will increase going from 12s to 15s. A rough guess is top speed will be about 3-6 mph faster than 12s.
I just realized that the lipos use the 4mm bullet connectors but currently my li-ion bat and controller uses the anderson connector. Are there any adapters for the bullet and anderson connectors?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
It's wire and connectors. You can make anything you want easily or possibly buy them already made. You can search for them as good as me. Personally, I'd cut the PP connectors off and use 4mm bullets everywhere.
Just want to confirm if this charger will work with a 15s pack. http://www.hobbypartz.com/75p-1220-char ... PAod10MAPw
Or this http://www.all-battery.com/TenergyBatte ... 224-1.aspx
Also aside from a cycleanaylst, what can I use to monitor the volts on the lipo packs. My yescomusa kit comes with a LCD display with has a battery indicator.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
The 300W Thunder 1220 will charge up to a 12s pack in series. To charge a 15s pack, you need to parallel charge them as 5s. So yes, it will work. The other is just a 2A 126W bulk charger. It won't balance, but will charge the pack. Just slower and not as safe. And it's very expensive for what you get. You can get twice the power at that price easily.
http://www.bmsbattery.com/alloy-shell/2 ... arger.html
BTW, I don't recommend bulk charging rc lipo if you don't know what you're doing. It can be dangerous, and one should take precautions doing it.
Heres a clip of my bike running, I'm just looking for a bit more speed and range. Thats why I'm interested in the 15s lipos. Probably going to get the thunder charger, 5s lipo packs, power supply, wiring adapters/harness.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
I decided to hook up the PAS, any idea on how to install the sensor and magnet?
Im guessing the sensor goes in before the crank and the magnet is post crank?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
What is the easiest way to get my bike up to 40mph, and out accelerate cars I have about $500 budget to make this baby go fast.
What is a good 72v controller?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
