My Electra Cruiser project
psychonurse   10 W
electra 7d cruiser
Post by psychonurse » Dec 01 2013 9:37pm
Hi guys, wondering if anyone had converted this bike to electric. Specifically front hub conversion. Have opportunity to pick one up but not sure if front fork is steel or aluminum. Any input appreciated. Thanks Mike
chvidgov.bc.ca   10 kW
Re: electra 7d cruiser
Post by chvidgov.bc.ca » Dec 01 2013 9:47pm
I've got a Townie 7D with a front Crystalyte 406 on it. The fork is magnetic <steel>. The rest of the frame is nice light weight aluminum. The bike looks like a tank, in black, but is actually quite light. It moves along nice with the high speed c 406 on a 48V Headway pack. Good balance. I've got Fat Frank tires on mine which are perhaps a bit slippery in wet conditions. I've got the battery on a back rack. Pretty strait-forward conversion. The gearing as supplied could be a bit higher, but I am able to keep up with a fairly quick cadence, around 25mph.
dogman dan   100 GW
Post by dogman dan » Dec 02 2013 9:35am
Near perfect choice for a front hub.
psychonurse   10 W
Post by psychonurse » Dec 02 2013 12:16pm
Thanks so much for speedy replies. What do you think a used one should sell for in fairly good shape. Just the bike itself.
Post by chvidgov.bc.ca » Dec 02 2013 2:44pm
I paid 400 Cdn for mine, in like-new condition, with the Fat Franks on it which was a bonus...they are supremely comfortable tires, good on an unsuspended ebike. I had to add fenders. Had a rack. I used two torque arms (eyelet type from ebikes.ca).
psychonurse   10 W
Post by psychonurse » Dec 05 2013 12:15pm
Hi, well I'm happy to report i won the auction and am now proud owner of an electra cruiser. Paid $124 for it which I think was a great price. Would love to see some pictures of your conversion to give me some ideas. Thanks. /Users/annshadler/Desktop/IMG_0288.JPG
The fingers   100 GW
Post by The fingers » Dec 05 2013 5:17pm
Always liked those Electra bikes. Would buy one in a heartbeat. 8)
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
Samd   1.21 GW
1.21 GW
Post by Samd » Dec 05 2013 5:31pm
I'm thinking these would make a pretty good longtail conversion with a Xtracycle frame extension, the lower frame in front of the seat makign it easy to hop on and off with kids seated on the rear skate deck...
http://ballaratebikes.com/
psychonurse   10 W
Post by psychonurse » Dec 05 2013 8:22pm
Wondering how bad the ride will be with a front hub motor. My last ride was a Diamond Back with suspension forks and you did not want to hit a bump in the road or a raised sidewalk. The electra doesn't have any suspension fork at all. Can you buy a upgraded fork that would soften the blow a bit. ?
psychonurse   10 W
Post by psychonurse » Dec 05 2013 9:16pm
Just trying to post a picture have been unable so far.
psychonurse   10 W
Post by psychonurse » Dec 05 2013 9:17pm
It worked!! This is the first time I have been able to insert a picture.
psychonurse   10 W
Need a BMC or MAC front hub motor
Post by psychonurse » Dec 08 2013 2:12pm
Hi Guys, after doing some research I have come to the conclusion that a lightweight geared hub is the way to go for my second build. My first bike was an ampedbike front hub. The bike weighed about 80lbs and with my bad back not easy to lift on the bike rack on my car. I really like the idea of free wheeling when not using the battery. Can anyone guide me to the least expensive vendor to purchase a kit. The least expensive MAC kit I have found was around $800! Any suggestions appreciated.
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Re: Need a BMC or MAC front hub motor
Post by DAND214 » Dec 08 2013 2:37pm
dogman dan   100 GW
Post by dogman dan » Dec 08 2013 5:57pm
I thought a mac weighed close to the same as a 28mm dd motor such as the amped one. Might be a tad lighter, so your new bike will weigh 78 pounds. Not scoffing the motor, just saying it's not a flyweight motor like a 200w type. And even those weigh a bit, full of copper as they are.
A different rack could help, do you have a wheel hold rack or a hanger type? I found the swagman hitch rack easy, I can put bikes on mine one tire at a time, lifting only half the weight at a time.
spinningmagnets   100 GW
Post by spinningmagnets » Dec 08 2013 6:08pm
I'm going to estimate that the MAC can handle about 25% more watts than the Bafang-BPM, based on the wider stator/wider magnets/and greater copper fill. So...if you are set on a front geared hubmotor, my recommendation is the Bafang BPM, which costs less than the MAC/BMC.
When it comes to a rear geared hub motor, both the BMC and MAC are quality products that have performed well for many builders.
psychonurse   10 W
Post by psychonurse » Dec 09 2013 1:51am
Thanks for the replies. Very helpful. The em3ev looks like a really good site to check out. Prices seems very fair.
psychonurse   10 W
Need help ordering MAC kit
Post by psychonurse » Dec 09 2013 11:58pm
Hi guys, I was on www.em3ev.com site to order my MAC electric bike kit for my 26" electra beach cruiser.No disc brakes. I can put the kit together but have no clue which components to choose. If you go on the site and click on the 500/1000w Pick"n"mix kit. They have several options they ask you to choose. 1. controller type, 2.Wheel type 3.Motor speed. I want a front hub motor, one of the choices was 8T for motor speed. I had heard that might be a good choice? I plan to use either a 36v or 48v lithium battery. I don't mind spending for the better controller if neccessary. Would appreciate any help. Thanks in advance.
DAND214   1 GW
1 GW
Re: Need help ordering MAC kit
Post by DAND214 » Dec 10 2013 12:33am
I love my MACs.
If you are going to run 36 or 48v then you don't need the upgraded fets. I would buy the 9 or 12 ft controller. If me 12 fet.
I have 3 8t love em. I think you would love a 10t, they are fast with good torque and use less GAS.
Rim is similar to what is on the bike. Alex DM 19 or 24 depending on the width you have now. A wider rim will take a wider tire. You need the CNC version.
Throttle is up to you. if you have twist shifters you need a thumb, triggers a halftwist. When ordering it order a spare or two. the weakest piece in the kit all kits.
No shifters, I would go half twist or get one of each to see what you want. There cheap
FRONT hub needs torque arms especialy with a geared hub, Lost of bottom end power.
Is the fork steel or alloy? Does it have lawyer lips on the droputs? You will need some C washers.
Paul does a great battery too.
Dan
Ricky_nz   10 kW
Post by Ricky_nz » Dec 10 2013 12:36am
What do you want the top speed to be and do you have hills to climb.
For reference the 10T has good torque and does about 42Kph on 50V (26" wheel). The 8T will be faster
The information on the upgrade kit is applicable to both in most places
http://em3ev.com/store/index.php?route= ... uct_id=138
It gives the expected speeds and recommended controllers etc.
Latest Projects: High power vector controller for Turnigy 80-100.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Keewee Stealth dirt jump with MAC 10T rear gear hub
psychonurse   10 W
Post by psychonurse » Dec 10 2013 1:23am
Hi Dan, thanks so much for giving me that input. Extremely helpful for me. I would like to use the existing tires that are on the bike so how do I know what size rim to order? Yes, before I bought the bike I made sure the fork was steel. Not sure exactly what type of dropouts but will check tommorow. Do you know what the difference in feel or performance using a 8T motor v.s. 10T?
psychonurse   10 W
Post by psychonurse » Dec 10 2013 1:27am
Thanks Ricky. Sound like the 8t will suit me fine. Not a lot of hills in my area. Will check out the link about the controllers.
dogman dan   100 GW
Post by dogman dan » Dec 10 2013 9:37am
Do you plan to pedal along? If so, a beach cruiser may not be geared for the speed of an 8t on 48v. But an 8t on 48v will be a blast to ride not pedaling.
If you will do lots of starts and stops, then a 10t would do that on less wh/mi.
Regular 26" rim should fit a cruiser tire good enough.
What controller may depend on how much you plan to spend on a battery. The lower amps one will still get you going ok, and may allow buying a cheaper grade of battery.
psychonurse   10 W
Post by psychonurse » Dec 11 2013 12:06pm
Yes, I have lots of stops and starts. I currently have 36v 12A.H. battery. Would like get a controller that will allow me to upgrade to a 48v 12A.H. down the line. I like having more low end torque. Not really interested in going real fast. If the bike can get to a top speed of 25mph that would be sufficient for me. Especially since the bike doesn't have disk brakes. Thanks again for all the help.
teklektik   10 GW
Post by teklektik » Dec 11 2013 7:48pm
What size/brand tire is on your bike now?
What is the outside rim width of your current rim?
psychonurse   10 W
Post by psychonurse » Dec 11 2013 9:07pm
My tire size is 26x2.125
