How to disassemble currie throttle?
yoyoman   1 kW
Post by yoyoman » Jan 30 2014 4:20am
Has anyone ever taken apart a Currie throttle from a USPD or similar bike? The throttle lever looks like it turns the pot. The wires leading to the three pins on my pot have all broken off, and I'm wondering how to take it all apart to replace the pot?
I tried pulling the lever outwards, but it doesn't budge. Failing to remove the pot, is my only recourse to get really good at soldering in tight spaces?
dnmun   100 GW
Re: How to disassemble currie throttle?
Post by dnmun » Jan 30 2014 7:13am
cannot see it but there may be a circlip on the inside where the spring is.
docnjoj   100 GW
Post by docnjoj » Jan 30 2014 9:12am
That looks like a self tapping screw next to the lever. Can it be removed?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
yoyoman   1 kW
Post by yoyoman » Jan 30 2014 10:54am
I think the screw is only there to limit the range of motion of the lever.
yoyoman   1 kW
Post by yoyoman » Jan 30 2014 4:42pm
docnjoj wrote:That looks like a self tapping screw next to the lever. Can it be removed?
otherDoc
OK, good call on removing the screw. It wasn't holding anything down, but once removed, I was able to turn the lever more, and that set everything in motion to come apart. It all happened so fast, that I'm worried about getting it all back inside.
Now, I'm going to scrape away at the blue plastic to see if I can get enough surface to solder.
atom1025   100 W
Post by atom1025 » Jan 30 2014 10:40pm
I consider myself pretty crafty and I could not get it back together. I have two I could not get back together. Good luck.
Adam
Bashed Synergy Cycle runs
1800w peak, 31mph tops.
2004 Cannondale Jekyll with a MAC 10
15s 8ah lipo (2100w peak) 31mph tops.
dnmun   100 GW
Post by dnmun » Jan 30 2014 10:56pm
you don't need a big spring to return the throttle to stop position. use a smaller one or rubber band instead and it will be easier to reassemble. you can find the cermet trimpots on ebay too. when you get it out there will be a value printed on it.
yoyoman   1 kW
Post by yoyoman » Jan 30 2014 11:54pm
dnmun wrote:you don't need a big spring to return the throttle to stop position. use a smaller one or rubber band instead and it will be easier to reassemble. you can find the cermet trimpots on ebay too. when you get it out there will be a value printed on it.
Mine says B552 and has a shaft. I didn't see any when I searched for "5k cermet trimpot"
dnmun   100 GW
Post by dnmun » Jan 31 2014 12:34am
http://en.wikipedia.org/wiki/Potentiometer
cermet: ceramic metallic potentiometer
http://www.ebay.com/sch/i.html?_odkw=ce ... r&_sacat=0
post up a picture of yours when you get it out.
if you read this you will see where they show that the B means linear:
http://sound.westhost.com/pots.htm
just thought of one other thing. before removing it from the position, measure the resistance between the wiper and each end. the trimpot is single turn and may have fixed offset position and you would wanna replicate that when reinstalling the new trimpot.
yoyoman   1 kW
Post by yoyoman » Jan 31 2014 2:55am
5k pot http://www.electric-bikes.com/bikes/diag-03.html
eldergeekaz   1 µW
Post by eldergeekaz » Jul 05 2016 4:30pm
I realize this is an old thread but did you (or anyone) ever find a replacement B552 5k Pot. I have looked everywhere and cannot find it. :oops:
I would rather replace the pot rather then spending $50 on the entire assembly. I've found a couple that may work with some fabbing. Usually the shaft is too short or not D-cut.....
Mine are broke off exactly like the pic above. (damn kids) :roll:
Thanks,
vitaliiokolos   1 µW
Post by vitaliiokolos » Jan 12 2021 2:09pm
dnmun wrote:
Jan 31 2014 12:34am
Newbie here. I've been trying for a few days now to understand the difference between a rheostat and a potentiometer but to no avail. I've tried to read about it on Wikipedia and even this article with a video about rheostats https://www.derf.com/rheostat-overview- ... planation/ but they don't really explain the difference in layman's terms.. Too many long words :) Could somebody here please explain the difference like I'm 5? Any and all help will be much appreciated. Thanks in advance
markz   100 GW
Post by markz » Jan 12 2021 5:37pm
https://www.circuitstoday.com/differenc ... d-rheostat
vitaliiokolos wrote:
Jan 12 2021 2:09pm
