latecurtis
I got my max life 22Ah leadass batteries for $85 with free shipping. I am scared of lipo cause of all that has been said of fire. plus it would have been a lot more money as the 6s brick was the same price about $85 but then I would need a charger/balancer and a power supply. but I haven't totally given up on lipo. I have a basket on the back of the bike. I tied a small shopping cart to the basket and went scrappin awhile breaking my batteries in. I gorilla taped and bungeed them to the bottom of the triangle frame for even weight distribution. everything's groovy but I am replacing the plastic milk crate basket with steel bolted to the frame. I am getting bigger and better wheels for the cart and bolting it to the steel basket I will be fabricating. i weigh almost 250 pounds and the bike is over 90 pounds now with the new batteries. my final upgrade will be the magic pie front wheel kit and two 22.5 6s lipo bricks. any more lead acid batteries would be ridiculous due to the weight. i plan on pulling between 100 and 200 pounds of scrap metal. metal goes around $10 a hundred pounds. i can easily get that in a couple hours right in my neighborhood on garbage night. i need the xtra power with the front wheel kit. 450 watts and 24 volts is not even enough power to get me up a hill without pedaling . and that's with my basket empty and nothing hooked up to the back. i will be able to unhook the shopping cart by two large wing nuts. for when i am not scrapping. does anyone know if there is any cheaper front wheel 48 volt 1000 watt kits as good as the magic pie. also should i charge the lipos outside in the back yard to be shure my house don't burn down if one of the batteries are defective. with a good charger it should be quick enough to while i spend time gardening cooking out or working out with my weights. i will get pictures when i get everything done. i really want an electric pick up truck. so i am sort of building one out of my ebike.
