Planning to buy 48v 6000w
Dyaz   1 mW
Post by Dyaz » Jun 18 2014 9:07am
Hello, i planning to buy motor kit form cyclone-tw.com
Have you ever bought anything from this site?
my Choice:
48V Super 6000W "3 chainwheel Kit" + Cyclone 100A continue 11.5AH 48V Lifepo4 pack in bag (10C)+ 48V 3A charger ) (4hours) Complete kit Top speed 100km/h ,cyclone 48- 72V 100A continue 350A max controlelr ( throttle 48V with LED lingt )
Are you sure this kit will drive the bike 100 km / h? how much time will be able to ride with a full loading battery?
Is it worth it to pay for the kit 1569USD ? You might suggest a better option for the price?
dogman dan   100 GW
Re: Planning to buy 48v 6000w
Post by dogman dan » Jun 18 2014 3:53pm
6000w through a bike chain sounds a bit much.
Tench   100 kW
Post by Tench » Jun 18 2014 5:08pm
dogman wrote:6000w through a bike chain sounds a bit much.
That was the first thing that came to my mind too!
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
sven_nilsson   10 mW
Post by sven_nilsson » Jun 18 2014 5:14pm
Maybe it is, but you cannot compare to motorcycle chain requirements because an electric motor produces very smooth torque while a combustion engine is like a sledgehammer in comparison and will need much stronger stuff, especially the four-stroke engines.
kentlim26   10 kW
Post by kentlim26 » Jun 19 2014 4:08am
how fast you wish to clock a speed ? say how many seconds you wish to reach a certain speed?
my suggest if you are looking speed below 50km/h, I will say that small motor of 500w will be sufficient enough to clock, you can always go a bit faster 55km/h.
bigger batter and cells cost more always, I have both ebikes hub motor or cyclone. smooth ride/ sound less... = hub motor
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
Dyaz   1 mW
Post by Dyaz » Jun 19 2014 9:04am
Thanks for answers all :)
kentlim26 wrote:how fast you wish to clock a speed ? say how many seconds you wish to reach a certain speed?
I want to achieve about 100-90 km/h, i was searching hub motor, but all motor not so high top speed...
Like this human https://www.youtube.com/watch?v=IsodEjnNFV8 have a awesome torque, but speed only 60km/h. I want a something like that, less torque more top speed. Maybe you know from where he have bought this motor?
skeetab5780   10 MW
Post by skeetab5780 » Jun 19 2014 9:14am
The x5404 is a slower wind motor. I went from x5404 to x5304 and gained about 6mph. You could get a x5303 and it would be around 8mph more than that. This will bring you to around 50mph full charge 20s(84v).
Or just get a Cromotor.
You can chain drive if you really want with a big block GNG motor and a separate chain drive from your human assist. I haven't made up my mind yet, but I still sort of like the hub motors more because they are silent.
Dyaz   1 mW
Post by Dyaz » Jun 19 2014 9:28am
skeetab5780 wrote:The x5404 is a slower wind motor. I went from x5404 to x5304 and gained about 6mph. You could get a x5303 and it would be around 8mph more than that. This will bring you to around 50mph full charge 20s(84v).
from where i can buy that motor? x5304
skeetab5780   10 MW
Post by skeetab5780 » Jun 19 2014 9:39am
If you can't find one second hand either here or Ebay/CL, then it is cheaper to buy a Cromotor. Even used older X5 motors go for around $400USD
Once and a while a vendor/supplier post New in box X5 stuff but the last ones I saw were $999 dollars not laced in a rim(motor only) they are probably still available.
Both my x5404 and x5304 need new bearings. From what I hear they used junk hall sensors, axles and bearings but the motors and housings are tanks.
slowest out of the 3 x5404
middle out of the 3 x5304
fastest out of the 3 x5303
x5304 could be comparable to x5403
Dyaz   1 mW
Post by Dyaz » Jun 19 2014 9:51am
hmm. So how with cromotors? I think they have also huge torque and top speed? But have one minus, motor emits a high-pitched sound?
skeetab5780   10 MW
Post by skeetab5780 » Jun 19 2014 10:31am
I've never had the pleasure of owning one. Someone else will have to chime in on that.
Dyaz   1 mW
Post by Dyaz » Jun 19 2014 3:55pm
How about this? 529 USD
without battery. 48-72V super 3000W 13T freewheel 8kw max +105 km/h @ 72V ( 48T,44T,24T) super crazy big motors 5.5 kg without gear box with 3KW 48-72V ( max input voltage 88V) 120A continue 350A max cyclone controllers throttle 48-72V no LED light with B.B. style bracket in stock ( speed test base on FFrontal area 0.3m^2)
Is this can be same motor? https://www.youtube.com/watch?v=1DS_6VjKQGY that guy going crazy, thats what i realy want.
bmurray7   1 mW
Post by bmurray7 » Jun 20 2014 12:44am
Dyaz wrote: Are you sure this kit will drive the bike 100 km / h? how much time will be able to ride with a full loading battery?
Bikes aren't built to go 100km/h. If you do manage to get a bike up to 100km/h, the bikes components will quickly suffer severe mechanical failures resulting a severe crash. You would be lucky if you survived.
An 48v 11 ah battery has about 550w/h of energy. It would power a 6000w motor for about 5 minutes. At a 10c discharge rate, the battery will be toast after a few rides.
See:
http://endless-sphere.com/w/index.php/I ... a_Go_50MPH
Eskimo   10 kW
Post by Eskimo » Jun 20 2014 3:28am
bmurray7 wrote:
Dyaz wrote: Bikes aren't built to go 100km/h. If you do manage to get a bike up to 100km/h, the forces bikes components will quickly suffer severe mechanical failures resulting a severe crash. You would be lucky if you survived.
Exactly.
You get four minute run, if your bike does not come apart and kill you. After that your battery is a toast.
IMO 50 km/h is high maintained speed for a standard bicycle components.
Member of a 10 000 mile club
http://helsinkiheroes.com/
kentlim26   10 kW
Post by kentlim26 » Jun 21 2014 3:10pm
my understand my 2nd ebike, when reached above 63km/h ,I already can sense - my front wheel is not gripping well the ground well. I can feel like - I am going to fall anytime. so I have some how accept my current speed 40km ~ 50km/h , I know is slow. I had even go slower like 30km/h on cyclone for 7 cells only, 15amps. is fun to try out all he speed range at WOT.
skeetab5780   10 MW
Post by skeetab5780 » Jun 22 2014 7:59am
kentlim26 wrote:my understand my 2nd ebike, when reached above 63km/h ,I already can sense - my front wheel is not gripping well the ground well. I can feel like - I am going to fall anytime. so I have some how accept my current speed 40km ~ 50km/h , I know is slow. I had even go slower like 30km/h on cyclone for 7 cells only, 15amps. is fun to try out all he speed range at WOT.
its good that you feel that it is unsafe because it probably is. You may have either bad frame geometry weather it be different sized wheels or aftermarket front fork. Or maybe too much weight in the rear of the bike and its not properly distributed to the center/lower portions of the vehicle. It makes a huge difference. Also once you get to speeds above 34mph you should really consider going to DOT rated moto rims/tires.
kentlim26   10 kW
Post by kentlim26 » Jun 24 2014 11:22am
yes, you are exactly right. the weight is at the rear . it could be this fork is too high. I have changed my rim from a thin spokes to a 6 spokes which is slightly heavier. it does help a lot.
