Qulbix 165/140 Raptor /NYX Carbon - Sabvoton/Adaptto - 20s/22s Build #5
Merlin   1 MW
Re: Qulbix 165 Raptor Build - Sabvoton 72150 - 20s Build #2
Post by Merlin » Mar 20 2016 6:59am
How long you can ride on full throttle without overheating? :mrgreen: :mrgreen: :mrgreen:
Rix   100 GW
Post by Rix » Mar 20 2016 8:21pm
You were moving Merlin, talking FAST!
Allex   1 GW
1 GW
Post by Allex » Mar 21 2016 3:02am
Why does your CA show 40Volts?
Merlin   1 MW
Post by Merlin » Mar 21 2016 5:53am
just for the cops. You can setup the ca to voltage you like (to see) i divide it by 2
it was 4am in the morning on a clear highway.
with daylight would be cooler. but a bit risky as iam not in russia :D
Rix   100 GW
Post by Rix » Mar 21 2016 11:43pm
Merlin wrote:just for the cops. You can setup the ca to voltage you like (to see) i divide it by 2
Thats awesome. I figured with the speeds you were going that 40 volts was actually 140 volts. :shock: 40 volts for the cops, is there a way to have 100amps diplay as 10amps on the CA by screwing with shunt values? With a 14s system that would be around 250watts with volt sage. :mrgreen:
Merlin   1 MW
Post by Merlin » Mar 23 2016 7:20am
yes. if you dont "need" the real wattage,amps and volts, you can setup the ca to everything you like to see.
in my first 100kph raptor speed video, i had 40v and 4Kw because i dont divide the shunt by 2.
but with this setting you have to "calc" everthing you see by 2. watthours, amphours etc.
strange thing: with my old trekking ebike i was pulled out 3 times from the cops.
with my raptor never. "they" saw me maybe 10-12 times. but just looking.
if the time comes iam prepared. if iam riding in the legal range. i would stop.
if i know they saw me flying around, i take the next "flight" crossover everything home :D
as i know my Battery, watthours using etc very well, i could divide all that stuff by 4.
looks really legal an 250w accelerating compared to a real "25kg, 250w pedelec/ebike" :mrgreen:
spring is comin. cant wait to ride every day :)
Merlin   1 MW
Post by Merlin » Mar 24 2016 5:44am
Yesterday (night) wasnt my day. :roll:
my "thermal test" was with 20s and 50A Flux.
i think it is even to adapptos ovs "2"
on my older cro v3 9kv i had 100kph with 100a flux weaken.
so, lets try what happen setting up the sabvotons field weaken to 150A :mrgreen:
first try: wtf. totally empty battery (3,65v each cell) and hit easy 105kph.
charge my 2,5Kwh Pack, watch a movie in the meantime, setup cam, and go out for a run.
all i can say. new camera holder sux. wiggles quick up to film the heaven.
last time i replaced a XT60 connector because it was a bit "deformed"
sure it was 100a continuous in a closed frame. but i had two of them to half the current for each connector.
the mistake was 2 wires lay over each other and this heats up alot more.
just want to share my mistakes.
with 150A flux, it was clear it wouldnt stop on 8/9Kw like in my last video. 8/9KW are about ~100A continuous.
it was my first try, so i didnt expect that the controller have to push 11,5KW continuous (145A continuous)
(i let the sideplate on battery side 1cm open for alot of cold air flow.)
this ride ends quick. 112 GPS kph. and an "exploded" XT60 connector.
what i didnt get: why is it "exploded"?
if it was melted, okay. too many amps, too much heat. but a loud "bang"? i would say it was a short circuit. but there was only one side blown.
heat cant be a problem. 100kph on 8°c cold air was flowing around the connectors. all others look really good.
XT60 are for 50A continuous without air flow. i used them for 2 minutes of 75A with 100kph ice cold air flow. nothing deformed or melted.
Merlin   1 MW
Post by Merlin » Mar 24 2016 10:38am
not much to see or "hear" but here it is....
izeman   100 GW
Post by izeman » Mar 24 2016 12:53pm
maybe a cold solder joint that broke and when it reconnected you got the regular "battery to controller spark" which caused the black marks and the loud noise.
Allex   1 GW
1 GW
Post by Allex » Mar 24 2016 1:24pm
50A in a fantasy world maybe :)
for that current I would go for xt150, just to be sure that they will not be a bottleneck.
Rix   100 GW
Post by Rix » Mar 24 2016 5:51pm
Allex wrote:50A in a fantasy world maybe :)
Totally agree Allex, but looking at the picture, that joint looks burnt quick, not melted at all. Just a strange failure. Merlin, get some XT150s, you wont regret it. I somehow think you know this though. Any luck with Ferrotech?
Merlin   1 MW
Post by Merlin » Mar 24 2016 8:36pm
no 50A they eat really easy. my charge equipment had XT60. Sometimes when a buddy comes around for a ride in the forrest we charge his battery quick in 40 min.
its a junsi 4010 and we charge full 70 amps. i monitored with a heat gun. yes. it gets bloody hot that you cant touch (~80°) but it works. ( i can make a video charging) :)
i wouldnt take my hands in fire for that IN a CLOSED frame. no matter anymore. i changed all i had to XT90. very happy nothing happend to my controller.
yes also: i think a bad soldered wire it was. if it was a short circuit still wonder why my 150A FUSE didnt blow. everything is fine.
Bike runs great and pulls incredible. I think the controller "start" settings are a bit conservativ. it feels like the bike goes "slower" from 0-30 now. from 30-100 i see also continues 12KW.
i would buy a spare sabvoton, but this company sucks. no answers anywhere, anymore. redirect to motopulse also i get no answers.
Rix, i write another mail and set you in CC.
heres a good overview from a german guy who is well known as a great tester of new batterys, chargers and motors.
http://www.elektromodellflug.de/hochstrom-st.-bu..html
edit: i remember that are cheap fakes around from XT60.
Hobbykings website says 65 amps:
Made from high-temp Nylon and gold plated spring connectors, both included in the injection mould at the time when forming the connector. The XT60 ensures a solid high-amp connection, perfect for applications up to and beyond 65A constant.
Most/alot Lipo Batterys had XT60.
for short i dont see a problem by 100amps. But the 65C Monsters had XT90 :P
2016-03-24 20.13.13.jpg (136.57 KiB) Viewed 2680 times
sansander.ebike   100 W
Post by sansander.ebike » Mar 25 2016 7:37am
German guy, German Autobahn..... du bist der geilste :D you are the best.
Never drive a Ebiker on the German Highway, "RESPECT"
Ratking   1 kW
Post by Ratking » Apr 13 2016 4:42am
Quick question, how did you manage to mate the 10G spokes with a metric nipple with M3.5?
Or did you re thread them?
Merlin   1 MW
Post by Merlin » Apr 13 2016 10:10am
i buyed new spokes local in Germany :mrgreen:
1100km on the New Frame now. 13.5KW Peaks. Everything works well.
try_all   100 W
Post by try_all » Apr 16 2016 5:55pm
how did you get that speed on 20s? on my mxus 4t i got only 43mph with a lyen 18fet 20s hot off the charger, However i just ordered a sabvoton same like yours hope i can get it over 50mph with flux weaken :P
Merlin   1 MW
Post by Merlin » Apr 18 2016 5:22am
where did you order it?
the SSC Series? (Square format)?
atm i need some new fenders....i had a "backflipp" during bike wash...never touch the throttle with your left hand to hold the bike :roll: :mrgreen:
without fenders i found something new what makes fun with my fat pig :D
try_all   100 W
Post by try_all » Apr 18 2016 9:00am
Merlin wrote:where did you order it?
i bought on aliexpress from qsmotor
http://m.aliexpress.com/item/3225416727 ... sitedetail
yes its a square format not sure if its better then the other shape
Rix   100 GW
Post by Rix » Apr 18 2016 1:36pm
Very nice.
Quokka   1 kW
Post by Quokka » May 25 2016 4:26am
Merlin, what winding did you get for this QS and to get those speeds?
Qulbix Q76R+ QS205+MaxE
Merlin   1 MW
Post by Merlin » May 25 2016 4:32am
its a cromotor v4 / QS205 (11KV).....
- ~8% for sinewave
+ 150A OVS/Flux weaken
in a 19" MC Rim with street K34 Heidenau tires.
Merlin   1 MW
Post by Merlin » Nov 08 2016 10:51am
ill changed the name of my Build topic because some deep changes were made...
Ill checked in for an Adaptto Max-E with BMS
swapped my nano tech battery for more capacity. Another QS Motor as i dont wanted to wait xD
new Rims new Tires. New lights New Brakes + i build another Raptor for my Girl.
We all like Photos....so i start with them :mrgreen:
Sold my Raptor 165 because i was snoopy about handling a 140 + some More Space for Batterys + good offer from Ziva for 2 Frames :D
fitted the old Nano techs inside. Fitted well but not so much space i expected.
Original Kickstand from Qulbix. Its a normal Pletscher. She told me: Its a modified special for Qulbix :D
the Modification was a pvc block screwed down the plastic plate xD
Tire is 2.75x19...could be a problem with 3.0 tires.
some LED Headlight trying...
Quick charging with 2750w :D
19" x 2.75 Heidenau K34 front and rear.
CroMotor v4, no Fenders :D
switching to Multistar Batterys :D
these assholes doesnt ship them anymore. so i took a ride to UK Warehouse and cateched 60 pieces of them.
abit wire p0rn...
HID Front Headlight with Hi and Low Beam. Not blinding other riders...
really cool.
Sm Pro Rims. I made my self some Washers for the Oversized Nipples. works great.
Spokes for the Front butted 13g/14g.
That Mufa was a beast to slip it on *damn
today:
SM Pro Rim 17x1.85 Rear, 3.00 Michelin M62 Gazelle, 9G Spokes, Adaptto Max-e, HID Front Headlight, Magura MT5e.
15x 4s16Ah Multistars = 3,5Kwh of Juice.
1863mm Outside diameter of the M62, Max speed at OVS 4, 125kph. No changes from 19 to 17 inch wheel in Speed.
weight is now 66Kg. Not that light "Bicycle" yup. But its a very light 17KW "Moped" :P
next: switch Frontwheel also to SM Pro and Shinko 244 for the Winter.
Buying a litre of Ferrofluid and waiting again for Hubsinks from Sketch :D
Rix   100 GW
Re: Qulbix 165/140 Raptors - Sabvoton/Adaptto - 20s Build #4
Post by Rix » Nov 08 2016 10:54am
Plain awesome Merlin.
Merlin   1 MW
Post by Merlin » Nov 08 2016 11:16am
thx Rick, but i wasnt ready...you re quicker then i can post *haha
Quokka   1 kW
Post by Quokka » Nov 08 2016 9:58pm
You had any problems using ac circut breakers? Mine crapped themselves at around 10kw?
