Mongoose dolomite fatbike? 7spd, disk brakes, INEXPENSIVE
danjpendleton   100 W
Post by danjpendleton » Jul 30 2014 10:24am
Mongoose Dolomite- $249 with free shipping from Walmart
Update pic
bike is steel framed
7spd freewheel which i believe is shimano
front and rear disk brakes
4 in wide tires
from what ive read on some mtb forums- this bike is actually pretty good for the price...
I know some of the guys on here have converted the mongoose beast which is very similar, except that they are single speed and lack disk brakes. one guy actually ran a cellman em3ev bag in the frame on his beast....so im hoping mine will fit in the frame of this dolomite.
Id ultimately like to build it for snow/winter. Ive gotten so used to riding to work that I cant see myself pumping gas this winter....
Im thinking-
crystalyte hs3540 or some equivalent (i run this on my eboardtracker- sensorless, because one of the halls burnt up and it seems more reliable this way)
lyen or infineon 40 amp controller (run the infineon on my eboardtracker, but might buy an additional one to have a spare)
cycle analyst-dps
and the battery would be my 76v 21s7p 20R samsung triangle pack from paul at em3ev, which does fit in the em3ev bag....(and hopefully in the frame of the dolomite :wink: )
Electric boardtrack racer
http://endless-sphere.com/forums/viewto ... =6&t=55898
Perhaps the single most important element in mastering the techniques and tactics of racing is experience. But once you have the fundamentals, acquiring the experience is a matter of time.
Greg LeMond
gogo   10 MW
Re: Mongoose dolomite fatbike? 7spd, disk brakes, INEXPENSIV
Post by gogo » Jul 30 2014 10:59am
It was just a matter of time, aye? This would be an easy platform for adding a single speed mid-drive to the inboard of the rear sprocket. Even if you used this as a 'disposable', it would be inexpensive to just bolt your electric gear to the next one.
"A conclusion is the place where you got tired of thinking." -Steven Wright
danjpendleton   100 W
Post by danjpendleton » Jul 30 2014 11:04am
I know very little about mid drives. my battery will most likely end up in the frame triangle, so I dont think Ill choose that route. I would like to build a mid drive setup someday, with gearing for rediculous speed and acceleration...with a fat top tube to house a lot of juice.
Greg LeMond
dogman dan   100 GW
Post by dogman dan » Jul 31 2014 6:11am
So where do you get the hubmotor with a fat rim? $125 to get your rim laced to a E-bikekit motor, so that's one option. The rear motor axles are long enough. Then some fiddling about with spacers to make the disk line up. You also need a spacer to move the freewheel outboard some. http://www.ebikekit.com/kit-components/ ... r-1-speed/
Does EM3ev offer a fat rim version of his 12t mac? That would be a great choice, but are the axles long enough? I really don't know.
Mid drive, the bafang won't fit the wide bottom bracket. And I bet a GNG kit would not line up right either, so mods to the mount would be needed.
ambroseliao   100 kW
Post by ambroseliao » Jul 31 2014 7:15am
How wide are the dropouts? They MUST be more than the typical 100mm front and 135mm rear! :?:
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
Tench   100 kW
Post by Tench » Jul 31 2014 7:25am
There is a thread on here about one of these bikes with a rear (135mm) clyt laced into the front wheel, the forks didn't last long though!
I think the rear dropout is about right for a Cro!! :shock:
Here it is;
http://endless-sphere.com/forums/viewto ... =6&t=61757
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
danjpendleton   100 W
Post by danjpendleton » Jul 31 2014 9:59am
http://endless-sphere.com/forums/viewto ... =6&t=44696
^^^^^this guy ran an hs3540 on the rear of his surly. he mentioned that it was 170mm dropout i believe. the motor was not modified or anything
----not sure if hes running a 7spd. ill have to read through it
my friend will re-lace the rear wheel to my motor of choice for around 100. he uses really high quality spokes and can cut them to length because he works at a local bike shop. hes done a set for me in the past
Greg LeMond
MikeFairbanks   100 kW
Post by MikeFairbanks » Aug 02 2014 5:55pm
I need to get on this. I have a work commute through dirt that's 2.5 miles (mostly hard pack but there is some gravel and big gravel near train tracks that normal mountain bikes hate).
By car it's almost twenty minutes (and 6 miles).
In other words, if I can comfortably go by E-Fat-Bike across the dirt I can do it in half the time and twice the enjoyment.
I have a front hub motor (9c direct drive). Is there any hope to use that motor built into either the rear or front?
Stay frosty
spinningmagnets   100 GW
Post by spinningmagnets » Aug 02 2014 6:33pm
I just took a spin on the single-speed with back-pedal brake. I can see the appeal, and in spite of the drawbacks of it being a cheap Wal-bike...the low price allows you to spend your limited budget on other upgrades. $250 is still a good price, and the 7-speed system with disc brakes is a huge improvement.
The 2-speed Xiongda thread said that it can run well on 48V X 15A =720W, and here is a blurb: "If you want to use one of these hubs (or two of them?) on a fat bike, order the hub with a drum brake, which has 166mm wide shoulders on the axles to fit the 170mm drop-outs on fat bikes"
I'm told that at 44V, the 2-speed hub will do 14-MPH and 22-MPH.
wesnewell   100 GW
Post by wesnewell » Aug 02 2014 6:37pm
No chance for the rear. It might fit in the front, but I don't know the width of the forks.I was going to buy one of these the other day but can't find them in stock for $250 anywhere. My rear motor (225mm axle) will fit easily in 170mm dropouts, but I will probably drop a 3-5kw motor in it if I get it. Plenty of room for it even with a 7 speed freewheel.
neptronix   100 GW
Post by neptronix » Aug 02 2014 7:07pm
I considered putting a cheap motorcycle cromotor in one of these.
And then i saw the weld quality of the bike.
Looks like what they allow the new hires to practice on, to be frank.
Give it a look before you buy. Check out the weld quality. Maybe it's hit and miss.... but for high power, i would not go for anything other than proper..
danjpendleton   100 W
Post by danjpendleton » Aug 02 2014 7:53pm
bought the bike. ill have it next week and report back. im going to get a hub motor to fit the back of this this bike one way or another.
Greg LeMond
danjpendleton   100 W
Rode a specialized fat boy last night. That was a lot of fun
Greg LeMond
Post by MikeFairbanks » Aug 02 2014 8:51pm
Seems like a front hub motor would be much smarter (and easier to install, obviously). With the weight of those bikes and grip/size of the tire, I really can't see any advantage of putting a hub motor on the rear. Just my thought (although it's a guess).
Here it is in the 20-inch version (four-inch tires). Boys mountain bike.
Also, check this out. Three-inch tires (not the same, I know), but it's a beach cruiser and looks pretty fun for under 300
http://www.rakuten.com/prod/fito-modena ... 98194.html
Stay frosty
danjpendleton   100 W
Post by danjpendleton » Aug 02 2014 9:35pm
id much rather have a rear motor. Steering and propelling on one axle is counter productive in my opinion. I posted a link to someone who has a clyte hs3540 on the back of his fat bike. He said the motor had no modifications to fit...
I have a beach cruiser ebike with 3" wide tires and rims and Ive seen that fito modena converted before. Mine isnt a fatbike though. the mongoose should be a good winter/semi offroad rig. interested to see how those tires will be on the street at 30 mph....without snow on the ground. but we will see.
Greg LeMond
dogman dan   100 GW
Post by dogman dan » Aug 03 2014 5:09am
I don't get why you'd want the fat tires for street. Well, cushion I guess, at $250, suspension will not be great as an alternative.
But I have thousands of miles of bottomless sand dry washes in my area. A fat bike would be great for that.
Post by MikeFairbanks » Aug 03 2014 9:30am
danjpendleton wrote:id much rather have a rear motor. Steering and propelling on one axle is counter productive in my opinion. I posted a link to someone who has a clyte hs3540 on the back of his fat bike. He said the motor had no modifications to fit...
That's assuming you could build a system that could move it that fast. It would take an awful lot of muscle to move it to 30mph, and it would eat up a lot of power in a short time.
Better for offroad use or slow on-road use (around the neighborhood, around town, etc.).
Stay frosty
Drunkskunk   100 GW
Post by Drunkskunk » Aug 03 2014 10:18am
dogman wrote:I don't get why you'd want the fat tires for street.
Ever get to ride in a 70's era Cadillac? They sort of float down the road the same way, and have the rolling diameter of a 29er.
Check these out as well: http://www.bikesdirect.com/products/gra ... onster.htm
$499. Twice the price, but still free shipping. These come with VeeRubber Mission tires, $100 more value by it's self, and they come in actual sizes.
danjpendleton   100 W
Post by danjpendleton » Aug 03 2014 10:46am
i have the beach cruiser/boardtracker for most days but when it snows or the road conditions arent so great i think this fat bike will do the trick quite nicely. plus they are a relatively new style of bike and i think overall it will be a lot of fun. I can always run a different set of tires if need be, but ill see how the original tires hold up at first.
Hell, if it doesnt work out ill sell it.
Greg LeMond
danjpendleton   100 W
Post by danjpendleton » Aug 03 2014 10:49am
Drunkskunk that looks like a really nice bike
Greg LeMond
John in CR   100 GW
Post by John in CR » Aug 03 2014 10:50am
MikeFairbanks wrote:Seems like a front hub motor would be much smarter...
I'd say exactly the opposite. Those forks look suspect even before adding a motor that will put significant stresses outside of the design criteria. I can't think of a failure worse than a front fork failure. Due to the wide tire the common issue of a rear motor, running out of space, goes away.
danjpendleton   100 W
Post by danjpendleton » Aug 03 2014 12:33pm
^^^i second that
Greg LeMond
Lenk42602   10 kW
Post by Lenk42602 » Aug 03 2014 12:42pm
Aargh.
I bought one. Should see it next week.
I just couldn't justify the price of a decent one given the seat time it competes with against the rest of the pedal bikes my stable. There is about two months here in Pittsburgh where there is actually snow on the ground. I think I can use this sucker along a railroad track in bad weather and not have to deal with cars sliding into me when its sloppy out.
there are a bunch of crappy parts on the bike, to be sure. The high ten frame is not particularly strong or lightweight.
Its 50 pounds outta the box. Steel seat post/clamp, lousy crankset with pinned chainring, spindle bb with caged bearings, solid axles. cheap stem, bars and brakes..... Dumping the craptastic parts, and focusing on dropping some weight on those wheels, I should be able to get it down around the low 30's....
For me personally, I have a BUNCH of spare bicycle parts that are a direct swap, and cost zero additional bucks to transfer over to.. Between that, and some modifications to the wheel that cost just my time, the thing is an easy cheap entry into a fat bike.
Word on the street is that my LR kit is shipping tomorrow; I built a chassis based on a 26" steel full suspension frame for it. If for some reason that kit doesn't seem to work well on the frame I have, I may try that mid drive on the dolomite.
I will post the bicycle - part upgrades and wheel hacks when I get it....
len
Drunkskunk   100 GW
Post by Drunkskunk » Aug 03 2014 12:46pm
^^^i second that
^ Third. And it seems Plebe, who had built one and used a front motor, agrees. He retired his build after concerns about the front fork. viewtopic.php?f=6&t=61757 These might be fun if built right, but it's still walmart quality.
danjpendleton   100 W
Post by danjpendleton » Aug 03 2014 12:55pm
Ill have mine wednesday. if i wasnt going to convert it, i would have purchased something a little more upscale, because ive ridden the fatboy and they are a blast. I agree with lenk42602- a lot of the parts are lower quality because it is a walmart bike, but from what ive read in the mtb forums it isnt half bad. may need to swap some parts out and upgrade things as i go. i commute pretty early in the morning so im not too worried about other cars.
my way home ill probably take an alternate route
Greg LeMond
