new eZip motor
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Mar 26 2020 9:48pm
https://www.ebay.com/i/173844365503?rt= ... %3DDefault
Are these as good as the ones SUNDER posted ?
https://www.aliexpress.com/item/3289147 ... b201603_55
I never ordered from alli express. It says to be careful. i thought Lithiul iron was safer than LiPo ?????
Please let me know. Thanks.
LC out.
I build e bikes. There not always pretty or practical but sometimes they work, at least for awhile. Immortality is not a dream but the future of our evolution. We were given the tools to forge our own destiny. We were created in gods image and shall evolve to live forever.
markz   100 GW
Re: new eZip motor
Post by markz » Mar 26 2020 9:59pm
No battery is safer then another.
LiPo needs careful attention just as much as LiFePO4 or any other Lithium Ion.
Problem with LiFePO4 (Lithium Iron) is that is heavier and bulkier then LiPo and Lithium Ion. I guess you could say the LiFePO4 is more forgiving then LiPo. You have to be careful with any and all batteries you are using or are putting together.
Go to ru.nkon.nl for 18650 cells, the 25R is a great cell to use, along with the PF cell. They can even tab weld the ends for you, so you can solder on wire to make what you want.
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Mar 27 2020 10:33pm
Thanks so much.
I will look into that.
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Mar 28 2020 1:31am
LFP (LiFePO4) is almost impossible to put into thermal runaway by accident, much safer than either LI or LiPo.
And yes, LiPo a bit more dangerous than LI.
Both much more energy dense where weight & space issues are important.
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Mar 28 2020 6:58pm
markz wrote:
Mar 26 2020 9:59pm
I would disagree with that. No battery is totally safe, but how many fires have been started your standard carbon zinc batteries? How many people have gotten chemical burns or been electrocuted by them?
LTO is not safe, but the risks are different, and I think, overall lower.
@LC, I see you found them anyway. Let me just warn you that those pouches cannot be soldered. You either need to mechanically assemble them, or spot weld them. I will show you some photos a little later of how I did it.
LiFePo4 is another safer than LiPo option, because as John61ct said, they are almost immune from thermal runaway. However, they are less resistant to over-discharge than LTO, and need a lower charge rate. They do have better power density, and are way cheaper than LTO though.
The other options that might work for you is 18650 LTOs. https://lg18650.com/battery-cells/152-l ... h-23v.html
These are even more expensive and lower density than pouch LTOs though.
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 Died... Electrified Ninja in Progress!
eCar: Mitsubishi Outlander PHEV... Warramty expired. Still not game!
eHouse: 6.2kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Mar 28 2020 11:19pm
Sunder wrote:LTO is not safe, but the risks are different, and I think, overall lower.
Please expand on that, ideally contrasting with LFP risks and failure modes. Links?
Sold out. Other sources? Do you know the manufacturer?
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Mar 29 2020 4:15am
Basically, LTO's only major risk to life and property aside from itself, is electrical fire and electrocution, but the latter is common to all packs. I have a pack here that can deliver something like 33kw continuously, and 66kw instantaneously. I once dropped a spanner over only part (maybe 16-18v?) of a 30Ah, 24v, 10C sustained capable pack, so at the very least 5kw (Not sure what the instantaneous rating was, but these had around 1.2-1.4mOhm internal resistance). I had holes in my T-Shirt, scorch marks on an MDF bench, fragments of molten metal and a large chunk taken out of the spanner.
To damage itself, you need to overcharge the cell by at least 50%, but if you do, some toxic gases can build up, but in a well designed cell, this should just vent in tiny amounts at a time. Draining the cell to zero doesn't appear to be a catastrophic failure mode, and in face, aside from a small loss of capacity and increase in resistance, doesn't even damage the cell.
Contrast to LFP? You're already comparing very safe with ultra safe. Both are extremely hard to set on fire - even with external heat sources, but LFP will gas and swell from over-discharging. Not sure if the gases from that are toxic, but I'd assume so too.
With a large enough pack electrical fire is also possible with LFP - In fact, electrical fires are "possible" with the right resistance wire on a AA battery... But considering the voltages these are normally used at, most of the time, if there's accidental contact, the spark will push the metal object away, rather than fuse the object to a terminal to give it time to heat, so the more likely fire risk is from the molten metal coming from the sparking. Not a lot of difference there, except LFP packs tend to be lower C-rates.
Obviously have no stats or anything to back this up, but these are just observations.
And, back to my last post. Here's a photo of how I assembled a 48v, 4Ah pack without soldering:
Close up on the tabs, I've punched a hole through them, and bolted them together.
No reason they had to be nylon bolts, and that's not finished yet - I'm going to tape it all down with foam spacers and insulating tape, and possibly even pot it with hot melt glue, but I'm still cycling it to test for weak cells.
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Mar 29 2020 10:07am
cool thanks
link to BMS / voltage checker?
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Mar 29 2020 5:08pm
That's this one here:
https://www.ebay.com/itm/10S-24S-Smart- ... Ggqh8SgrAg
The smaller (lower current) ones are cheaper, but they seem to be out of stock currently.
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 05 2020 2:15pm
As the Hub Motor Turns and the LiPo Fire Burns. Batteries , motor vehicles and e bikes.
Second only to housing transportation has been a major issue most of my life. Especially the last 25 to 30 years. I have moved probably over 30 times. I lost track years ago. Vehicles. I had many of those since I turned 16 years old and started driving.
The last 5 or 6 years I have been riding electric bikes instead of a motor vehicle. However e bikes do have their limitations. Some of those limitations can be solved and some can not. Yes a waterproof rain suite and all waterproof parts and wiring can happen and studs can be put in e bike tires but lets face it. I cant go 500 miles to NY and move a 10 by 10 storage unit to Ohio. I cant even move a studio apartment with an e bike.
I would like to eventually convert a motor vehicle to electric or hybrid. someday. A small 2 wheel drive pick up truck would be ideal. I am looking at some time in the future like 5 to 10 years when battery technology advances and can get two computer controlled motors built in the wheels. Two 25 - 50 kilowatt wheels (Hub motors built into the wheels). This would allow a person to drive on battery power with the vehicles transmission in neutral. Then if necessary can shut the electric motors down and run the gas or diesel motor and incorporate a battery charging system that can charge the batteries that power the hub motor from the alternator. I could also use a solar powered system with a large panel on the roof for trickle charging when the vehicle is at rest and the sun is shining.
However for now I will probably just get a motor vehicle like a Suzuki 4 by 4 which I can keep a small 20 to 24" e bike fully waterproof with a 16 to 20 Ah lithium pack so I don't have to use the gas motor all the time but only when necessary. For example if I were to go camping I could park the motor vehicle and ride around on the e bike. Even if I were to go to a city )NOT NOW ) but if this virus shit ever ends ; I can park the vehicle and run the e bike all over the city and wont need to start the gas motor until it is time to hit a highway back to the city or state I live in. Also if I were to break down out in the middle of nowhere and the vehicle needs to be towed and fixed I got a e bike to go to a motel and restaurant until it gets fixed.
I am hoping that I get the Stimulus money every American who makes under 50,000 or whatever the limit is. If it happens this month Not only can I get my vehicle but can build an e bike to keep in that vehicle. Most of my e bikes are in storage. One idea I have is to get a 24" bike and take the 26" hub motor SUNDER sent me years ago and have the motor put on a 24" rim. It would be geared better for hills That also is a front motor so it would be possible to run a 1,800 watt brushless motor on the rear which could easily go over 30 mph for cruising on level ground. The front motor would be switched off. Then when going up a hill I could use both motors but would only need the rear motor for really steep hills and would not have to run the rear motor that hard because the front motor could do more than 50% of the workload climbing a steep hill.
Like DA once said I am too big for a 20" kids bike. However I am only 5 foot 8 inches so a 26" bike is ok but not when hauling it up and down stairs and maybe not if storing it in a SUV or minivan. 24" would be ideal. Most of the bikes I have in storage are 26" Therefore I might buy a 24" bike here in Ohio for my next project. I can also order an 1,800 watt brushless motor and when I get the 1,000 watt front hub motor from storage have the 24" wheel built for the front.
I really like that with 24" rims for perfect gearing with the 1,800 watt brushless motor however will have to wait on my storage as I have a lot of bikes there I can sell when I get them here. I have my eye on that frame for 40+ mph. Until then I will be running a cheaper bike.
For now though I will need a battery pack as the packs I have now are old. Has anyone ordered any of these packs from this company.
They are all over e bay and they even have 48 and 60V packs now.
It is one option however may go with the better batteries that charge 10 times faster and last 10 times longer so please SUNDER let me know what is out there or should I say where besides China can I order them. I am NOT going into the politics but put it this way. I am all for boycotting China. I will buy batteries ANYWHERE BUT CHINA. I want absolutely nothing to do with China. If it is in China it can stay there. If It WAS made in China and sitting on a shelf in any other country then I will buy it. That means someone bought in bulk and China will not profit from the sale. I am looking and if anyone knows where I can get a good deal on batteries please let me know. Thanks.
LC. out.
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Apr 05 2020 5:54pm
latecurtis wrote:
Apr 05 2020 2:15pm
2WheelsMovesTheSoul has two batteries that a customer cancelled on.
Toshiba is a Japanese company, and manufactures in Kashiwazaki, Niigata prefecture, doesn't outsource to China, so meets your ethical sourcing requirements. (You're starting to sound like a Vegan!).
The post isn't clear if each module is 16 cells each, or 8 cells each. Picture too small to get the part number from it. If it's 16 cells each (i.e. 2 x 38v nominal packs). That's an absolute bargain. If it's 8 cells each i.e. 2 x 19v packs, then it's still cheap for Toshiba, but you could get cheaper by going no name brand from China, compromising your beliefs.
2WheelsMovesTheSoul wrote:
Jan 31 2020 1:23pm
Hey guys, I bought 2 of those totally brand new in the box Toshiba SCIB packs from BatteryHookup.com they had on offer just a few weeks ago. The customer I had purchased them for has now backed out of his chopper build. Paid $250 + s/h for each.
viewtopic.php?f=31&t=104498&p=1542321
Inwo also seems to get large pallets from time to time, but as of last post is currently out. He may have had new stock since, or expecting new stock, or be able to refer you to the customer with a pallet of them:
Altairnano are an American company. They manufacture in Anderson, Indiana. However, they are owned by a Chinese parent company, so you can decide whether that meets your requirements or not.
Inwo wrote:
Mar 18 2020 8:16pm
I'm out, but a customer in Iowa has a pallet left.
Kme in Charles City.
Pm for his phone.
viewtopic.php?f=31&t=92680&p=1538108
Just remember the trick with LTO, is that the idea is small battery, big charger. If you get a 20Ah pack, to charge at 10C, you need a 200A charger, which will be expensive as hell, and won't plug into a normal wall socket (You'd need a EV charger).
That said, for most people the difference between a pack charging in 6 minutes and 12 minutes is neither here nor there. Don't get too hung up on making the most out of the high charge and discharge capabilities. For example, I've just finished a 4Ah pack. I've got a 20A charger on that pack, so I should be able to get it from flat to nearly full in 12 mins (I've done some dangerous wizardry to stop the lack of differential in voltage slowing down the end charge, but that's another story) - But the charger is the size of a large shoebox and weighs about 5-6kg, while the battery is about the size of 3 cigarette packets, and weighs maybe just over 1kg.
In most circumstances, I would be far better off building a shoebox sized LiPo battery if I were to carry the charger around all the time. I'm not. My 95% of my intended use for this project was just enough to do the 18km trip into work. The reason I designed this way was very specific:
1. I already had an expensive high current charger;
2. I wanted as small and light as possible to avoid attention and so I could charge on my desk at work. I have a USB Power Delivery charger that can run off my laptop. It takes 4 hours instead of 12 minutes, but at work, who cares? Not like I'm going anywhere for 8 hours.
3. On the odd occasion that I want to go further, I can carry two of these batteries, get me about 30-35km, which will take an hour, stop for a coffee and charge in about 25-30 mins. I don't see myself riding too much more than 70km in one hit.
I think for you, unless you really have stimulus money burning a hole in your pocket, you should focus on the longevity and sefety of the batteries, and if by chance you come across a bargain charger, or managed to adapt a second hand PC/Server PSU to a rapid charger, don't worry about how fast it will safely take a charge.
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 05 2020 6:01pm
The capacity is 275 pounds
No I love meat but not bats and live ratts and other disease carrying animals. I also refuse to do business with China due to their lack of respect for human life. The Coronavirus was an accident ??????? :roll: I don't think so.
The cheap bike above is good for the hub motor you sent. . It needs a new rim anyway as the 26" rim is bent. It went about 28 mph on the 26" rim but with a 24" rim it is good for about 22 or 23 mph maybe but great for climbing hills. I can put a chain drive motor on the back if I can get a sprocket which will bolt to a disk brake rotor. I will need a steel rear rack heavy duty anyway for cargo so the motor can bolt .Under the rack if possible so can have a large cargo basket above it. I might get the 1,800 watt 3300 rpm motor for the rear.
The bike may not be safe for 40 mph. However just because it would be capable of 40 mph does not mean I would have to do 40 mph. I could drive it at 30 mph until I get the Jackel which I am definatlly getting when I sell some of my bikes in storage.
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Apr 05 2020 6:13pm
latecurtis wrote:
Apr 05 2020 2:15pm
By the way, there isn't a snowball's chance in hell that's 26.8Ah, less than 1kg, and that small. At that weight and size, you'd be lucky if it's 2.6Ah. I'm not exaggerating. The full listing is here:
https://www.ebay.com/itm/36v-lithium-io ... Swt6heIuNk
And it says it's made of 10S2P of 18650s. Average 18650 weights 45g, so 900g for the cells, leaves just enough room for a BMS.
The highest density 18650 is a NCR18650G at 3600mah. So in a fantasy world, this might be a 7.2Ah pack. Cheapest one I could find was here: https://www.ebay.com/itm/Brand-New-Pana ... SwJEpcwp8v
$11 per cell excl. delivery.
They ain't selling $220 worth of batteries including a BMS and the labour to assemble it for under $60 including shipping.
If there's any reason to boycott China, this one's a better one than trying to hide Coronavirus. The level of dishonesty in that country is astounding, and I'm Australian born Chinese.
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Apr 05 2020 6:16pm
latecurtis wrote:
Apr 05 2020 6:01pm
No I love meat but not bats and live ratts and other disease carrying animals. I also refuse to do business with them due to their lack of respect for human life. The Coronavirus was an accident ??????? :roll: I don't think so.
Sorry, maybe that's an Australian joke. Over the last two years ago, Australian Instagram Influencers in Australia have started to talk about "Ethically sourced food". I.e. no animal cruelty (or animal products at all), and grown using fairly paid labour, fewest food miles, etc. etc.
Most of these influencers are young attractive ladies in their 20s, and they almost always pose in bikinis, yoga pants or lingerie, so I'm not sure if they are popular for their advice, or their followers are mostly made up of men.
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 05 2020 6:29pm
I have been studying China since the Coronavirus outbreak. Animal cruelty is one thing that makes a lot of people mad. I always believed that if you are going to kill an animal then must eat it. Like shooting a deer. I do not believe in keeping or raising animals for slaughter if the animal is suffering unacceptable living conditions or the animal suffers. A cow in a field grazing on grass does not suffer except for the moment it is slaughtered.
I read about how they treat older people and the total lack of respect for human life. It is common knowledge over there that if a car hits a pedestrian that it is encouraged for the driver to back up over the person several times to make sure they are dead as it is cheaper and like a fine rather than call for medical attention and pay the victim's medical bills for lord knows how long. China has no regard for life in general. The whole country is about money. Since they are so overpopulated human life has little or no value. Therefore why would they even care that they made the whole world sick due to their stupidity or more likely on purpose.
This does not apply to all Chinese people. Just the ones living in China or support mainland China.
Anyway lets get back to e bikes. I see a lot of sprockets on the electric scooter parts website that bolt to a freewheel like the stock Currie rear wheel. ONLY 26". For proper gearing 24" has advantage and a sprocket that bolts to a disk brake rotor is cheaper than the 120 buck Currie wheel. Do you know where they sell sprockets for disk brake rotors. I know they do custom sprockets but too expensive. The bike above also does not have disk in the back but V brakes so I would have working front and rear brakes for the build.
Thanks.
LC out.
tomjasz   10 GW
Re: new eZip motor
Post by tomjasz » Apr 05 2020 6:36pm
Oh FFS.. study harder!
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 05 2020 6:50pm
I am not discussing China any further. I got the information from several discussion groups on Facebook some with around 4,000 members many of them Asian and some even Chinese living in other countries. I am Just hoping the virus nightmare will go away. I want to build e bikes again.
I am not sure what a sprocket which bolts to a disk brake rotor is called but can find the perfect size sprocket for the 1,800 watt 3300 rpm brushless motor.
https://www.ebay.com/itm/48-Volt-1800-W ... 3011093613
If I run the motor with the 1,800 At 60V it will be 40+ mph. 4,125 rpm.
rpm = 3300 / 48V * 60V = 4,125
power = 1,800W / 48 * 60 = 2,250W. Yes it will be a BEAST :twisted:
I am buying the 24" bike and ordering the 1,800 watt motor soon. Please let me know about a sprocket. I am not using cheap chain. I am going with #40
Electric scooter parts will make me the custom sprocket I need for the disk brake rotor which is awesome however I have a feeling the price for such a custom sprocket wont be that awesome but probably close to 100 bucks or more so if someone knows where I can order a 76 tooth sprocket cheaper please let me know.
Not concerned about slightly over-gearing with the rear motor @ 60V as It will have the 1,000 watt hub motor on the front geared for about 23 mph for climbing hills. That will add weight but should still reach 40 mph with a good 60V battery pack. I might run it at 48V if I can find a variable controller which is 2,500W and 48 - 60V. It would be easier to get a 48V pack and a 48V pack should work with all my other e bikes. 60V will not work for any of my other e bikes. I can build a 60V pack when I get the Santa Cruz Jackel.
Thanks.
LC out.
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 06 2020 7:05am
controller - Copy.png (478.22 KiB) Viewed 356 times
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Apr 06 2020 7:13am
No one cares about you blaming China, it's false but your business how you make choices.
However from a practical POV trying to do ebike stuff avoiding products made there is like saying you only want fish that don't piss in water.
Maybe not impossible, if you were wealthier and just wanted a ready-made bike for $8000, but I bet scratch the surface a high percentage of components would still come from there.
Just the way of the world, reality as it presents itself.
Banging your head on a big boulder, isn't going to affect the rock, just you.
But suit yourself. . .
latecurtis   1 GW
1 GW
Re: new eZip motor
Post by latecurtis » Apr 06 2020 3:17pm
I will never buy an e bike. I build e bikes. I am not discussing China any longer. All I will say is we will be lucky if any of us survive.
if I do survive , I found a decent controller and is my last post. I am searching now for a 60V lithium pack also.
https://www.ebay.com/itm/60V-DC-Motor-B ... 0008.m2219
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Apr 06 2020 6:23pm
If you have a bit of spare cash, consider buying a Phaserunner. It's double the cost of that one, but it is the last controller you will ever need. Fully programmable from 24-90v, decent current especially if you put a extra heat sink on it, and it's totally water proof.
So much you can control, from the ramp up time, to phase currents (vs battery currents), regen battery protection (lowering current when the battery nears flat) thermal protection.
Genuine field oriented control is amazingly smooth and quiet, and more efficient.
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Apr 06 2020 7:15pm
Is ASI BAC a Euro product?
tomjasz   10 GW
Re: new eZip motor
Post by tomjasz » Apr 06 2020 7:59pm
latecurtis wrote:
Apr 06 2020 3:17pm
Dude. Listen, meaning read, the sensible people posting hear. You and I are not experts. The best we can do is trust the posters that made all the mistakes before us. And typically share those experiences. Blathering a claim to be clueless fails to help you. If you and I were smart, we’d be rich. Accept your station and trust in others. Your decisions so far have been seriously frocked.
Sunder   1 GW
1 GW
Re: new eZip motor
Post by Sunder » Apr 06 2020 8:40pm
john61ct wrote:
Apr 06 2020 7:15pm
No, it's Canadian. Headquartered and assembled, but I'd be very surprised if it wasn't from Chinese components. Makes the Phaserunner the same, I guess.
john61ct   100 GW
Re: new eZip motor
Post by john61ct » Apr 06 2020 8:48pm
Wow, unexpected.
Purists will never be satisfied, but buying from a Canadian company shojld be good enough for most.
One day the Chinese will control the maple syrup monopoly worldwide. Would probably be great for the consumer
8-)
