- IMG_0581.jpg (202.09 KiB) Viewed 202 times
Well It is a start. Yea I know the cells do not like heat but hopefully with my new solder iron I can do it quick.
I plan on ordering other balance plugs from a different vender. I won't cancel the ones I ordered as I plan on ordering more cells.
https://www.ebay.com/itm/US-SHIP-10-PCS ... %3A2334524
- download (25).png (226.33 KiB) Viewed 202 times
I can use these small connecters to start though so I can start charging.
I think a lot when walking so thought about what to do with the space in the middle and came up with a great idea thanks to DA.
I remember a few pages back he mentioned running 14S to get the best performance from a 48V controller.
Since I can fit 6S - 10P on the sides then I can gorilla tape 10 cells in parallel in the center and charge it separate from the 6S packs. Then depending on the limitations of the motor I can hook up for 7S and hook in series to a second 7S set up and run 14S - 10P for 56V.
I do not call 10S - 36V because at full charge even with older cells it should be 40V. Also 4V per cell is easy to calculate. It does not matter if some cells are 4.1V or 4.3V. I would not want to mix brand new cells though that are 4.5V or above.
So using my math a 10S pack = 40V , A 12S pack 48V and a 14S pack = 56V. I would not want to run any of the geared hub motors rated at 36V above 10S or 40V. I also would not want to run the 36V - 750W gear reduction motor or the 36V - 1,000W motor at 56V but 48V should be ok. That leaves the 48V - 1,000W hub motor and the 1,800W 48V brushless motor for 56V. Also 56V should do the trick if I order a 60V - 3,000W brushless motor for the Haro V3. But that wont happen until I am running 14S - 20P.
Doing the math I am better off running the 48V - 1,000W hub motor at 12S or 48V as the 36V - 1,000W motor on the front is geared for 28 mph and the hub motor is also geared for 28 mph at 48V or 12S.
28 mph / 48V = 0.58 * 56 = 32.6 mph. - hub motor on rear.
- download (27).png (32.09 KiB) Viewed 202 times
Yea. Much better off going with 36V up front and 48V in the back.
Since the 1,800W brushless motor was rated at only 26 amps then 56V should do it justice and can get at least close to 1,500W out of it.
48 * 26 = 1.248W
56 * 26 = 1,456W
https://prnt.sc/wdyhb0
That is one thing I do not understand about DC motors and how they function. Is current a constant by design ? I know RPMs change according to voltage and watts also change by voltage but what about rated current and max. current. Obviously the 1,800W motor would need over 60V to achieve 1,800W but is rated at only 26 amps so did I get ripped off ? I paid about 140 bucks with shipping for a motor rated at 48V and 26 amps or basically a 1,200 watt motor. 48 * 26 = 1,248W. I only paid 62 or 64 bucks with shipping for the brush 36V - 1,000W motor which would put out over 1,300W @ 48V - 1000 / 36 = 27.7 * 48 = 1.333W.
Very confusing indeed. I do know however that brushless motors can be over volted more than brush motors so at 60V the 36V brush motor would over heat and self destruct but if 26 amps is the maximum then even at 66V I could not reach 40 mph as 66V * 26W = 1,716W. So basically I bought a 140 dollar piece of junk as at 1,333W and 48V I could hit around 33 mph and the brushless motor at more than double the price will only go about 3 mph more at 66V. that is terrible.
Please let me know. Thanks.
LC. out.
12/31/20 - 11:09 PM.
- IMG_0584.jpg (267.66 KiB) Viewed 197 times
- IMG_0583.jpg (234.41 KiB) Viewed 197 times
Yea. 14S - 20P sounds great for the 1,800W brushless motor but for the 1,000W - 26" hub motor I am going with 12S - 8P.
I see four rows of 4 - 6S - 1p fitting perfect in that space. Two containers that size is ridiculous. I can find a water proof zip up bag to cover that and still have room up front for my 10S - 8P pack for the front motor. It will be 2 kilowatts total with both motors and both motors will have almost exact gearing at 28 mph.
Also once I get all the balance connecters hooked up I can use my Y balance cables to balance two - 6S packs with each charger so charging all 16 - 6S packs would be much faster than dealing with 20 - 6S packs for 12S - 10P. As long as I can squeeze 1,000W out of 12S - 8P It should work .
Please let me know.
thanks.
LC. out.
I build e bikes. There not always pretty or practical but sometimes they work, at least for awhile. Immortality is not a dream but the future of our evolution. We were given the tools to forge our own destiny. We were created in gods image and shall evolve to live forever.
