2000 Lumen USB Headlight
cr0nis   1 mW
Post by cr0nis » Sep 01 2014 7:11pm
Hi All,
First off I want to thank everyone for their help over the last few months, including cellman, who was patient and helpful as I placed my order for a triangle battery pack. What I've realized is a simple ebike turns into a small obsession, adding parts here and there. With that being said, here is my quick review of a USB headlight.
I was looking for a way to have a nice powered headlight, with my first choice being a light that plugs into my CA directly. After looking at the prices, I finally realized that a cheaper alternative would be to just use a USB light with a free powerbank I got at a recent technology convention.
Below is a 2000 lumen headlight I got off ebay for about $12.
I use a very small powerbank with the following specs:
Input: 5v-800mA
Outpu: 5v-800mA
Capacity: 2600mAh
Mounting it to the front of my handlebar, and running the powerbank into the center frame bag couldn't be more seamless:
To be honest, 2000 lumens is a bit much, so I run it at the second setting, which dims the light to about 1200 lumen at about 1500MA (current). The light lasted exactly 2 hours and 22 minutes, which seems to befalls awesome considering the quick setup.
For those looking for a decent light and don't mind charging a removable USB powerbank every few days, this is a great alternative to an integrated CA light.
Enjoy!
Raged   1 kW
Re: 2000 Lumen USB Headlight
Post by Raged » Sep 01 2014 10:57pm
Nice... I picked up something similar (headlamp that comes with battery pack and charger) off ebay :
http://www.ebay.com.au/itm/271436169128 ... 1439.l2649
So when I charge my battery pack I can charge the light as well. The batteries used are standard 18650 batteries (cheap rechargeable) so I can stack them in parallel or swap them out when I need to.
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
TheBeastie   10 MW
Post by TheBeastie » Sep 02 2014 10:14am
Yeah i got that USB version myself. I never thought for the low price it would be so bright.
i get the odd bit of words from ppl on the street.
This video below at 24 seconds, guy drinking a beer says "What do you use at night time?" as light was beaming them when i first turned it on..
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
bionx 1954   100 W
Post by bionx 1954 » Sep 03 2014 7:02pm
You can also use a dc to dc converter to power the headlight from your battery pack. I use a 36v to 12v for my headlight, but 36-72v to 5 v would power your head light.
d8veh   100 GW
Post by d8veh » Sep 04 2014 5:39am
bionx 1954 wrote:You can also use a dc to dc converter to power the headlight from your battery pack. I use a 36v to 12v for my headlight, but 36-72v to 5 v would power your head light.
The Banggood ones have the DC/DC converter included inside the light. Shortly, I'll be able to tell you about this one that can take any voltage between 8v and 84v. It has the Cree U2 emitter:
http://www.banggood.com/LED10-U_S-CREE- ... 36965.html
jerrydubois3   100 mW
Post by jerrydubois3 » Sep 04 2014 9:39pm
These are very cool lites and mount
Phasor....108 Volt 100 AMP Cromotor
Raptor........108 Volt 100 Amp CroMotor
Greyborg....84 Volt 60 Amp HPC 3500 Watt
