StinkyGoalieGuy
- Joined
- Apr 23, 2008
- Messages
- 298
I'm considering building a frame that is bolted together instead of welded. Imagine something along the lines of Tinker Toys. The junctions would be aluminum blocks connected by square aluminum tubes. The head tube block could be CNC milled to accept the bearing cups for the headset. The junction for the seat tube/down tube could be CNC milled to accept a bottom bracket. The rear suspension triangle would be built in similar fashion. This is very much in a high level conceptual idea stage. The advantage I see is that the geometry can be easily changed by using shorter or longer tubes, and obviously no welding is invovled. Is this a bad idea? Assuming I used an adequate sized tube with adequate wall thickness, will the weak point be the bolts?
