Feeding 12v 5050 led strip with 48V battery
Nobuo   10 kW
Post by Nobuo » Nov 25 2014 9:46am
I'm installing 12V 5050 RGB led strips in my ride as position lights.
I wonder if I can feed them just with a DC-DC converter efficiently, or better to fed them with a independent 12V battery
This is the DC-DC converter.
http://www.aliexpress.com/item/E-bike-D ... 06594.html
Greetings :pancake:
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
amberwolf   100 GW
Re: Feeding 12v 5050 led strip with 48V battery
Post by amberwolf » Nov 25 2014 11:21am
Either works fine as long as it supplies t he current needed for them.
Nobuo   10 kW
Post by Nobuo » Nov 26 2014 5:13am
Thank You for your fast reply :)
That DC-DC converter is rated at 12V 10A max, but 6A max recommended.
5 meters 5050 (60 led / meter) is rated 72W (6A at 12V)
That means that I would be able to feed a whole 5 meters strip just with that small DC-DC converter?
If I use the whole 5 meters strip, Should I put a ~7A fuse between Strip and DC-DC converter?
1000w   1 kW
Post by 1000w » Nov 26 2014 5:21am
That dc converter will easily run that led strip.
I use the same dc converter to run a few metres of leds and a triple cree head light.
Nobuo   10 kW
Post by Nobuo » Nov 26 2014 5:37am
OH nice! it gets warm? I need to put a fuse between?.
Just if anyone has that converter, this is a very interesting item :)
http://www.aliexpress.com/item/Dropship ... 80393.html
1000w   1 kW
Post by 1000w » Nov 26 2014 10:14am
The converter doesn't get warm in my installation and I don't use a fuse with it, but using a fuse may be a good idea, it's your choice.
Cheers
ddk   1 MW
Post by ddk » Nov 30 2014 6:06am
I'm assuming you're using a RGB controller.
The small-ish ones have 2A drivers per color string and work (brightly) between 12-24V. They don't use a convertor so the power use @ 224V is almost twice what it is at 12V (not that you intend to run this at 24V, just trivial info...)
Every color other than white uses less than 6A for the whole string
If you only use a single die, like red (R), you only need a 2A (plus a little bit more) source
...don't ask how I know all this
LOL
2 strings of 5050 RGB
slightly visable.jpg (29.83 KiB) Viewed 999 times
"How can we play Hot Wheels without lighter fluid? " -Serge
