E=IR
- Joined
- Jul 13, 2007
- Messages
- 46
My bike is powered by a brushed WE BD36 hubmotor with a 48V battery pack. There is a voltmeter (el cheapo multimeter) with probes on the plus and minus poles of the battery pack.
At a stopped position, no throttle, fresh pack, the voltage reads about 51V.
When I accelerate I observe the multimeter register voltages up to about 150V, which slowly drop as the bike reaches top speed to about 43V. The voltage reading seems to stay stable as long as the same speed is held. I would expect to see a voltage drop as soon as the hubmotor is included in the circuit, but the multimeter reads a big increase in DC voltage, well above the battery pack voltage.
What is the cause for the meter to register the high voltage? Apparently a change in current affects the reading.
Is something in the circuitry of the multimeter that causes it to read high voltages?
Is there AC noise riding on the DC current?
EMF from the hubmotor?
Does the controller create "noise"?
Perhaps PWM frequencies are affecting the voltmeter?
Anybody have an idea what could be causing the odd readings?
