First build - Vector (e-kross) frame
herbalizer404   100 mW
Re: First build - Vector (e-kross) frame
Post by herbalizer404 » Apr 14 2015 3:37pm
Some new pictures with a halo sas 26" as front wheel.
pchen92   100 W
Post by pchen92 » Apr 14 2015 4:01pm
Hi,
what is the wheelbase of this frame ? To compare, the Giant DH Team is around 110-115cm. I'd like to get 5cm more.
I plan on getting the vector frame and Max-e once I'll move to Munich for the summer.
Greetings from Paris :D 8)
Giant DH Team
Cromotor 18s4p Kelly KEB72101
http://www.endless-sphere.com/forums/vi ... =6&t=41896
Post by herbalizer404 » Apr 15 2015 9:58am
I will check the wheelbase tonight. I putted the chain this morning.
Unfortunately my rear brake doesn't fit between the motor and the disc.
Anyone had this problem? Thanks
striker54   100 W
Post by striker54 » Apr 15 2015 1:22pm
I also had problems with the rear brake, in my case with the cromotor and a avid bb7 the rotor stays to close to the side.
I had to fabricate a adaptor to secure the caliper.
GiantEV   100 W
Post by GiantEV » Apr 16 2015 12:10am
Which headset did you use?
Post by herbalizer404 » Apr 16 2015 12:33am
Ok thank you striker. Maybe i can find adapters on the market.
The headset is this one
1-1/8" EC34-30 down EC34-28,6 UP
striker54   100 W
Post by striker54 » Apr 16 2015 4:42am
herbalizer404 wrote:Ok thank you striker. Maybe i can find adapters on the market.
Maybe this can help: http://endless-sphere.com/forums/viewto ... s#p1035033
Post by herbalizer404 » Apr 16 2015 5:12pm
Im the owner artur is talking about :p
I will receive a total of lifepo4 4sx6=24s
so 13.2Vx6=79.2V 8400mah and 30c (40c burst)
Do you know how much A will it really brings? And how many watts finally?
I'm notre sure about my calculation. Thanks
Dirtech   1 W
1 W
Post by Dirtech » Apr 16 2015 5:29pm
herbalizer404 wrote:Im the owner artur is talking about :p
Hi Herbalizer.
I got it as 76.8V nominal (24x3.2)
I would suggest the discharge values are optimistic. What capacity are your cells? 5Ah? The discharge rate may not be a problem with 30c cells. I will use multistar lipo on mine which say 10c but really dont perform well over 4c-5c.
Post by herbalizer404 » Apr 16 2015 5:37pm
OK thx. Here is one of the six pack
Dirtech   1 W
1 W
Post by Dirtech » Apr 16 2015 5:49pm
herbalizer404 wrote:OK thx. Here is one of the six pack
You are right, it says 13.2V I could have sworn LiFePO cells were 3.2V nominal. So if the discharge rate is accurate, you could pull 8.4x30=252A (8.4x40=336A burst)
Realistically I think your controller will limit you in terms of current. Even the Max-E has max battery current of 140A.
striker54   100 W
Post by striker54 » Apr 17 2015 2:07am
If the Life cells from hobbyking are like the Lipo cells also from hobbyking you need to de-rate the C capacity by 4 at least. So the 30C will be more 7.5C really.
Dirtech   1 W
1 W
Post by Dirtech » Apr 17 2015 3:34am
You could add another 24s in parallel to double the current you can draw and achieve 16.8Ah capacity. But even if striker is right and the batteries are only good for a quarter of as advertised, this is still 63A (84A burst).
striker54   100 W
Post by striker54 » Apr 17 2015 4:02am
Dirtech wrote:You could add another 24s in parallel to double the current you can draw and achieve 16.8Ah capacity.).
Also only 8.4Ah will be good only for 20-30km of autonomy. The ideal will be the double or triple of that capacity.
Dirtech wrote:But even if striker is right and the batteries are only good for a quarter of as advertised, this is still 63A (84A burst).
63A is good for a MINI-E
For a MAX-E you need the at least the double of continuous corrent or the cells will sag a lot.
garrett42   1 µW
Post by garrett42 » Apr 25 2015 11:36pm
Hey awesome build! This is an almost identical build to what I am wanting to do. Now that you have it built up do you have any idea how much it weighs? I only ask because my local laws prevent anything over 100 pounds to be legal. Thanks!!
Lurkin   100 kW
Post by Lurkin » May 04 2015 5:34am
Lookin forward to this....
moonshine   1 kW
Post by moonshine » May 05 2015 11:08am
Hey man I'm having issues with the rear freewheel and the front chain ring.
Also did your cranks go all the way up the square taper? Or do you have a decent amount of the square taper showing?
Current Build: Vector, MXUS 4T in 19" moto, Max-E, 20s8p Samsung 25R http://endless-sphere.com/forums/viewto ... =6&t=67752
Torque Raptor, Cromo V3 in 19" prowheel, Kelly KBL96251, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =9&t=56342
Giant DH Comp, X5404/Cromo V2 in 26" rim, Kelly KBL96251/Lyen 18fet, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =6&t=40031
GiantEV   100 W
Post by GiantEV » May 05 2015 3:34pm
It looks like the chainring is mounted on the wrong side of the crank arm. That should move it over and help a bit.
kiwiev   10 kW
Post by kiwiev » Jun 01 2015 2:38am
Yeah I flipped my ring gear over to the inside and went to 34 tooth. My square is showing a bit on the inside.
You need to get it on as fast as possible to get your lowest gear on your rear cassette. I have a 10 speed but cant get the lowest gear. But I did this so I could use a shimarno shadow clutch derailer it certainly stops the chain slapping
Cheers KiwiEV
Post by herbalizer404 » Jun 19 2015 4:59am
Hi guys,
I'm coming back after a long while.
I'm about to buy those batteries:
http://www.hobbyking.co.uk/hobbyking/st ... _Pack.html
only 6 to begin, I'm a beginner in batteries plugging..etc
Do you know guys what kind of plugs do I need to buy to plug those lifepo4 in serie?
Thank you
kiwiev   10 kW
Post by kiwiev » Jul 02 2015 1:22am
XT-90 I think or XT-60 you can buy on e-bay
I plugged 3 in series by to lots then plug the the2 packs in series.
Cheers Kiwi
sllikskills   1 W
1 W
Post by sllikskills » Aug 01 2015 1:39am
Hey pal,
Long time no talk - Great job with the build, the black looks awesome. I have a quick question. I'm using a Cromotor too, did you have any problems fitting the axle on the dropouts? It seems like you inverted the dropout clamps. Also, was the axle too wide for the frame dropout? It seems like it's so hard to slide the axle in, it would be impossible to take it out afterwards, I was thinking about grinding a little of the dropout to make it just 0.5millimeters wider...
I should have my bike done within a week!! I was planning on opening a build thread afterwards showing the steps I took to put the bike together. I know last time we chatted I only had a sketch, I came a long way - here's a preview picture :twisted: :
An E-Bike crazed I.T. junkie/analyst who scratches on turntables like DJ Premiere...
Complete Custom x5403 Project Build: http://endless-sphere.com/forums/viewto ... 7#p1012857
ScooterMan101   1 MW
Post by ScooterMan101 » Aug 02 2015 9:31am
With the Mac Hub motor, I had to use a 203 mm rear disc rotor, and the 203 disc caliper mounting adapter . even a 180 rotor would not work, Had to use a 203,
shimano makes both a large 203 disc rotor and adaptor .
http://endless-sphere.com/forums/viewto ... =3&t=71378
herbalizer404 wrote:I will check the wheelbase tonight. I putted the chain this morning.
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
Post by herbalizer404 » Nov 23 2015 4:46am
Hi Everyone,
My build is for sale. You need a controller and a battery and it will ride. I never finished the build, so everything is brand new, and never used.
I'm waiting proposals.
jakequicksilver9   10 W
Post by jakequicksilver9 » Nov 23 2015 9:07pm
Why are you selling?! You bike looked so good!
