Been a lurker for longer than I want to admit - now I'm a poster.
I'm new to BMS's and I don't understand the difference between the kind that have two wires and the other kind. The two wire ones seem to only require one port that is shared for both charge and discharge. The other kind has a dedicated discharge port.
Is one better than the other? Seems like most batteries use the seperate discharge and charge ports, but other batteries like sunthing28 on ebay has the two wire bms. Is it ok to have the charge and discharge ports shared?
Thank you
Thank you
