internethope
- Joined
- Oct 4, 2008
- Messages
- 25
hello,
i am new to e biking and have invested a fair bit of money into a recumbent cycle to try to help me with my back problem as i cannot ride a upright as i am over weight,
i have just managed to get my kit sorted finally after quite along time sorting parts and fixing onto bike.
my first lipo test was today with all the propper parts which i was recommended . i bought the 24volt 36 volt kit from cyclone.tw who recommended me this kit to be ran at 36 volts to get about 1000 watts power. as i asked him for a kit which would pull me about my hilly area as i am heavy but i wanted some respecatable runtimes also so i feel this was a good compromise.
now, i ran the bike on some used 17ah lead acid batterys for a while before my lifepo batery came as i bought it on ebay and took over 1 month too arive, i bought it from jimmmy ....,
ive read the forums on this guy, seems ok guy to me , well i gave him the benefit of the doubt as i do not know much about them as i am new.
but the lead acid batterys had hardly any runtime at all, i could barly reach end of road to shop with out them going flat , this was after cycling them a little also.
so anyway ,
once my new lifepo's arrived i carried onto locate them with padding inside a spare pannier box, after a thorough check and patient install putting a switch and inline fuse in buying water proof panier boxes and such , i set off. but as soon as i hit the throttle i get a little acceleration then it cuts out, absolutely no power! i have to wait a little while and disconnect the power and reconnect then it works again but repeats itself, this was after me charging the cell all morning , i would have left it longer but the charger kept clicking on off , on off all morning green red so on so on.( now i have the lipo charging all night incase i got it wrong with the charge, but as it stands it looks fully charged as the green light is on solid) this is the new lifo po cell which has voltage of 38.4 on the sticker and 20 ah . the battery is about 13 " x 4" x 5" roughly , i think it is wise to mention the size as i have no reference to what size a 10 or 20 ah battery shuold be. as i understand the cells inside are smaller than the normal ones and are bunched in series and parallel to make up runtime and voltage.
the bike ran futher on lead acid but still quite useless. the motor kit is brand new and so is the battery so it is hard for me to tell what is faulty here ?
oh i nearly forgot i ran the bike initialy on SLA 24 volt only with better results althogh it did cut out after a few mins which i put down to bad/ old cells, i have much much larger car batterys to try out as a process of ilimination in a attempt to fault find.
fingers crossed someone out there can enlighten me on this situation.
i heard it could be a faulty hal sensor, but idont know what that is other than a component that would be to do with teh esc, ( electronic speed controller)
love to get some feedback soon.
many thanks.
rob.
so anyway ,
many thanks.
rob.
