Ah, the q100h, light of my life.
Forks come in all kinds of different parameters, materials, weights, widths, sizes, suspension, costs, colors and support various types of brakes. More information is needed. http://www.sheldonbrown.com/headsets.html
I recommend getting some steel forks that suit your needs and weld/epoxy on some doctorbass torque arms. Aluminum lacks a fatigue limit, if there is any play in your setup, the aluminum will eventually crack (as I am sure you've experienced). I am a little bit obsessed with doctorbass torque arms. They seem like such a versatile product at an amazing value for the retrofitter. I know this sounds like an advertisement, but I am no shill. There are a lot of benefits to the design in my opinion, the biggest is their open mouth design. Loosen a few axle nuts and you can get your wheel free from the dropouts in no longer than it took before the torque arms were installed. Great for changing a flat, replacing a tire, truing the wheel and all that.
To eliminate any play potential in doctorbass torque arms, rotate each arm in opposite directions as you weld/epoxy and clamp.
http://www.endless-sphere.com/forums/viewtopic.php?f=31&t=29129
