Q100 vs Q100H
docnjoj   100 GW
Q100 vs Q100H
Post by docnjoj » Apr 26 2015 11:15am
Does anyone know if the Q100h innards can go into a Q100 case? It appears that the cases are the same size, but the gearing is different. The Q100 has 8:1 gears and the Q100H has 12:1 gearing.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
motomech   1 GW
1 GW
Re: Q100 vs Q100H
Post by motomech » Apr 26 2015 11:40am
Yes, the cores will swap. Of course, if the Q100 is a CST(Q100C), The screw-on side-cover need to stay with it's motor.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/10Ah Multistar Lipo rear 4Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 4#p1378484
docnjoj   100 GW
Re: Q100 vs Q100H
Post by docnjoj » Apr 26 2015 11:49am
Thanks MM
Mine is just a plain Q100 Rear with a freewheel, no freehub like the Q100C.
otherDoc
d8veh   100 GW
Re: Q100 vs Q100H
Post by d8veh » Apr 27 2015 2:42am
You have to swap the side-plate as well as the core with all versions. It's no problem because it all comes out as one assembly ready to swap, so, actually, it's easier.
The different side-plates have different ring gears, and there's different clutches too.
docnjoj   100 GW
Re: Q100 vs Q100H
Post by docnjoj » Apr 27 2015 8:01am
Thanks d8veh
I figured that the ring gears would be different since the gear ratios are different. As long as the parts interchange I'm good. I want to order the Cute 100H and use the wheel build for the regular Cute 100.
otherDoc
toniovelo   10 W
Re: Q100 vs Q100H
Post by toniovelo » Feb 17 2019 3:19am
Hello, i've old q100 328rpm 36v with 26 rim, Can i swap it with a q100h? Thanks a lot to confirm this swap is possible?
Sorry for my bad english...
