Cka3 said:
yeah, everyone is different, but it is much easier to change couple numbers in CAD program then to model frame from scratch, I wonder why no-one shared their designs. Everyone want to patent/money for it?
Most people probably didn't use computers to design and build them in the first place--they probably did like me and did it either by the "other CAD" (cardboard aided design) or just by-guess-and-by-gosh (which is how most of my stuff gets built, including CrazyBike2, Delta Tripper, and now the SB Cruiser).
If you want to find the ones that did share theirs (cuz there are some) you'll have to read around for them, though, cuz few have the info in the title itself.
FWIW, you can get all the critical proportions simply from photos of bikes, if they are at angles you can calculate things from or directly measure. Since you have to build the bike to your own measurements anyway, it doesn't really matter if they published the actual lengths of anything. All you need is to determine the angles of headtube and other things relative to each other, and approximate proportions of the rest of the frame. You can get good guesstimates of the actual lengths simply by comparing things to the components installed on teh frame (wheels, brake discs, grips, throttles, etc) so you can use those known sizes to determine the others.
it's more work than having them handed to you on a plate,
but it's certainly possible.
(I used to build props and models of scifi show stuff, and had to do this sort of thing off the tv screen or still images in magazines, etc...it's a PITA but it can be done well enough to work fine).
