I put together my ebike about a year and a half ago to get to and from work (27 miles total). It hasn't gotten a whole lot of use, mostly because it's unreliable and probably dangerous.
Details:
- Cheap aluminum mountain bike (probably needs to be replaced)
- 48V 1000W front wheel hub motor
- 20AH battery (I think)
- Crappy rim brakes
- Stock chain drive
- Max speed of 30mph
- Don't remember details of the controller
I have a few concerns with this setup. 1) I don't know if the aluminum frame can handle the torque of the motor and I don't have a torque arm, 2) the rim brakes loosen constantly and it takes me way too long to come to a stop when I hit the brakes as hard as I can, and 3) with the chain drive I have, I can't pedal fast enough to assist the motor at top speed, which means the battery often dies before I get home from work.
When I first put this ebike together, I did a lot of research on the electric components, but clearly not enough on the bicycle portion. As a result, I'm pretty happy with the motor, controller, and battery, but I think I might need a whole new bike. Reading guides and forums again, I realize I should have made sure my bike had a steel fork, disc brakes, and I think a chain drive with a bigger front gear? Unfortunately, the hub motor/front wheel I own does not have disc brakes and I'm not sure how they would be installed.
I am comfortable investing $1000 into rebuilding this ebike into the safe, reliable commuter vehicle I wanted it to be. Can someone please help me with this?
Details:
- Crappy rim brakes
- Stock chain drive
