thuktunflishithy
100 µW
- Joined
- Jul 10, 2015
- Messages
- 7
I was riding to work one morning last week and stopped for a red light. I didn't stop hard or anything, it was actually at the top of a hill. When I went to go again I got response from the throttle initially until I started moving then when it did cut in it was with noise and vibration as well as reduced power.
Opened it up checked the hall sensors. One of the three seemed to be not working. Looking back now I wonder if I just didn't press the probe in correctly and that's why I got no signal but it doesn't seem likely, I tested multiple times with the wheel in multiple positions.
So I ordered some Honeywell SS41 hall sensors. While I was waiting I got some OH137s from a friend, from the data sheets they seemed to have suitable characteristics so I put one in. Tested it before assembling the wheel, just like the other 2 turned on and off with the same poles of a magnet as they did.
Tried it out, same problem..I chalked it up to some property of the OH137 not being suitable. Last night the SS41s arrived so today I put one of those in there. Same problem.
This is where I am now. Golden Motor Smart Pie 4 Vector rear wheel, 36v thumb throttle, 4X12v10Ah SLAs running at 48v. When I test on the connector for the hall sensors I get 4.2v on the red wire and either 0.01v or between 3.2 and 3.24v on the yellow, blue and green wires as I rotate the wheel. Each phase wire for the motor shows 0.06v at rest. When I apply throttle I hear a faint click, either in the controller or the motor itself, hard to say which but no other response besides a green flashing led on the controller board. Checking the phase wires in this state shows the same 0.06v on all three. I release the throttle, spin the wheel up by hand and apply throttle and cruise control so my hands are free and check again. Same 4.5v on the red wire for the hall sensors power and 1.6v on each signal wire. I assume that's because they are on half the time. Checking the phase wires for the motors is the same, 26v on each half the supply voltage.
So from this I'm thinking the 3 sensors are working and the 3 phases of the motor are all working g. What could be the cause of the vibration, noise and reduced power? It's not mechanical, it coasts and pedals under human power smoothly. The amount of noise and vibration gets stronger with speed. Could my controller be sending g pulses out of phase for some reason? Any ideas what to test to narrow down my problem?
