Leebolectric
I see in many threads that people talk about the difficulty of flats with hub motors.
They suggest they go to heavier tires and wheels so that they reduce the risks of flats.
Heavier wheels and tires destroy rolling efficiency and suspension function and should be avoided in my opinion when possible.
The only time heavier wheels should be used, in my mind, is when they break spokes from torque or get blow outs from velocity impacts, but better quality tires/rims could help those issues and still give the benefits of lower wheel weight...Higher efficiency, faster acceleration and braking, better maneuverability and less gyroscopic effect.
In the racing MTB scene, it is widely known that the most effective place to remove weight is the wheels, and race times always improve on a lighter weight wheel set as long as the lighter one is as strong as the heavy one. So, with all the threads on efficiency and technology...what about this very simple one?
Tubeless is great, but has it's own issues...all my MTBs are tubeless...but this tip is for tubes.
Here is the secret magical hack....which seems to escape so many.... (i'm sure some people get it)
Carry a tire lever, mini pump and a patch kit...that's all.
1- Leave wheel ON THE BIKE...do not remove chain or anything at all.
2- Deflate tire completely if leak doesn't deflate it completely for you.
3- Use tire lever to pop off one side of tire bead, to access the tube inside....only really need it opened 6" or so, no need to pull bead off whole side of rim.
3- Pull tube out partially, preferably at the puncture point if obvious, otherwise ya may have to search it out a bit....pump can make it hiss to find spot easier.
4- Patch tube, wait a whole minute or two for it to dry...doesn't take much patience.
5- Push tube back into tire, add 1-2psi with pump so the tube is more round but not firm as this will help it not to pinch while mounting the bead.
6- Mount the tire bead to the rim, use the tire lever to fully seat the bead. Make sure the bead its seated all the way around before pumping.
7- Pump up the jam, Pump it up while your heart is thumping.
8- Ride that bitch!
(In other words, you only need to remove a wheel to REPLACE a tube, patch kits work great and don't require wheel removal.)
Much love y'all, HappiHollidaisy!
8- Ride that bitch!
