One for the battery-builder guys
tommie   10 W
Post by tommie » Jan 07 2016 12:44pm
Been curious to know what cells are in my battery that came with the BBS02 kit.
I`m none the wiser as i didn`t want to start pulling it apart any more..
Can only read a part of the text on one of the cells -
RZY5D
91335
as you can see they`re a lightish red color - any ideas (its supposed to be 13ah/48v)
wesnewell   100 GW
Re: One for the battery-builder guys
Post by wesnewell » Jan 07 2016 2:56pm
tommie   10 W
Post by tommie » Jan 07 2016 3:32pm
Thanks Wes,
so they`re Sanyo 2600MaH items,
maybe not the worst, but not up to the standard of the Samsungs or Panasonics you reckon?
Sunder   100 MW
Post by Sunder » Jan 07 2016 6:58pm
Hard to tell without a scale, but they look more like 26650s to me.
The way you can tell is that 18650s are 18mm in diameter (and 65mm long), and 26650s are 26mm in diameter.
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 Died... Electrified Ninja in Progress!
eCar: Mitsubishi Outlander PHEV... Warramty expired. Still not game!
eHouse: 6.2kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
tommie   10 W
Post by tommie » Jan 07 2016 7:25pm
@ sunder,
yes should have measured the top when the case was apart, but i think they're 18650`s as there`s 52 of them in there and its only a water-bottle shark type battery.
Don`t think you`d get that many 26650s in there??
Just wondered if they were any good or no good!!
(bike frame size)
Sunder   100 MW
Post by Sunder » Jan 07 2016 7:54pm
tommie wrote: Don`t think you`d get that many 26650s in there??
Yeah, now that I can see how big the whole thing is, it's probably not 26650s.
dogman dan   100 GW
Post by dogman dan » Jan 08 2016 6:54am
Nice looking assembly for sure. Not like the cheapo pack spot welding.
dilkes   100 W
Post by dilkes » Jan 08 2016 1:48pm
tommie wrote:Been curious to know what cells are in my battery that came with the BBS02 kit.
RZY5D
91335
Tommie
Just wondering where you purchased that kit, specifically the battery? I have one as well and have been searching high and low for a battery mount exactly like that one so I can easily move the battery between two of my bikes. Maybe the vedor of that kit would be able to help me.
tommie   10 W
Post by tommie » Jan 08 2016 2:12pm
http://www.aliexpress.com/store/product ... 29440.html
BTN China,
btw what`s the output of your battery, it was sold to me as a 13aH but i have my doubts.
dilkes   100 W
Post by dilkes » Jan 08 2016 4:03pm
tommie wrote:http://www.aliexpress.com/store/product ... 29440.html
BTN China,
Thanks for the reply with the link.
My battery in the same enclosure is a 13s4p config of Samsung 2.9Ah cells giving a total capacity of 11.6Ah. I tested it doing a controlled discharge at 15amps with a wattmeter inline and it did indeed dleiver around that number. However, they can put whatever flavor they choose of 18650 cells in that enclosure. My guess is that yours are Sanyo 2.6Ah cells as shown at http://lygte-info.dk/review/batteries20 ... %20UK.html.
The AliExpress link you pointed to says it is a 13s5p config and delivers 10.6Ah. Something is probably wrong here as:
  • I doubt you could fit 65 cells in there, although if you have it open you could count them.
  • If you could it would indeed be (5 x 2.6) = 13Ah
  • Most likely it is 13s4p config providing 10.6Ah
tommie   10 W
Post by tommie » Jan 08 2016 4:39pm
BTN China,
yes dilkes think you`re spot on there, i opened mine up and there`s 52 cells in there, no way could you get 65, typical sales pitch.
It`s pretty hilly where i am and i feel the BBS02 750W needs a lot more punch than 11aH, what do you reckon?
dilkes   100 W
Post by dilkes » Jan 08 2016 5:18pm
tommie wrote: yes dilkes think you`re spot on there, i opened mine up and there`s 52 cells in there, no way could you get 65, typical sales pitch.
I am not an expert on this, but just to be clear:
  • The rated Ah represents the capacity of the pack/cells to deliver power between full charge and full discharge state
  • The Amps that the pack can deliver to the controller/motor is what is important when determining performance of the motor
  • The BMS is usually set to limit the current delivered to prevent damage to the cells
That AliExpress listing you pointed to says:
Continuous Discharge Current 10 A
10 min Discharge Current 15 A
5 sec Discharge Current 18 A
However, I would be somewhat sceptical of the quoted info they have there.
The 750W BBS02 running flat out runs at about 1000 watts and would want 20 amps at 50V.
Having said all this, my guess is your pack should be fine.
DrkAngel   100 GW
Post by DrkAngel » Jan 10 2016 11:19am
48V 13Ah pack has 13s4p indicating 3250mAh rated cells.
(If Sanyo 2600mAh cells then fictitiously rated.)
But ...
Most likely the new Panasonic-Sanyo NCR18650BF!
(Panasonic bought Sanyo)
3.7V 3250mAh nominal capacity.
Various spec sheets recommend .5C charge and 1C discharge with reasonable 2C discharge capability.
Life cycles is a modest 300 (to 80% capacity) @ minimal .5C Charge\Discharge rates
1C-2C, more typical rates, will greatly reduce usable life!
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
wesnewell   100 GW
Post by wesnewell » Jan 10 2016 3:40pm
