Adaptto Controller PAS
ElectricDreams   100 µW
100 µW
Post by ElectricDreams » Jan 13 2016 5:22pm
Im wondering if anyone has used Pedal Assist on the Adaptto Controller at all?
Im looking at having a "legal" mode for the EU on a project Im looking at.
I can't seem to find much info on PAS and the Adaptto, only brief mentions,
Derek
ccmdr   100 W
Re: Adaptto Controller PAS
Post by ccmdr » Jan 13 2016 6:40pm
Running on Eco lets you utilize PAS, works a treat assuming you setup your gearing/cadence at speed with your wanted assist power :D. The power and speed variables are slightly lower than 'Norm' and 'Boost', but as it's been said before PAS at 30+ is going to be rare.
Not much more to say, it works. If I were to be ultra picky maybe the power stays on a little too long when you stop pedalling. I mean 3-5 seconds so it's not massive, but notable coming from a crystalyte setup.
Evidence backs up solid ideas, otherwise your thoughts are a figment of your imagination or a lesson learnt :D
100 µW
Post by ElectricDreams » Jan 14 2016 7:59pm
Ah ok, sounds good. I just need it to be close to "legal" so I can bluff if needs be.
Am I right in thinking that there is special firmware that adaptto can provide that helps with this as it sets it as default mode when powered on?
Wheazel   10 kW
Post by Wheazel » Jan 15 2016 1:30am
I have tried a few PAS functions and I think they all NEED an electronic switch in the brake handles.
The resolution of the magnet ring and the delay to cut power makes this function unavoidable in my opinion.
With a brakeswitch/hallsensor it works well and feels safe. That said, I very rarely use the PAS on my adaptto powered bike.
ccmdr   100 W
Post by ccmdr » Jan 15 2016 5:39am
When you turn the Adaptto on it automatically goes to 'Eco' mode first then you have to change it to higher power settings 'depending on your parameters in those settings'. It'll be 'legal' as long as your not coasting to a stop from 30+mph. No firmware changes required, plug and play :D.
The only thing it doesn't do is limit the throttle to 8mph whilst PAS is set at 25kph. Tbh if someone is questioning you that much, they either know the current law by heart, you were riding badly/too obviously in the first place :wink:.
As Wheazel said PAS isn't used frequently. Find trail use it works best, otherwise doing 20+ offroad I'd have a mid drive motor or use my light weight enduro's.
100 µW
Post by ElectricDreams » Jan 15 2016 10:23pm
Thanks for the info! 1st hand experience is always appreciated, in saying that I've never used Pas and I did see in various threads that it's not implemented very well in general except in commercial ebikes, particularly the adaptto controller. So I may have to use an arduino to keep it "legal" to an extent by detecting motion in the crank and stopping quicker than the controller.
ccmdr   100 W
Post by ccmdr » Jan 16 2016 9:35am
Tbh I think if I were you I'd try to get hands on before tinkering. Although PAS isn't implemented very will with standard magnets and hall, it is still pretty damn good. However if your wanting 'perfect' torque sensing your looking along the lines of this. It doesn't effect the 'legality' side of it, tbh a stonking great motor will give that away before looking further into how the system is setup :lol:.
100 µW
Post by ElectricDreams » Jan 19 2016 3:34pm
Nice find! Does the Adaptto support this at all by any chance? or just the CA? Legal for me would be showing the fuzz how I have to pedal to get it going, they'll drop it at that point, as long as I don't shoot past them at 60mph that is :lol:
Adaptto E-Drives Lab   100 W
Post by Adaptto E-Drives Lab » Jan 20 2016 3:58am
ElectricDreams wrote:Ah ok, sounds good. I just need it to be close to "legal" so I can bluff if needs be.
Hello,
1) Our controllers don't support torque sensors currently.
2) Everything is correctly explained about PAS feature except for the firmware. There is a regular firmware which is installed into every controller and there is a special "password protected" firmware for those who need the bike to comply with EU and US laws as much as possible.
This firmware has additional feature allowing to set a password for switching between power profiles. In practice you can ride at high speeds even without using the PAS but just get back to ECO and PAS with only one or two clicks. After that controller will require password for returning to Normal or Boost mode - this is useful if someone would try to check the power of your bike. :)
In order to get such firmware just send an email to techsupport@adaptto.com with the topic (password protected firmware).
For sales enquiries please contact us via: sales@adaptto.com
Technical questions: techsupport@adaptto.com
Web-site: http://adaptto.com/
100 µW
Post by ElectricDreams » Jan 20 2016 5:10pm
Thanks for the reply!
The password protected firmware would really be helpful in certain situations!
gensem   100 kW
Post by gensem » May 07 2016 5:40pm
Hello,
When you are using the password protected firmware in ECO mode does the throttle still works? I want to block the throttle in ECO mode.
Justin we really appreciate what you did!
scrambler   100 W
Post by scrambler » May 13 2016 9:05pm
Adaptto E-Drives Lab wrote:Hello,
To the Adaptto team: Is there any hope / plans that Adaptto will support a torque sensor like CA?
PAS mode is not only necessary for legal reasons, but it is also a great way to use the bike for a workout. Torque sensors provide a much more intuitive and pleasant experience in that mode than simple cadence sensors.
Adaptto has a great controller, it would be really nice if you could fill in that gap :)
wannesd   100 W
Post by wannesd » May 14 2016 7:39am
Hello,
What I have also suggested in the topic you created for future updates:
It would be better if the password was only asked the first time when going to other modes than eco.
Reason is that I can see someone wanting to go from "boost" to "normal", would need to enter password this way.
And that would suck wile riding.
If I would need to be locked in "eco" again, I would just switch controller off and on, which is easy enough to do while being stopped by the police.
Regarding eco mode, as pointed out here before: in EU you can have a throttle, but it can only give assist up to 8kph.
So in eco mode, it would be great if we can set different speed limits for throttle and PAS.
Thanks,
Wannes
Post by Adaptto E-Drives Lab » May 17 2016 2:48am
Hello,
Existing controllers have no more memory for adding new features, that is why the support of torque sensor will not be added.
Best regards,
wannesd   100 W
Post by wannesd » May 17 2016 9:22am
Adaptto E-Drives Lab wrote: Hello,
Best regards,
Will there be a new version with more memory and added features in the not-so-distant future?
scrambler   100 W
Post by scrambler » May 17 2016 2:04pm
Best regards,
Thank you for the quick response, and I second the question below from wannesd (memory is cheap :) )
wannesd wrote:Will there be a new version with more memory and added features in the not-so-distant future?
Post by Adaptto E-Drives Lab » May 18 2016 7:29am
Best regards,
Yes, we are planning to start producing new controllers during the oncoming year.
Best regards,
