Tire levers, moped tires, and tubes
amberwolf   100 GW
Re: Tire levers, moped tires, and tubes
Post by amberwolf » May 16 2019 12:37am
Just an update to this, after about three years:
A couple years in the original tires wore down enough to need replacing (they're still usable but down past the tread, look more square than round in profile now). Only one flat that I recall, was a slow leak kind of thing. No, wait, there were two--the second was a year or more later, right at the end of life for the tires, and was because of the thinned center tread area, I forget what the puncturing item was.
The second set is still going strong.
The rims and spokes have been great, though I damaged one rim with a serious pothole impact I could not avoid; no spoke damage, but the bead bent inward almost flat in that spot. Tire/tube was fine, and just kept riding to work. No longer trued, but ridable.
Later the same wheel got another bend in the rim next to the first from yet another unavoidable serious pothole. Still no spoke/tire/tube damage.
The tires *do* make a difference in efficiency--run at their rating abotu 35psi, I get less miles per wh than with the bicycle tires, I forget exactly how much poorer it is, but it is noticeable. I've added a lot of stuff ot the trike in the same 3 years, so it's gotten heavier, and less aero, and there's more loss from those than the tires. ;)
markz   100 GW
Post by markz » May 16 2019 5:58pm
I hate when rim gets damaged, but you've had great luck with rims and tires and tubes. My last tire got a cut above the wire seat, lasted a month. I think because I was doing a lot of "S" turns at speed, with 380lbs, and normal 45-50psi. Tube flats, too many, one a month easy. Thorn proof helps somewhat, like my last flat, would have held up but then again I would have gotten a flat somewhere out of the way and not in front of Canadian Tire.
I find some tires are on bicycle rims are dang tight, had one or two that were ultra tight.
amberwolf wrote:
May 16 2019 12:37am
