7005 aluminum
t_tberg   100 W
7005 aluminum
Post by t_tberg » Feb 21 2016 5:57pm
I'm starting my third build on an '05 Kona Dawg, this is the first time I'm using an aluminum frame. I believe the swing arm is the same material as the rest of the frame (7005 aluminum). Ideally I would like to get some custom torque plates made, does anyone know what the cost of something like this will be? The dropouts look to be 6-7mm, I may just use grins v4 torque arms since I already have one. Peak power will be about 2500w (20s). Has anyone used the '05 kona dawg with a hub motor or 7005 aluminum in general, what were your results?
t_tberg   100 W
Re: 7005 aluminum
Post by t_tberg » Feb 22 2016 12:31pm
Raged   1 kW
Re: 7005 aluminum
Post by Raged » Feb 22 2016 2:02pm
My old focus MTB was 7005. It was fine with a 2kw geared hub and a grin v4 torque arm.
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
ebent   10 kW
Re: 7005 aluminum
Post by ebent » Feb 22 2016 2:36pm
With that configuration why not put torque arms on both sides?
2005 catrike pocket trike, sold 2013
750 watt hub motor
48v 18ah Lifepo4 electrified 1/2010
2014 HP Scorpion fs 26 April 2015 owned
electrified 6/6/2015 ride till you die...don't die riding
48v 20 ah LiMn2O4
t_tberg   100 W
Re: 7005 aluminum
Post by t_tberg » Feb 22 2016 6:17pm
The plan as of right now is to try to build some steel torque plates that would pinch the dropout between the plate and some kind of backing. Here is a quick sketch of what I'm thinking.
Punx0r   100 GW
Re: 7005 aluminum
Post by Punx0r » Feb 22 2016 6:31pm
From the photo it looks like the brake calliper mounts are in the same plane as the outside of the dropout slot, so I would make a torque arm from steel plate that picked up on the nearest calliper screw (or both screws if you're running a lot of power). There's plenty of room below the dropout slot for a cross-bolt to make the arm of the clamping variety. Ideally you'd have a similar arm on the opposite dropout, but if your power level is modest then single-sided solution is viable.
Chalo   100 GW
Re: 7005 aluminum
Post by Chalo » Feb 23 2016 4:10am
7005 aluminum is fairly ordinary stuff that's comparable to 6061 alloy, the industry standard structural aluminum. In bike frames it has the unique benefit of allowing manufacturers to skip the solution heat treatment step of the hardening process, because in bike tube sizes it does that by itself at air cooling rates after welding.
Do not rely on any aluminum alloy to restrain motor torque applied through flats on a steel axle. The steel will always prevail.
