S06S controller marked as 36/48V
ideaHex
Adelaide, South Australia
I just received my order from BMS Battery of a S06S 250W Torque Simulation Sine Wave Controller. The label states "DC36/48V". Is this a typo or have they changed the controller?
I purchased this to match up with a Q100CST 32 hole 201Rpm motor which is going into a 29er wheel. My ideal setup would have been this motor and controller running at 12 or 13S. But the BMS website states that it is a 36V controller and after reading this forum I was under the impression these controllers would not handle 48V. I had already purchased a 10S Lipo pack as I really wanted the torque simulation feature.
I thought I would post this in case anyone was in the same boat as me.
Been there, done that.
Except for the controller. That is a new version.
With the older 36V version, it was hit or miss as to whether or not it would live on 12S.
I never could get the SO6S and the LCD-3 to work right on either 12S or 13S.
The controller just didn't like the odd Lipo Voltages.
But I have read here that at least one rider got the combo to work, so I suspose it's not impossible.
I run serveral S06p at 14S vor two years and 6000km without one Problem. The S06S I tried befor hat PASS Problems but it handled the 14S to.
It can change automatically between 48v and 36v. It sometimes gets mixed up if you connect a drained 48v battery, since the voltage could be the same as a charged 36v one, so it's best to make it absolutely clear by fully charging a 48v one. Another thing is the damping coefficient for the battery level display (parameter P5). I don't know if that has any affect further than the display, so It's probably a good idea to set that low until things have settled down.
Grizzl-E said:
1KW said:
how to run this controller on 72v?
You cant its limited to 60 volts max
It can be easily modded to run on higher voltages. Have a look at posts by snickers and fellow.
https://endless-sphere.com/forums/viewtopic.php?f=6&t=59225#p928932
https://endless-sphere.com/forums/viewtopic.php?f=6&t=68305
https://endless-sphere.com/forums/viewtopic.php?f=2&t=79763#p1177751
