wallypedal
We received a new motor and additional parts for our project. We are wanting to put this motor into a 20" fat tire front fork and rim. The fork has 135mm spacing between dropouts, as does the motor. Had a whole stack of emails back and forth on motor selection and other topics, but the truth is neither we nor the vendor knew for sure how this would come together until we started fitting up.
The present problem is that the wheel is not centered well, with about 19mm clearance to the fork on the 'freewheel' side - and about 9mm on the left (cables out) side.
To be centered then each side should be about 14mm or so.
The spoke holes are to the outside of the rim, in rows both 30mm from center. Since the spokes spread going away from the motor flanges, dishing and spoke head changes don't have much effect.
I could maybe get a special axle machined, that would likely cost more than the motor!
The cable side axle protrudes 35mm from base to end of threads. I might be able to get a 2 or 3mm spacer on and still get full nut engagement Maybe more.
The other axle end also is threaded and has flats for 35mm. I could, in theory, machine those flats additionally at least the 5mm and still get full thread engagement. The thickness of the dropout, washer, torque arm, etc. add up to more than 5mm anyway.
The rim is just drilled without eyelets. I have enough flat rim surface outboard of the present spoke holes to move them 6mm or so. On each row of spoke holes, the holes are 70 mm apart around the circumference. I would just split the difference if I drilled new ones offset.
Those are my newbie thoughts, but would sure like to hear from the experts. This wheel is low speed (15mph max) and quite low load and shock bearing....if that helps.
I can post pictures if that helps.
Thanks!
Wallypedal
Thanks!
Wallypedal
