ScooterMan101
I am starting to put together the pieces of a Q100c cst, with S-LCD Display, Throttle , Controller, etc.
Do I have to connect the magnetic spoke sensor , If I am only going to ride it with a throttle ?
If I leave the PAS off How will the Display work , will it be just linear speed ?
There are 5 PAS settings on the Display , do I have to do anything with those if I only want to only connect a throttle ?
Can you just use the throttle if you have the PAS installed and connected ?
I did get a small 48 volt KT48SVPR-XDL07B controller, to use instead of the 36 volt that BMS sells for the Q100 motors.
So
When Looking at the Controller , Motor Hall wires there are five , Red/Black/Blue/Green/Yellow,
However
The wire coming from the Hub has one more pin , a white one .
What is the White Wire ?
Has anyone just left this one off ? ( there is only 5 Hall wires going into the controller , on the controller side , just like the Infineon )
So
However
