Need suggestions for Headlight / Taillight
g725s   100 mW
Post by g725s » Sep 21 2016 10:29pm
Hello,
I just put together a BBSHD mountain bike and seems because of my work schedual the best time to ride is now getting dark.
Looking for suggestions on a good Headlight and Taillight that I can connect to a 52v battery.
Edit: I'm also open to a stand alone option with its own battery, maybe one that would use my own chargeable AAA battery(s)
Thanks!
Marin   1 kW
Re: Need suggestions for Headlight / Taillight 52v
Post by Marin » Sep 21 2016 10:56pm
I have picked up a few head and tail lights from Lunacycle, they work on 52v and reasonably priced
Marin ex-rental hybrid with 48v bionx...sold
Specialized hardrock with magic pie 4-5
Lunacycle with l/r mid drive coming soon
Kona Caldera with QS 30H (maybe), and phase runner
Giant Yukon bbs02
Kona Abra Cadabra bbshd
Wildfire fat bike bbshd
g725s   100 mW
Post by g725s » Sep 21 2016 11:28pm
Marin wrote:I have picked up a few head and tail lights from Lunacycle, they work on 52v and reasonably priced
Yes, I've seen those. But was wondering what other options might be available for comparison. At Luna they only have the one headlight and the one taillight.
I might also consider stand alone head and tail lights too. I'm just starting to look into this.
dogman dan   100 GW
Post by dogman dan » Sep 22 2016 5:40am
For headlights, I tried a few different things, before the higher voltage led's got cheaper. Tons of options out there now. Don't go with the super cheap 12-60v led light you see on ebay, it's dim.
What I settled on was two 800 lumen flashlights, which fit nice in a rubber handlebar holder I got on ebay. I had to look hard for the lights, because most run on three AAA cells. I wanted one that runs on two AA cells. I had tons of those in nimh for cameras. Charging three nimh a bitch with the charger I have, that charges them in pairs.
Plenty bright for me, but what I really liked was that I can aim one low and one high, giving me a nice beam including the last few feet to my wheel.
The main reason I wanted a removable light, was for touring. The lights could then easily be used in my tent.
For rear, I used two of the cheap flashies that run on AAA, and just run dry cells there.
Ykick   100 GW
Post by Ykick » Sep 22 2016 7:34am
For a good bright focused beam, I use one of these -
http://www.ebay.com/itm/Mini-CREE-XML-T ... 41a16976bd
For bike mounting, several options here -
http://www.ebay.com/sch/sis.html?_nkw=A ... 2749.l2658
For a decent floodlight which doesn’t seem to blind oncoming riders and runs off battery packs up to 100VDC, I’ve been very fond of these -
http://www.ebay.com/itm/3W-DC12-100V-Mo ... 568c60dd44
Basically, I use both. Majority of the time the flashlight is just on flasher mode and flood provides plenty of light but sometimes on really dark & desolate roads I rely more on the high and focused beam of the flashlight.
I'm sure someone will come along and call my suggestions "rubbish" while suggesting $300 bicycle lights. I've tried the "Stellas" of the bicycle world and they're good but I've been using this setup for couple years now with excellent results while saving a ton of money.
- Frank Sinatra
g725s   100 mW
Post by g725s » Sep 22 2016 10:30am
Ykick wrote:For a good bright focused beam, I use one of these -
Ykick,
Thanks. The more I think about it, I like the idea of the flashlight as a headlight. I'm going to go this route for starters with the headlight. As I like the idea of using my AAA NiCad batteries.
I found this article: https://electricbike-blog.com/2015/04/2 ... from-ebay/ and tend to agree if I do attach a light to my 52v battery it would be best to have in-line fuse.
g725s   100 mW
What are considered the best Flashlight holders?
Post by g725s » Sep 22 2016 11:45am
The more I think about this I am really leaning on wanting a Flashlight for a headlight. Is this a bad idea for any reason?
I like that I could take it off and use it to check things out on the bike at night.
With this in mind, anyone have suggestions for the best Flashlight holder?
The fingers   100 GW
Post by The fingers » Sep 22 2016 4:26pm
I like two; one on the handlebars to illuminate the road, another on my helmet for whatever I happen to look at.
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
Metallover   10 kW
Post by Metallover » Sep 22 2016 5:03pm
I'm running this light. It is hard to mount. It takes 12-24v. The best thing is that is has a true low beam/high beam. I feel safe riding at night.
https://www.amazon.com/gp/product/B018L ... UTF8&psc=1
Add your bike to the Unofficial E-Bike Garage! - http://spreadsheets2.google.com/ccc?key ... OWcg&hl=en
My Build - Vector Frame, 20s 25Ah LiPo, Max-E, Cromotor - 10.89HP on the Dyno
g725s   100 mW
Post by g725s » Sep 22 2016 7:45pm
Metallover wrote:I'm running this light. It is hard to mount. It takes 12-24v. The best thing is that is has a true low beam/high beam. I feel safe riding at night.
That thing is HUGE! Let's see a picture of that on your bike please.
Metallover   10 kW
Post by Metallover » Sep 22 2016 8:06pm
Didn't get pictures of what it's like facing the light. The low beam is way easier to look at than the high beam, yet still bright enough to be seen. I think the light pulls about 30W on high beam, but don't quote me on that.
Light is hacked on there. I will some day mount it better, hopefully!
low beam
high beam
AMC11   100 µW
100 µW
Post by AMC11 » Sep 23 2016 4:29pm
I've been using an Ultrafire A100 as a bar-mounted light for a while now, pretty happy with it. You'll get the best performance from a 18650 cell and dedicated charger but it can also run on 3 AAA cells. The beam is wide and circular with a very even spread, no 'hotspots' or dim areas. It's not ideal for really dark roads but it's certainly not bad either and it can also be dimmed enough not to dazzle others. It has a zoom function as well which can be quite handy if you need to see further ahead.
DrInnovation   100 W
Post by DrInnovation » Sep 24 2016 8:26pm
I did a flashlight for a while.. but always worried about it being stolen and when I forgot to charge it and it was almost dead and I had to ride home in the dark I went for a dual cree light from eBay as my headlight. Been using it 2 years and would never go back. I only went for 500LM and even with 2 crees its a bit hot. If I did it again I would probably go for a broader and brighter headlight. Luckily my commute is only a few miles.
For tail light I had a basic static tail with 5 LEDs, but I've had some cars get uncomfortably close so recently decided I wanted something that caught more attention and kept then back. So I got a flashing LED
http://www.ebay.com/itm/371239440351?_t ... EBIDX%3AIT
which I find very nice. At $3, its a great addition. I aim it at the ground about 10-15FT behind me and it makes a flashing spot almost 6 feet across 10ft long. Cars now keep a bit more distance :D
Owner of a Crystalyte 4012/409 with 10aH 16s Headway on a old huffy frame. Its not fast but it climbs my daily commute up 8% and 10% grades nicely. Washout frame with a "e-bike" front-drive hub with a home-built 18650-based 20ah-36v. My bigger "E-ride" is a chevy volt.
markz   100 GW
Post by markz » Nov 20 2017 11:57pm
Exaggeration or what?
18 cree's though! 4 modes, xml t6
https://www.ebay.com/i/332337949277?rt=nc
though I debated whether to go with this unit
https://www.gearbest.com/headlights/pp_971695.html
This is cheap, earlier post, worth the pocket change to try out a few ;)
https://www.ebay.com/itm/3W-DC12-100V-M ... 568c60dd44
Maybe a few of these
https://www.ebay.com/p/Mini-2500lm-Adju ... 4096.l9055
So many choices, buy a few of the cheap shit first I guess.
heavymetalthunder   100 W
Post by heavymetalthunder » Nov 21 2017 3:37pm
Being seen during the day and at night has always been a problem, my bike runs on 12s lipos (52v fully charged) and what I did was to get a transformer they use on golf carts 48v to 12v on ebay. Also on EBay have many 12v headlight and tail light setups you can buy. With a micro switch I have also included stop lights and turn signals. I ride with lights on all the time just like a motorcycle.
Alan B   100 GW
Post by Alan B » Nov 22 2017 12:24am
There are lots of other threads on this topic. Search is your friend.
Some lights are designed properly for this purpose and do the job better. They are even legally required in some jurisdictions. Flashlights are not optimal. More lumens is not always better, and many lumen claims are pure fallacy. Do plenty of research, there are lots of choices, and many poor ones.
