How To, 50A BBSHD Controller Mod
Cobain Windsurfer   100 µW
100 µW
Re: How To, 50A BBSHD Controller Mod
Post by Cobain Windsurfer » Mar 02 2018 6:14am
Some pictures of my mosfet swap out. The new IRFB4110 from is rated 100V. Found very good information about it here https://electricbike-blog.com/bbs02-controller-mods/
Very important to not have used the controller for some time before soldering shunts, mosfets and so on, or there will be shortcuts and sparks since the caps can hold electricity for a long time. To get rid of the old mosfets I found out the best way to do it without any damage is to wiggle them carefully back and forth one by one, until the legs of them snapped, and then clear the holes afterwards. I cut the legs of the new mosfets at the right length, screwed them on slightly on the heatplate, inserted them all in the PCB and solder all the legs. As pointed out before, soldering them to the PCB without attached to the heatplate will make it impossible to screw them on later (the hole of the mosfets and the ones in the heatplate will not line up). Now I am only waiting for the caps to arrive. :)
100 µW
Post by Cobain Windsurfer » Mar 08 2018 12:13pm
Epyon wrote:
Aug 13 2017 5:13pm
A big thanks to you guys. I swapped out my shunt resistors and capacitors.
A bit off topic, but does anyone here know where the ROM/EPROM chip that contains the firmware is located on the PCB? Perhaps it is possible to replace that chip with the one on my faulty controller with the old firmware to make trottle override PAS. :?: :?
fechter   100 GW
Post by fechter » Mar 08 2018 2:06pm
BBSHD processor chip.jpg (92.42 KiB) Viewed 1709 times
Well, it's right there. It would be very challenging to replace the chip. I don't think you could get a new chip from anywhere either.
What would be easier would be to re-flash the firmware on the chip, but that is something only Bafang has and they are not likely to give you a copy. Possibly you could send them the controller and have them re-flash the firmware and send it back, but I doubt they would be willing to do that.
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Mar 08 2018 11:39pm
fechter wrote:
Mar 08 2018 2:06pm
Several resellers have the firmware, perhaps someone will pony up...
100 µW
Post by Cobain Windsurfer » Mar 12 2018 11:43am
fechter wrote:
Mar 08 2018 2:06pm
Thanks for the info! Seems hard to replace that chip with the old one, but so is a re-flash. How can it be done? Bth, my caps has arrived, but as E-mil has pointed out, the small board on the PCB (for the 6V Headlamp cable), make the 1000µF impossible to fit. Is it possible to remove the small board from the pcb to make it work?? (The old controllers didn´t have these "headlamp cards" but the PCB had holes prepared for it.)
fechter   100 GW
Post by fechter » Mar 12 2018 2:02pm
To re flash the firmware, you need an ISP interface (sort of easy) and the software (not so easy).
Generally you can re-write the firmware, but there is no way to read it from the chip. This is to keep people from copying or hacking it. The software part would need to come from Bafang.
Daxxie   1 W
Post by Daxxie » Mar 21 2018 5:31pm
How to do this 50A mod to a Bafang Ultra drive?
Should be easier. Controller is not potted.
I have a standard one that I would like to upgrade.
fechter   100 GW
Post by fechter » Mar 22 2018 8:09am
Daxxie wrote:
Mar 21 2018 5:31pm
It's not so easy. Just getting the motor apart can be a challenge. The shunt is located on the controller board next to where the negative battery terminal attaches. This is under the mezzanine board, which needs to be removed to get access. Due to the board being recessed in the housing, I think you'd need to completely pull the board out to tweak the shunt. Use some thermal grease when you put the board back into the housing.
Shunt location 1.jpg (95.44 KiB) Viewed 1557 times
Daxxie   1 W
Post by Daxxie » Mar 22 2018 9:09am
Well I have a Ludicrous version but I also bought a standard Ultra.
It looks pretty different from your picture.
This is how my Ludicrous version looks.
burner77   100 W
Post by burner77 » Mar 22 2018 9:13am
you had to remove the Ludi pics?
http://fasterbikes.eu • Domino, MXUS V3 Turbo (with FF & HubSink) and Bafang BBSHD shop • 5% discount for ES forum members, use voucher "ESMEMBER"
fechter   100 GW
Post by fechter » Mar 23 2018 10:14pm
Yes, it does look a lot different, but similar.
The shunt is located here:
Ultra Motor Controller - Shunt Location.jpg (119.23 KiB) Viewed 1514 times
It looks pretty easy to attack. It's 5 milliohms, so with some math you can figure out what to place in parallel with it to get what you want. To double the current limit, use another 5 mOhm. I've simply stacked another one on top before and it worked OK. It will get hot if run near the limit for long. Ideally, you'd want to place two side by side so they are both in contact with the board, but maybe not worth the work. You could also completely remove the stock one and replace it with a different value. I got a bunch of 3 milliohm ones from Mouser that are the same physical size.
That board will require a lot of heat to solder on the shunts because it's aluminum. Use a big iron.
And I have never found a datasheet for those FETs. Mystery part number. EZ85NF12
dalysea   100 mW
Post by dalysea » Apr 02 2018 11:31pm
" I got a bunch of 3 milliohm ones from Mouser that are the same physical size."
For the Bafang Ultra, to swap out the 5mOhm and replace it with a 3mOhm, can you please tell me what is the part # from Mouser?
Is it Mouser #: 660-PSIDTEB3L00F
https://www.mouser.com/ProductDetail/KO ... OmV1HfQ%3d
Thanks!
fechter   100 GW
Post by fechter » Apr 03 2018 8:52am
dalysea wrote:
Apr 02 2018 11:31pm
Thanks!
I think the ones I got are these:
https://www.mouser.com/ProductDetail/Bo ... 2kZA%3d%3d
Physical size is 2512.
Alan B   100 GW
Post by Alan B » Apr 03 2018 9:11am
A question, how are the 50A BBSHD mods holding up? I saw on FB that one had darkened the motor wires (insulation changed color) and destroyed the small gear. Not suddenly, but over time. How common is this? Does it happen even at 30A or are we pushing a bit into getting it too hot? Any other issues folks are seeing on these, or are they pretty reliable??
fechter   100 GW
Post by fechter » Apr 03 2018 9:40am
Sounds like excessive motor temperature. I haven't tried 50A, but at 30A you can certainly overheat the motor if you try hard.
Daxxie   1 W
Post by Daxxie » Apr 10 2018 7:36am
Sorry guys, don't want to go too much off-topic here.
But I just received another Bafang Ultra wich I bought of Aliexpress from a "reliable" company.
Price was quite good.
It arrived today and I opened it up immediately to compare it with my Luna Ludicrous version.
The Ludicrous is a 1.3 version and the new one I got from China has "version 1.5" stamped on it.
Controller looks a bit different but I noticed the Hall sensors were not connected.
The connector is missing? WTF I don't think this will work.
And to my surprise the "cheap" chinese version has a steel gear, where the Ludi has a nylon gear.
fechter   100 GW
Post by fechter » Apr 10 2018 11:21am
We should have a separate thread for the Ultra motor.
I heard some versions of these used a sensorless controller, which could explain the hall sensors not being used. At some point in time they switched to the metal gears also. Seems Bafang keeps making changes, which maybe indicates the earlier designs had some problems.
Daxxie   1 W
Post by Daxxie » Apr 10 2018 1:27pm
fechter wrote:
Apr 10 2018 11:21am
I heard some versions of these used a sensorless controller, which could explain the hall sensors not being used. Seems Bafang keeps making changes, which maybe indicates the earlier designs had some problems.
Well I didn't hook it up yet.
So maybe it could work without this connection?
Gonna try that.
I heard from Luna they are currently not offering the Ludicrous version anymore.
"Too many reliability issues from users"
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Apr 11 2018 10:39pm
fechter wrote:
Apr 10 2018 11:21am
Changes without data or notification. Argh! And forget about tying changes to serial number, double ARGH!
Alan B   100 GW
Post by Alan B » Apr 11 2018 11:07pm
Nothing new there.
racingame   10 W
Post by racingame » Apr 18 2018 6:45pm
Sorry for the interference, but isn't "Ludicrous" version just a Luna internal name for a controller where they switched out the shunt (and maybe also replaced aluminum case IIRC)?
fechter   100 GW
Post by fechter » Apr 19 2018 9:23am
racingame wrote:
Apr 18 2018 6:45pm
Yes. It may also have a steel gear instead of the plastic one.
dwturbo70   1 µW
Post by dwturbo70 » May 09 2018 11:09am
Does anyone sell Ludicrous type controllers or provide a service to upgrade an original? I'd try the modification myself, but that would be an expensive waste if I screwed it up,LOL!
Daveograph   1 µW
Post by Daveograph » May 31 2018 5:35pm
Just wondering would the display show the correct amount of watts being used? running the bbshd @ 52v nominal / 45 amps (shunt mod)
fechter   100 GW
Post by fechter » May 31 2018 9:52pm
Daveograph wrote:
May 31 2018 5:35pm
No. If the shunt is modified, the current on the display will read lower than actual. If you are getting an actual 45A, then the meter on the display will probably show 30A. 30A will always be the highest reading.
