Oval chainrings
jpgey   1 kW
Oval chainrings
Post by jpgey » Sep 28 2016 2:28pm
Just why ?
MrDude_1   100 kW
Re: Oval chainrings
Post by MrDude_1 » Sep 28 2016 3:01pm
The concept is simple enough.. Your legs dont make the same power everywhere in the 360* rotation like a motor does. Instead, you have better areas of up/down-stroke, and are almost coasting power-wise when in-between.
So the oval shape lets the ratio change to match that.
atleast thats the idea. They were popular with road race guys for a short time in the late 90s/early 2000s and then died off quickly. Personally I dont see an advantage for the average joe.. but im just a fat guy that prefers the motor do all the work anyway. :mrgreen:
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
jimw1960   10 kW
Re: Oval chainrings
Post by jimw1960 » Sep 28 2016 3:35pm
My old Raleigh Technium mountain bike had those. It's supposed to give you more power on the downstrokes. I thought it worked well enough. I didn't really notice it while riding.
Punx0r   100 GW
Re: Oval chainrings
Post by Punx0r » Sep 29 2016 7:09am
It's not just your legs, it's the variation in both speed and both that affects any crank assembly over a revolution. You get maximum torque at 90 and 270 degrees and zero at 0 and 180 degrees. The oval shape gives more mechanical advantage (leverage) where it's more useful.
I think Chalo observed that oval chainrings resurface as new/latest tech idea about once per decade...
Hillhater   100 GW
Re: Oval chainrings
Post by Hillhater » Sep 30 2016 1:18am
There are still one or two riders using them in the Grand Tours (TDF etc)
Lurkin   100 kW
Re: Oval chainrings
Post by Lurkin » Sep 30 2016 3:13am
Marketing the "latest" gimmick required for exxxxtreeeemmmmeee cyclists. :roll:
Which really means there might be a small gain, but to the common joe, unlikely to have much benefit if noticeable.
I test rode a friends bike with one, just wasn't something to write home about really.....
amberwolf   100 GW
Re: Oval chainrings
Post by amberwolf » Sep 30 2016 4:45am
The main thing the Shimano ovoid BioPace rings do for me is to help with my knee pain--it hurts less with these than with others, for teh same length of cranks/etc.
MrDude_1   100 kW
Re: Oval chainrings
Post by MrDude_1 » Sep 30 2016 9:25am
amberwolf wrote:The main thing the Shimano ovoid BioPace rings do for me is to help with my knee pain--it hurts less with these than with others, for teh same length of cranks/etc.
I could see that.. less stress at the less ideal knee angles.
amberwolf   100 GW
Re: Oval chainrings
Post by amberwolf » Oct 03 2016 4:44am
FWIW, I haven't had any on my CrazyBike2 for a long time, or at all on SB Cruiser, which have a different seating position from a normal bike.
After testing here, during my redesign/rebuild of SB Cruiser,
https://endless-sphere.com/forums/viewt ... 0#p1227692
I remember why--they don't do the same thing in this position (though they still help some) because the ovals are angled for pedalling from above them, not behind/above them. So everything is offset by something like 45 degrees...
I'm tempted to figure out a way to rotate the rings around the spider so they do what they were designed for at the seating position I'm actually at on SB Cruiser.
MadRhino   100 GW
Re: Oval chainrings
Post by MadRhino » Oct 03 2016 7:23am
They were introduced by Shimano in the eighties. After a decade of growing popularity, most abandoned them to be able to use the new, better front derailers that were not compatible with the Biopace. Still in use today but never pushed further in its development. I used one for a while when they were introduced, liked it and found that the crank feeling was round but it didn't improve my time.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
EVTodd   10 kW
Re: Oval chainrings
Post by EVTodd » Oct 03 2016 9:05am
My old Blue Max mountain bike has the Shimano oval rings on it. The bike does pedal like a dream. Other than feel I doubt it does much for performance.
New Tidalforce friction drive build: http://endless-sphere.com/forums/viewto ... 28&t=28029
My Friction Drive Outrunner Setup: http://endless-sphere.com/forums/viewto ... &start=330
keithmac   10 W
Re: Oval chainrings
Post by keithmac » Oct 03 2016 11:56am
I had a Raleigh Mirage years ago with Biopace-sg chainrings, it worked very well.
Surprised there aren't more bikes still using it to be honest.
Sunder   100 MW
Re: Oval chainrings
Post by Sunder » Oct 03 2016 5:11pm
There are two versions: the Shimano biopace which reduced load on the knees, and made LESS power.
And the Osymetric ones which allegedly make more power and still in use by some professional teams: http://www.osymetricusa.com
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 Died... Electrified Ninja in Progress!
eCar: Mitsubishi Outlander PHEV... Warramty expired. Still not game!
eHouse: 6.2kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
